Question about Olympus EVOLT E-500 Digital Camera
Card error, no card inserted
A "card error" message is displayed on the screen, even with no card inserted.
the message appear with all the cards used, even new ones,  the camera doesn't function, only the display menus.  I try to format the cards, but the camera did not respond, don't allow to format them.  I connected the camera to the computer, the computer cannot read from the card through the camera, but can read from the card itself when inserted in the card reader.  I try to update the camera with a new firmware, I did it, but the problem persists.
any help or solution. It is out of waranty.  thanks!
  • cougar01 Oct 23, 2007
    Yes it does.  The card error message is displayed with any card inserted,both xd and cf.
    Novelist:
    Champion:
  • 244 Answers
It is possible that you camera having trouble to the card port. If you are familiar disassembled camera you need to use a circuit tester. Try to resoldered the card port on your camera just to insure the connectivity working.
Just ask near electronic shop to resoldered the card port if you are afraid to avoid damage to your camera. Sometimes this because of a capacitor could no longer supply value of voltage inorder to detect the card.
I don't beleived that this was not affected with a viruses because as what you stated you can used the card through card reader with computer. So that mean's the internal problem is from your camera.
Please let me know any update.
Posted on Nov 30, 2007
  • Cheater Cheater Nov 30, 2007
    I also added to clean up the card port of the camera since ussually we are often to insert card to it and that's possible some dirty thing was also inserted. You can buy a liquid fuil ussually used to clean electronic part which will evaporate right aways to avoid short circuit of your devices. Hope this will be helpful.
SOURCE:
Insert sim card
Do you want to insert other network sim or if your Blackberry Curve 8350I displaying insert sim card,if already sim card inserted.Don't worry i will help you.You can insert other network sim card in the phone by unlocking the phone from current network lock.To unlock Blackberry Curve 8350I use unlock code.Visit the site Wickedunlock.com get unlock code and unlock it easily.Then insert any GSM network sim card.If the phone displays insert sim card even though sim card is already in the phone.Please remove the sim card and replace it correctly.It is because the phone didn't detect the sim correctly.After inserting if it is display invalid sim or sim not valid message on the screen.It is locked to some network,you need to unlock it.To unlock use unlock code.Get code from online site and unlock it.
Jul 30, 2013 | Blackberry Curve 8350i
PHOTOSMART 2575 DISPLAYS "MEMORY CARD
Insert a memory card (in my case a SD CARD) and SLOWLY extract card until error message clears and normal screen images appear.I had to do this several times but it worked for me but cannot guarantee it will for everybody.GOOD LUCK.
Jun 10, 2011 | HP Photosmart 2575 All-In-One InkJet...
''Unable to display this image'' error on Pentax Kx
Sounds like some of the spaces on the card are becoming corrupted. How do you download? With the camera and USB cord, card inserted into reader on computer, or card inserted in a separate card reader? When you are finished downloading, do you use the "safely remove hardware" icon at the bottom right of your computer screen or do you just yank out the cord or card thereby causing the corruption?
Feb 11, 2010 | Pentax Kx Body Only Digital Camera
My Blackberry Curve 8330 won't format a media car
From the Home screen of the BlackBerry smartphone, click Options > Media Card or Options > Advanced Options > Media Card.
Display the menu and click Format Card.
  • some times Format Card option does not appear on the menu, skip the step and perform the procedure that follows.
  • A warning message will appear asking if you are certain you would like to format the card. Click Yes to continue.
    If the Format Card option does not appear on the menu, complete the following steps:
  • On the Media Card screen, set the Mass Storage Mode Support field to Off.
  • Display the menu and click Save. The Media Card screen closes automatically.
  • Click Media Card to reopen the Media Card screen.
    To format the media card, display the menu and click Format Card.
Nov 03, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
The card is locked appears on screen when SD card is inserted
Is it possible for you to use some tweezers and adjust the very small lever inside the camera's card bay? It may be stuck thus telling the camera the card is locked.
Aug 27, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
How to use the memory card reader
To access the memory card reader without using the software provided, follow the steps below. If no card is inserted, the green light on the card reader will be on.
Insert a memory card.
• Insert the card with the brand name label facing up.
• If there is an arrow on the card, make sure it points toward the printer.
• If needed, make sure you connect the memory card to the adapter that came with it before inserting it into
the slot.
Wait for the light located to the right of the slots on the printer to come on. The light blinks to indicate the memory
card is being read or is transmitting data.
• The printer recognizes one memory card at a time. If you insert more than one memory card, a message appears
on the display prompting you to remove all memory cards inserted.
• If a USB flash drive is inserted together with the memory card, a message appears on the display prompting you
to choose which memory device to use.
When reading of images is complete, the number of photos found appears on the display. Then you can make your selection and print. these are the types of memory card supported by you printer.
xD-Picture Card
• Secure Digital (SD)
• Secure Digital High Capacity (SDHC)
• Mini Secure Digital (with adapter)
• Micro Secure Digital (with adapter)
• MultiMedia Card (MMC)
• Reduced Size MultiMedia Card (with adapter)
• MultiMedia Card mobile (with adapter)
• Memory Stick (MS)
• Memory Stick PRO
• Memory Stick Duo (with adapter) or Memory Stick Duo PRO (with adapter)
Mar 18, 2009 | Lexmark X5495 All-in-One &USB...
Card error even with no card inserted
I've had the same problem. No pins are bent and I bought the new cards as well. Write protection is off. Hmm... Olypus wants $190.00 for a flat rate repair at one of their facilities.
Had 1.5 years of good use out of the camera. Do I do the repair or buy the 510?
Nov 09, 2007 | Olympus EVOLT E-500 Digital Camera
"Memory card is locked
This error message means that the memory card is write-protected. To take a picture, turn off the camera. Then insert a new card or change the storage location to internal memory.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
The camera screen displays error message
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card. CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card.
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Olympus EVOLT E-500 Digital Camera Logo
96 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
