Question about Sony Grand WEGA KF60XBR800 60" Rear Projection Television
Sony 60 in projection tv makes weird noise
My bulb burned out today. i was able to replace the lamp, but when i turned it on to check to see if the lamp was working it started making this high pitch sound. the tv did not go on and i still have the red flashing light what do u think the problem is? How much will it cost to repair the problem?
    Sergeant:
  • 184 Answers
Did you hear that wierd noise 3 times after you turn the TV on? if so the ballast is working try replacing the lamp XL-2000u
Posted on May 27, 2009
My tv turns on but 2 minutes later my picture goes out but still have sound
You may attempt a B+ replacement. This controls the high frequency voltage that powers all the RGB tubes needed for picture. The B+ flyback looks like this:
Best of luck! Thank you
May 27, 2011 | Mitsubishi VS-6041 60" Rear Projection...
My sony sxrd 60 comes on only for a sec than go off and red stanby lamp blinks 4 times,i have cleanned vents and checked bulb door,can only turn tv off and back on ,and still onlly get screen to show...
4 times red light blinking indicates problem with exhaust fan that is not running and tv shuts down instantly due to protection mode activation.
Please check exhaust fan and make sure its connector is plugged in and fan runs freely.
Thanks.
Apr 19, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
I have a 60" Sony
It seems lamp/ bulb popped again, check lamp inside tv.
If tv does not show red blinking light then it would be lamp that knocked off, replace lamp in tv to fix its problem, please buy Sony original lamp for good picture in tv.
Let me know if you have additional question.
Thanks.
Jan 15, 2011 | Sony Grand WEGA KDF-60WF655 60" Rear...
Red bulb lamp flashing and screen won't turn on. Just replaced lamp bulb with new one - didn;t fix it.
Please make sure lamp cover is fixed in its place securely, you know it was removed to replace lamp so put lamp cover back in its position and turn ON tv.
Hope this info will help you.
Feb 18, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony wega won't turn on
It sounds like it is the ballast. The ballast is what fires the lamp, if it is faulty, it will continue to blow out the lamp. The fan cooling could also be the issue but the TV will usually turn itself off if the fans are not spinning at the right speed.
Oct 06, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
My sony wega 60 inch tv will not turn on. The
I bought a new blub for it and the light still goes green then red.Anybody know?? mg
Sep 02, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Replace bulb tv wont turn on
make sure the lamp and lamp door are seated properly. does it blink any codes. 3 blinks is lamp or lamp door not seated properly
Jun 25, 2009 | Sony KDS-60A2020 60" HDTV
Picture cycles off and on
I replaced a burned out xl-2000u bulb with an after-market Philips bulb on my Sony KF60XBR800. After a fews weeks, I started experiencing intermittent black-outs with the "stand by" red light appearing. After a couple weeks it became intolerable. I then purchased an OEM Sony lamp and the problem has been gone for months. I read somewhere that the Sony circuitry monitors either resistance or watts and shuts the thing down for board protection. It was said that it is so sensitive it can can use only the Sony bulb. I'm a believer. If the bulb is going bad, i wouldn't doubt the protection circuit can kick in.
,,,,Pat
Nov 21, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Tv will not power up - makes a weird noise and red light blinks constantly.
It sounds like a bad lamp, a bad lamp driver or a combination of the two. Be aware that sometimes a bad lamp driver will blow a perfectly good lamp, so if you're not sure which is causing the problem, replacing BOTH would probably be the best course of action
Sep 30, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony kf-50XBR800 tv turns itself on and off
I just purchased a replacement lamp off ebay and the TV is working fine now. Color looks better too (which I guess I should have expected). Search for "REPLACEMENT LAMP SONY XL-2100U" on eBay and look for seller "niosales". I paid $129 out the door. Their are other auctions for this lamp you can check out. Make sure you look at lamps that include the entire lamp housing, not just the bulb.
Jan 24, 2008 | Sony Grand WEGA KF50XBR800 50" Rear...
Sony Grand WEGA KF60XBR800 60" Rear Projection Television Logo
209 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
