Question about Ariston Technologies Ovens
Loud droning noise from fan.
I have a loud droning noise when the oven is on. The noise is coming from the fan. I opened the back and sprayed WD40 on the spindle and it stopped for a bit but it is back again very quickly. Ive read on websites that it may be the bearing but I think you have to buy the whole motor. Any ideas what this noise could be please?
  • pwimpenny May 27, 2009
    Is this something I could do myself or would you use an expert. (eg special tools) How long would it take please.
    regards phil
  • Ariston Tech... Master
  • 3,463 Answers
You are correct in assuming that is a noisy fan bearing, only solution is to replace the motor complete unfotunately.
Please rate my advice.
Thanks.
Posted on May 27, 2009
It is making a loud noise as if it is catching onto something it comes and goes sometimes louder than first time it started
I'm guessing your problem is the fan in the oven. To fix: 1. with oven cold, remove back wall fan cover in oven. 2. remove fan. 3. clean and lubricate. 4. install fan. 5. install fan cover making sure fan is not touching. If cover does touch fan, gently bend cover away from fan and install.
May 15, 2016 | Ovens
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
Beko double oven the fan has started to make a loud noise and sometimes cuts out had oven 18 months
by loud noise do you mean squeeling squaking .
then its the fan bearing just order another fan motor.
Jul 25, 2014 | Ovens
My new world double oven fan makes a loud noise and now the large oven does not heat up
Newworld model 444447289 made a loud bang and doesn't come on. The top oven oven is ok. What could the problem be
Oct 11, 2013 | Ovens
My whirlpool oven (model rbs305) makes a loud noise whenever it is on. I can't figure out if it's the fan, or just extremely loud.
I would suspect that the blower is noisy its what i would expect to potentially make noise ...if fits in the back of the control panel and it comes on to cool the control board each time the oven is on.
In case it turns out to be the blower thats noisy the part number for it is W10176670
GENE
Sep 10, 2011 | Whirlpool RBS305PD Electric Single Oven
My AEG competence oven is making a loud buzzing noise coming from the top fan? The food tonight was either burnt or under cooked? The buzzing is also loud when switched off/cooling down? Any ideas please.
I would suspect that the problem is caused by the external cooling fan located under the outside cooker cabinet housing, which continues to operate as the oven is cooling down if it is built in, you will have to remove it from the oven housing to access the fan
Dec 12, 2010 | AEG D4101-4 Electric Double Oven
Whirlpool double oven has a loud fan when baking
There will be some noise from the fan, but it should not be excessive, if it is really loud, then this is an indication that the fan is failing, and should be replaced ASAP.
Mar 12, 2010 | Whirlpool RBD305PD Electric Double Oven
Bosch oven loud fan noise
JUST REPLACED BOTH FAN MOTORS ON A DOUBLE BOSCH 755. DIDNT HELP MUCH.THE FAN IS LOUD COMPARED TO OTHER BRANDS.UNLESS YOU NOTICE A DRASTIC CHANGE IN NOISE, DONT WASTE YOUR MONEY ON A NEW FAN MOTOR.ITS JUST THE WAY IT WAS MADE.
Nov 26, 2009 | Bosch HBL 445 Stainless Steel Electric...
Fan making loud noise
Hi
does the noise start as soon as you turn the fan oven on?
does the noise stop as you turn off?
just depending what make and model you have there is two fans
in it 1 is the fan motor inside oven at back and other
is the cooling fan which is at top of oven .you just need
to find out which one it is and just replace . then should be back to normal
regards dan
Mar 19, 2009 | Belling XOU174 Electric Single Oven
Odd loud fan type noise
what you are describing is the cooling fan. That fan will come on to keep the electronic control panel cool. It is normal for tat to come on even if your done with the oven. I dont think is should be as loud as you describe. I would try the oven again and if it is still loud I would call for service because it is new. That fan will also come on when you use the self clean cycle.
Jul 25, 2007 | Frigidaire PLEB30T9DC Electric Double Oven
Ovens Logo
727 people viewed this question
Top Ariston Technologies Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you an Ariston Technologies Oven Expert? Answer questions, earn points and help others
