Question about Intel Computers & Internet
Turn on screen says check pc signal
Screen says modem is working
  • 52 Answers
This means that the connection to the PC is not entirely stable, make sure that the cable going from your monitor into the PC is securely in the sockets and that the 2 screws are done up. Failing this you may have some computer hardware issues.
Posted on May 27, 2009
Inconsistant wireless signal in house
Have you checked that the signal on your new cable modem/router is strong enough to reach your wireless devices? You may need to re-site the cable modem to get better coverage in your home. Your old one probably worked fine in the same position but that doesn't mean a new one will. There are a few things you can try to get the best of the range it has. Internal walls and furnishings all play a part in reducing the effective range of the router. Most routers will give you at least 50 metres indoors. Keep the router as high and as far away from walls as you can, this will greatly improve the range. Try to ensure the router is not screened by large near by metal objects such as steel PC cases, these will absorb wireless signals and reduce the range.
Jan 18, 2014 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
When I turn my monitor on I get an unusable signal box on the screen. The Internet provider says the Internet is functioning at the modem but I get nothing on the screen. I also have a wireless router...
It's not an Internet related problem. It's problem with monitor.
Please check
1. If monitor cable is connected properly to the tower(CPU)
2. Check the [ I/P ] button and try to press it to toggle between interlaced and progressive scan mode
Sep 12, 2011 | HP Computers & Internet
The signal from the router is ok but it cannot be passed to the computers through the switch
Check the computer's network interface card by opening the command prompt and typing ping 127.0.0.1 If you get back 4 replies 100% then ping router's and modem's IP addresses. If all are working. Try resetting your devices unplug your modem, router, and turn off your PC. Wait about 2 minutes. In this order, turn on your modem, wait 15 secs, turn on your router wait 15 secs, now turn on your PC.
Sep 07, 2011 | Computers & Internet
After connecting modem to pc, the link light in modem was orange, the others were all green, of course, pc can not surf internet. Try to restart and change modem location, issue persists
Good day.You can do the following to make your connection work.
1. You need to make sure that the cable connection between your modem and wall outlet is tight.
2. Ethernet cable should be detected when plugged in to your pc ( usually a pop up on your screen will tell that)
3. Link light means there's a conenction between your pc and cable modem.
4. You might need to check if the online light or cable light on the modem is on to make sure that your modem is getting a signal from your cable internet provider. If its off you need to contact your internet provider because there could be an issue or possible outage on your line.
5. You can also try to restart your computer once its connected to the modem to refresh the ip address of your pc.
6 You can also contact the tech support number for your internet provider for them to diagnose the issue.
Hope this information will help resolve you're problem. Have a great day and thanks for using Fixya.
Jun 11, 2011 | Arris SURFboard SB5120 Modem
It wont let me connect to the internet
You need to check internet connection settings. If you use wifi connection you should in active wifi area ( check signal on your screen). If you use modem as internet connection check the setting ( you may need assistance from service provider. If you use cellular phone as modem, make sure, you have phone's pc suite installed properly on your laptop then paired tehm using firewire.
Regards
May 17, 2011 | Computers & Internet
Computer won't turn on says no signal but router and modem are working
1. check for proper power connection.
2. if it is ok, then check that your smps is giving proper output- it cannot be checked by yourself. go to near by hardware repair center.
Feb 27, 2010 | E-Machines eMachines Desktop PC
My Motorola Modem Mstatea
When the DSL light turns red it indicates that the modem has no internet signal.
So please check if the cables are connected properly
Also ensure that there is a proper signal to your premises without any interference
This is called intermittent connection
If the DSL light turns red it indicates that there is a problem with the cables connected or the DSL line
Please check your DSL connection with ISP
There is on another reason that the modem might have gone bad.
If all the above steps are executed and if this issue still persists replace the modem
Jan 28, 2010 | AT&T High Speed DSL Modem
Wireless not working
First thing to do - check wireless is turned on. It sounds basic, but sometimes the switch can get knocked, meaning that the laptop won't recieve any wireless signal. If this doesn't work, play around with the settings for a while - if you're running Windows you can go to 'network connection' in Control Panel and right-click on your wireless connection; go to 'repair' and the repair wizard will go through it to try and fix it. Make sure both the wireless switch on your laptop is turned on, and that your modem is turned on too.
If this doesn't work, go to your modem's setup page (usually a web page - the address will be in the manual) and choose a different wireless channel - 0, 6 and 11 are the only non-overlapping channels. You may want to adjust your wireless signal power to make sure you have enough signal. You might also want to run a diagnostic on your modem to see if it is running properly. Some modems will display on the setup page which computers are active. See if yours comes up.
If this still doesn't work, you may want to go to an internet cafe or other wireless hotspot to check whether it is your modem which is at fault. If you get a signal and can connect, then it may well be the modem at fault. Check at some other locations just to be sure. If not, it sounds like the wireless card has a problem. If it is an internal wireless card, you might want to take it back to the manufacturer for repair. If it is an external wireless adapter, you may just want to replace the card or adapter to see if this helps.
Hope you work it out, and that you get your wireless connection back soon!
Jan 28, 2009 | HP 14.1 Refurbished Thinkpad, 1.13GHz...
Computer stopped receiving wireless router signal
In this order: 1) Turn off all PCs and printers connected to the router. 2) Unplug your router's power cord. 3) Unplug your modem's power cord. 4) Wait for at least 2-3 minutes. 5) Connect the modem's power cord and wait for at least 2-3 minutes. 6) Connect the router's power cord wait for at least 2-3 minutes. 7) Turn on each PC separately and wait until it is completely finished booting before turning on the next PC.
If you still do not have connectivity, read the manual and change the channel of the modem. YOu may be experiencing some RF interference, ie microwave, wireless phone system etc...
Oct 29, 2008 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
20 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
