Question about E-Machines eMachines Desktop PC
Check pc signal monitor is working fine
Turn on computer screen says no pc signal have emachine
    Genius:
  • 2,785 Answers
Plz try by resitting the ram
Posted on May 27, 2009
    Problem Solver:
IS the video cable plugged in? there is either a VGA like old CRT's have or a DVI cable like modern PC's or Monitors have. Is it plugged in properly, Can you try another cable? try another monitor, is the monitor set to the right output(most monitors you can select VGA or DVI input, make sure it is on the input that the cable is plugged into (if you use DVI ensure monitor input is DVI)
SOURCE:
Emachines won't send signal to screen, when turned on it makes one long continuous beep
The beep signifies an error. But different bioses have different beeps. You can check with the emachine site to tell you what 1 beep on the machine signifies and you can be guided accordingly. Could be bad power supply, connection, peripheral, etc
Sep 01, 2017 | E-Machines eMachines Desktop PC
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
I keep getting no signal when i turn on my emachine desk top
Its probably the power supply..they tend to go quick on emachines.!Replace the Power supply.
Jun 11, 2010 | E-Machines eMachines Desktop PC
When i turn on my screen it says no signal and turns off
Either the "data" cable between your screen and your desktop is defective, or that cable is not connected to your screen, or that cable is not connected to your desktop, or the video-card inside the computer is defective.
Check the connections.
Temporarily connect the screen to a different laptop/desktop computer, to see if the screen still works.
Temporarily connect a different screen to your desktop, to see if your desktop's video-adapter is working.
Feb 28, 2010 | eMachines W3507 PC Desktop
Emachine T6410 turns on but the screen says ''No Signal''
This problem is very common when you have a bad ram/ memory module or it is not making sufficient contact. Remove them and clean with a piece of dry cloth and reseated properly. Try it again. If it is still not coming on, the ram may be bad. Get them tested and replaced.
Thanks,
Lolita
Jan 05, 2010 | Computers & Internet
Monitor only has a black screen, when i turn it on the power button turns from blue to orange and the screen says no signal and then turns black
First open cpu cabinet Refix RAM memory .
Then pull cmos cell from motherbord for 10 minutes so all settings are defaults.
Then when power up the computer press F8 key then enter in enable vga mode.
Then go to control panel and display proeprty then settings change screen resolution to 1024*768 then apply and ok.
Then restart the computer.
Let me know if you need more assistanse.
Thanks.
Aug 31, 2009 | E-Machines eMachines Desktop PC
Computer not communicating a signal to monitor
You can fix that by getting a new graphics card
I'm assuming you have a T3830 emachine.
here's the link to replace video card
http://downloads.emachines.com/userguides/8511279_eM_NG3_chassis_HW_ref_en.pdf
Mark
Apr 09, 2009 | E-Machines eMachines T3830 PC Desktop
Emachine shows no signal when turned on black screen
check your cable from the monitor to the PC , make sure they are all fully connected and try again . please post what happens
Sep 15, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
368 people viewed this question
Top E-Machines Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
