Question about Sony Audio Players & Recorders
My Stereo Is Always On Protect Can It Be Easily Fixed
MY Sony MHC RG55 Is Saying rotect Can You Help
    Problem Solver:
  • 12 Answers
Protect occurs when 1 or more of your speaker wires is touching somewhere. Power off the receiver, connect speaker wires to receiver and speakers again, power back on, should fix the issue.
Posted on May 28, 2009
  • Sony Master
  • 19,396 Answers
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
Posted on May 27, 2009
SOURCE:
What's your question? my Sony stereo MHC-GZX550 , says protect eo3 or protect the echo?....pls help
Something short circuit inside the circuit board of your set. Short circuit protection energized. Contact any service technician to get it serviced. If you wish to get some details; check the site linked here. Pull up older posts.
Aug 03, 2016 | Sony Audio Players & Recorders
"Protect" Blinking on Sony Stereo
may i see a diagram showing where the ic goes?
Nov 03, 2012 | Sony Mhcec909ip Mhc-ec909ip Mini Hi-fi...
It keeps saying protect when i turn up the volume
The stereo is not letting you turn the volume up enough to damage the speakers. That's all. It's a nice feature.
May 09, 2011 | Sony MHC-RXD9 Shelf System
How to reset my sony mhc-gs100??? it keep saying power protect...
Your stereo went into protect mode to prevent complete failure of the amplifier inside that radio. Most of the time this happens from playing the stereo real loud for a real long time and it overheats. Most of the time disconnecting the receiver/stereo and letting it cool all the way down or at least 5 minutes and then reconnecting it to the power source will reset the protection mode. You want to make sure you are keeping the radio cool. Don't stack anything on top of it and try keeping a small fan blowing on it to expedite the heat out from the unit. Also turning it down every now and then to let everything cool down a bit will help prevent it from going into protection mode as well.
Mar 24, 2011 | Sony MHC-GS100 CD Shelf System
Sony Mhc GS100 want power up
The unit is in protect mode because a problem was deteected in the final output stage of the amplifier. The pop in the speakers is a god indication that there is DC current in the output stage. This is not a good thing. This is a relatively common failure of all receivers and can easily be fixed by any shop that does audio repair. Expect a parts cost in teh $30-$40 range.
Dan
Aug 19, 2009 | Sony Audio Players & Recorders
My stereo system blinks PROTECT on the screen
one of the out put tran is short ,
there normaly 4 to 8 of them
screw to a big heat sink ,
easy to get to.
check with a volt meter
then google the part
they cost 8.00-12.00
Mar 17, 2009 | Sony MHC-EC98Pi Shelf System
Press Power Protect
Always be solved replace him the audio amplifier IC
Dec 30, 2007 | Sony MHC-GS300AV CD Shelf System
Sony 60 cd changer mhc-gs300av
The audio amplifier IC is damaged and need to be replaced
Nov 21, 2007 | Sony MHC-GS300AV CD Shelf System
MHC-GS100 Shelf system
to restart, press stop, clear and display at the same time.
Nov 21, 2007 | Sony MHC-GS100 CD Shelf System
964 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
