Question about Kenmore Washing Machines
F35 code appears, even after changing the steam chamber.
I have the Kenmore Elite HE5t, Steam Washer and Dryer. I'm having issues with the washer, it keeps giving me an F35 code. The sears tech came out and stated that the steam chamber is no good and must be replaced. I replaced today and the code still appears. I don't know what else to think. Any good advice!
IT IS THE ANALOG PRESSURE SENSOR NOT THE STEAM CHAMBER.
Posted on Jul 06, 2009
I have a Kenmore He5t steam washer. I got the F35 code again, so I automatically ordered and replace the pressure switch again. did not fix the problem. I have checked and cleaned the drain basket and
Unfortunately you spent money unnecessarily, and before making any additional errors; it would be best to have a trained technician with knowledge of the washer, service the system.
Jan 18, 2015 | Kenmore Washing Machines
Kenmore elite front load washer model 46752701 after replacing pressure control switch i still get f35 code
Most common cause for the F35 error code: Using non-HE detergent. Detergent slime builds up in the hose, eventually getting into the analog pressure switch and killing it. Make sure you flush out as much soap as possible and make sure to use HE soap or it can keep occurring, also some vinger can calm down the suds
Oct 26, 2013 | Kenmore Elite HE3 Steam 8674 Dryer
I have Kenmore ELite HE5t Model 110. I keep getting an "F35" code and washer does nothing....even pushing the "Stop" button doesn't work..door will not unlock...I have to turn off breaker to open door.
Hi, we also got the SUDS error followed by F35 many times. I replaced the analog water level switch, Wirlpool part number W10156252, and the problem went away. The part is located against the back right corner of the top of the washer after removing the top cover. The part cost $62.99 + $12.95 express shipping from ApplianceZone.net. I have the Kenmore HE3t Steam Washer, model number 110.46752 700 front loader. I was able to run about 6 loads of laundry by unplugging the washer, waiting about 5 minutes, the re-plugging and re-starting the washer. Thereafter, the problem became permanent. I always used HE detergent. The washer was purchased new in December 2007, and the I made the repair in September 2009. I spent about $1300 for the Kenmore H3t Steam Washer, and I am disappointed that it required repair after less than 2 years. My mothers old Maytag washer lasted more than 15 years, and was not susceptible to soap SUDS.
Oct 05, 2010 | Kenmore Elite HE5t Washer
My Kenmore Elite he5t steam washer gets F35 error code
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%
Feb 21, 2010 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite he5t steam washer is about 2yrs old. I am now consistently getting either "Sud" code or F35. Is there a part for the F35 that needs to be replaced? If yes, could you let me know as well as...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^@$$
Sud and f35 error in my kenmore elite h5 steam washer. The washer do not wash the cloth and flash F35.
I got the f35 and suds code repeatedly and my clothes weren't washed, I ordered from Sears the analog pressure switch that regulates the water coming into the washer and the codes went away, the part is esitmately $125.00 including shipping but you have to order from the Sears parts department.If you print a diagram of the washer it is #38 in the diagram and is easy to replace. You can install it yourself and as a female I did not call service to do it.
Jan 17, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he5t steam is locked & display says f35. What does that mean?
Sep 06, 2009 | Kenmore Elite HE5t Washer
How do I prep my Kenmore Elite He5t washer for move to new house
Washers n dryers usually require some balancing after a move to the new area, and when you lift the washer on a dolly, you lift it from the rear. Assuming you've already tipped the washer slighlty to one side, checked the bottom for which side has the most metal underneath. This is best done with 2 people. Do the same with the dryer. The braces are used to help balance or to keep from tipping when the machine was packed inside a large box.
May 23, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
F35 Message on Brand New Washer
suds is determined using the level sw located on top right rear side. remove top cover to see. most letter codes do convert to a f code. most common reason for suds error is use of standard detergent or too much detergent. running a empty load of fabric softener can clean the system. or rinse/spin with nothing. other common problem is this is a whirlpool product.
Dec 01, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
737 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
