Question about UN 3000SW Radar Detector
Hookup I am not using the rear detector; how should the wiring be done? Right now I am getting "beeps" every 10 seconds.
I need an installation diagram!
Posted on Oct 14, 2008
  • Giuseppe Sandolo
    Giuseppe Sandolo Mar 31, 2014
    Same problem here: Open the front unit, there are 3 wire going to the plug, cut wire on the plug and feed wires with a small hole to the outside of the unit where I install a plug. the wire color from unit are : red,black, blue. Sliced the wires from the control and this is where Im right now stuck: Green, Brown White, now what ??
Stop beeping alarm
You need to change the batteries. Get the newest get alkaline once it is in it may still beep until you press the test button for 10 to 15 seconds to reset
Nov 26, 2013 | First Alert SA302 Dual System Smoke...
My 521NCSXT smoke sector beeps periodically. What is required to repair?
When a smoke detector beeps periodically it is telling you that it needs a new battery. They require the newest 'alkaline' 9 volt battery that you can get. If it is not alkaline you will get the beeps. once the battery is replaced do a hard reset. (pressing the button for 10 or more seconds)
Sep 29, 2013 | GE 521NCSXT - Photoelectric 2-Wire Smoke...
Beeping sound and message" battery low""
All smoke detectors need batteries often. The voltage must be 1.5 volts higher than what the voltage says on the battery used. Also electronics these days are touchy that you only use alkaline. So buy a new brand name alkaline that hasn't been on the shelve very long. Never use a used battery from another device in the house. Never buy the cheapest deal battery from a dollar store etc. Once the battery is replaced press the test button for 10 to 15 seconds to reset all. If you don't press the test button it may continue to beep or warn you. If you press the button just enough to test the alarm it may not reset properly. The longer 10 to 15 second test usually solves all issues.
Sep 01, 2013 | Kidde Night Hawk Combination Smoke and...
It is beeping every 10 minutes or so. It's hard wired and doesn't seem to have a battery, so wonderng what the beeping indicates
most hardwired smoke detectors have a built in battery, and when they wear out the smoke detector will "chirp" about every 10 minutes. You are best off getting a new one . they last up to 8 years, but do get dirty or greasy.
Apr 03, 2012 | System Sensor 5602 194°f Heat Detector Ror...
My K40 unit keeps beeping 2X every 10 seconds or so.. It still goes off when radar is present but it wont stop beeping. any insights would be helpful
You have a K402000 radar system. The double beep is a rear receiver disconnect notification. If you go to the K40 website and access their dealer locator from the dealer section, you can find an authorized dealer to help you with this problem or you can call K40 directly and speak to them...they really are a great company to deal with.
Aug 20, 2011 | Calibre Radar Detector
My alarm is beeping every 30 seconds. i just changed the batteries
CO detectors have a limited lifetime of 7-10 years before having to be replaced. I don't know if yours are past their useful life or simply require cleaning. Try cleaning first, vacuuming.
Jan 13, 2011 | Kidde Nighthawk Combo Gas/co Detector
I have a gt-11 detector, my question is when i touch a 120 volt wire whith electricity on i'm geting a full beeping ( stable ) and what the meaning of touching another wire and get a continuel beep beep...
It is detecting Residule voltage off the hot line, your common/Neutral should have no voltage. One thing I have noticed when using many non contacts if you are Holding a live wire (on the insulation)
I have gotten false readings (continous beeps) from the non-contact when checking neutral lines. Unsure as to why but something I have came across when trying to seperate wires while testing.
Nov 29, 2010 | Greenlee GT-15 Non-Contact Low Voltage...
Kiddie fire alarm model I12060, beeps once every
This happened to me, my smoke detector started chipping so I changed the batteries. A few seconds later it started chirping again. The answer is in the way you put the batteries in. The smoke detector allows you to put the batteries in wrong and makes a slight connector. This slight connector tricks the detector into thinking the batteries are weak. Simply turn the batteries around so the fat connector of the battery touches the skinny connector of the device. Mine was, fat side on the right.
Jan 28, 2010 | Kidde i12040 Hardwire Smoke Alarm with...
I have a k 40 stealth mounted radar unit - it keeps faulting and giving me beeps like every 30 secs
if the beep is one beep every 30 secs then the front radar detector is defective. If it beeps 2x every 30 secs the rear radar detector is defective. If under warrantee you are good. If not, take to any dealer and cost $225 to get it replaced.
Dec 15, 2008 | 2000P Radar Detector
UN 3000SW Radar Detector Logo
301 people viewed this question
Top K40 Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a K40 Vehicle Part and Accessory Expert? Answer questions, earn points and help others
