Washing machine went bang and wont work. The plug fuse is fine and the washing machine light comes on but it wont work
My washing machine was in spin cycle then it made a noise like a light bulb had blown and stopped working, i checked the plug fuse and that is fine and the washing machine on light is on.but it just wont work. What is the cause and what will i need to replace to fix it? Please help.
Changes are you broke a "drive belt".
It snapped causing the noise.
Lift the top up (easy if you pry a bit on each corner).
You will see the broken belt.
Remove the old belt and take it to a shop to make sure you get an exact replacement.
Threading the new belt can be a tiny bit confusing but it will soon become obvious.
It is like the "fan belt" in a car.
Posted on May 27, 2009
    Scholar:
  • 174 Answers
It should be the machine that has died. If you're unsure you can do it, call your appliance store's technician. Do not open it esp. if it's covered by a service warranty. It will become void if you do. I had the same experience before and the technician really took out the machine and brought it back to their branch office.
5 Suggested Answers
  • 188 Answers
SOURCE: Kenmore 80 Series washing machine - loud banging at end of spin
With the lid open, set the cycle to spin and press the lid switch button with a pen. Wait until the drum gets to full speed and release the lid switch. If the drum makes a knocking/ thumping noise and doesn't stop spinning within 2-3 seconds, the basket drive block is worn and needs to be replaced. (The basket drive block is located on the gearcase drive shaft, under the tub and agitator) If this has been happening for a long time you may need to replace the brake and drive tube assembly as well.
Basket drive block part number is 389140
If that's not it, let me know and I will try to help you further.
Posted on Mar 10, 2009
rylee_smith
  • 8619 Answers
SOURCE: loud banging noises
Hi!
The reason of this noise is from loose lower front weight mounting bolts or a loose bolt securing the driven pulley. Check the motor adjustment bolt for tightness. The noise could be from a loose wire harness, plastic purse-lock wire harness retainer on upper hose hitting the top cover or a plastic injection mold standoff on the outer tub bearing housing may possibly be interfering with the driven pulley. Also, check the drive belt for a weak spot on the belt. Ussually felt on the backside of the belt as a "flat" spot. Check the belt for a weak seam and replace it.
It may also occur due to the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on May 06, 2009
  • 2976 Answers
SOURCE: Machine makes loud banging noise during the spin cycle
The load is out of balance. Open the lid and redistribute the contents. When it's empty, grab the basket and give it a slight push sideways. It should move a little but, not free swing. If it doesn't have much resistance, the "snubber" has dried out and should be replaced. It is simply a piece of rubber in a metal bracket, that rests on the tub. When the basket spins,the snubber keeps it from jumping around.
Posted on Aug 31, 2009
kel1guy2002
  • 3740 Answers
SOURCE: loud banging noise during washing cycle. Sounds
Grab the agitator at the base and attempt to rotate it clockwise and counter clock wise. It should remain firmly in place. If there is movement the agitator spline is worn.
This is your Agitator:
http://www.repairclinic.com/Appliance-Parts?s=t-WBSR3140DW-%3d%3dc201
It does not come with the fabric dispenser. It has to be ordered seperately. You should be able to transfer you old one to the new one if you do have to replace the agitator.
Besides the agitator the drive bell can also be the source of the noise. It is located under the agitator.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-WBSR3140DW-%3d%3dc239i1195917&PartID=1195917
This part is the most likely cause of the noise.
Thanks for using FixYa.
Kelly
Posted on Mar 07, 2010
Why does my front loader make a banging noise while spinning?
Ive checked thru the top and back cant notice anythin brohen but when i do spin tbe tub the banging noice is coming from in tbe drum and its pretty wobbley
Aug 28, 2015 | Washing Machines
Miele washing machine wont spin or drain
clean your filter first then check there is nothing in the pump area
Jan 22, 2014 | Miele Washing Machines
Washing machine loud bang, now no water
you could have a broken or clogged bump,as far as the latch not opening it could be slightly off line
Nov 05, 2009 | Washing Machines
My hotpoint aquarius front loader has power but wont work.
Most likely the Door interlock is faulty or has fallen apart (through the banging of the door)
Aug 21, 2009 | Washing Machines
Water not draining although spin still ok. Then went bang!
Called out a plumber who diagnosed that the machine was not worth mending. He charged me £25. Now have new Indesit WM.
May 23, 2009 | Bosch Washing Machines
Kenmore Washer Tub banging on fast spin
there are some springs that help hold the tub even as it spins also make sure that the washer is level check front to back side to side and corner to corner if it is unlevel they will be out of balance in high speed spin
May 07, 2009 | Kenmore 23822 Top Load Washer
Washing machine wont spin
Your machine may not be receiving adequate voltage to start. Make sure your machine is plugged in. Also, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Or check to make sure no fuses in the fuse panel are blown. Try plugging something else into the same outlet. If it won't work either, then there is likely something wrong with the power outlet. Any of these could be the reason power is not getting to your machine. Also, refrain from using an extension cord to plug your machine in.
Dec 03, 2008 | Indesit W 123 Front Load Washer
The spin bang all over the machine
is it actually spinning or jsut making banging noise. if just noise
sounds like a broken motor coupling( this machines equivelent to a belt. part number 285753a . mounts directly to the motor shaft and connects to the transmission, order a new one it installs between the motor and transmission,assy
Jan 16, 2008 | KitchenAid KAWS850LE Top Load Washer
Hotpoint washing machine
check cble whare it enters machine
Dec 04, 2007 | Washing Machines
Washing Machines Logo
761 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
