Question about Intel Desktop Board D845WN Motherboard
D845WN mobo--USB 2.0 doesn't work i can activate the usb 2.0 .In the intel page says waws in the bios in advanced-usb configuration but in my bios doesnt appear
  • ikkenom May 11, 2010
    Does the motherboard manufacturer's web-site have any 'FAQ' ("Frequently Asked Questions") on this topic?
    Are you using the most-recent BIOS -- again, check the web-site for a newer BIOS, which may enable the USB 2.0 ports.
    Does the web-site have any "motherboard-drivers" that are specific to your motherboard?
  • 2,567 Answers
Solution to your problem is at the following URL:
http://support.intel.com/support/motherboards/desktop/sb/cs-009024.htm
If this does not work, then update your BIOS. You can download it at:
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=664&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go!
Updating the BIOS might help resolve the problem.
Posted on Jul 10, 2009
Motherboard specification
Intel 865GV Chipset Pentium 4 Main board,
Supports Prescott CPU
FSB800, DDR 400, SATA 150 Specifications
arrow_bullet.gif CPU
  • Supports Intel Pentium 4 Socket 478 processors(Prescott and Northwood) with 800/533/400MHz FSB
  • Supports Intel Hyper-Threading Technology
arrow_bullet.gif Chipset
  • Intel 865GV/ ICH5
  • Integrated Intel Extreme Graphics 2
  • Supports Advanced Configuration and Power Management Interface (ACPI)
arrow_bullet.gif Memory
  • Two 184-pin DIMM sockets
  • Supports 2 DIMM Single/ Dual Channel DDR 400/ 333/ 266 memory (Max. 2GB)
arrow_bullet.gif Graphics
arrow_bullet.gif SATA 150
  • 2 channel Serial ATA 150MB/s data transfer rate
arrow_bullet.gif Audio
  • 6-Channel AC 97 CODEC on board
  • Professional digital audio interface supports optical S/PDIF Output
arrow_bullet.gif System BIOS
  • Supports Plug-and-Play (PNP)
  • Supports Advanced Configuration Power Interface (ACPI)
  • Supports Desktop Management Interface (DMI)
  • Write-Protect Anti-Virus function by AWARD BIOS
arrow_bullet.gif LAN
  • On board 10/100Mb LAN
arrow_bullet.gif Internal I/O Connectors
  • 3 x PCI slots
  • 1 x Floppy Port supports up to 2.88MB
  • 2 x Ultra DMA 33/66/100 Connectors
  • 2 x Serial ATA 150 Connectors
  • 2 x USB 2.0 headers (Each header support two USB 2.0 devices)
  • 1 x CD-IN, 1 x AUX-IN
  • 1 x FP-Audio header
arrow_bullet.gif Back Panel I/O
  • 1 x PS/2 Keyboard, 1 x PS/2 mouse
  • 1 x Parallel Port, 1 x Serial port
  • 1 x VGA Port
  • 1 x Audio connectors (S/PDIF Out, Surround Out, Center/Sub, Lin-out, Line-in, Mic)
  • 4 x USB 2.0, 1 x RJ-45 LAN Connector
arrow_bullet.gif Miscellaneous
  • Micro ATX form factor (244mm*234mm)
  • Hardware monitoring - Including Fan speeds, Voltages, System environment temperature
    hope this helps
Jul 07, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Hi sir; I have a pc with intel d845wn mother board.It is not supporting usb 2.0.What can i do
You may be able to upgrade the BIOS firmware so it can support USB 2.
You can download the motherboardBIOS upgrade and device drivers from Intel WEB site. Select your
model motherboard/device, andmake sure you select the Windows XP or Vista version of the drivers
thatmatches your Windows operating system. Please click on this link andselect your model motherboard : - http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr
Apr 29, 2011 | Intel Desktop Board D845WN Motherboard
Hello, I have updated BIOS of Intel 845 GVSR board. But after the successful update USB is not displayed in BIOS hence no USB device is getting recognized. Please help.
Had exactly the same problem. This process fixed it for me:
http://www.intel.com/cd/channel/reseller/asmo-na/eng/tech_reference/box_processors/int_inst_info/factory_notes_all/203939.htm
  1. Shut down the computer safely and remove the chassis cover.
  2. Move the BIOS Configuration jumper to the Maintenance position. (Refer to the Quick Reference Guide or Product Guide for the location of this jumper.)
  3. Power on the computer and enter BIOS Setup (press F2 during boot).
  4. Go to the Advanced > USB Configuration menu.
  5. Enable the USB Function.
  6. Go to the Exit menu and select Save Custom Defaults.
  7. Save and exit the BIOS setup.
  8. Turn off the computer.
  9. Move the BIOS Configuration jumper back to the normal mode position.
  10. Power on the computer and enter the BIOS Setup again to verify that the Advanced > USB Configuration menu is now back to normal.
Jan 06, 2010 | Intel Motherboard
How to enable usb 2.0 in my d845wn board??
of course you need usb 2.0 ,if you wanna test ask a friend to lend one stick and try it should work
Nov 25, 2009 | Intel Desktop Board D845WN Motherboard
Ver, very SLOW when booting up! Sometimes the
BIOS System defaults are best used for installing a new operating system or performing diagnostics. Bootchecks and memory checks due to settings on antivirus/antispyware programs are notorious for causing slow boots. In most cases these scans are unnecessary. Saying that, it is also possible you have acquired a trojan. Run a full system scan and if you have a clean machine, disabling the bootchecks and memory checks will speed up your booting. If after doing this your boots are still slow, tweak your BIOS as follows per Intel:
  • Set the hard drive as the first boot device in the boot order in the BIOS setup (Boot > Boot Device Priority menu).
  • Enable Intel® Rapid BIOS boot in the BIOS setup (Boot menu).
  • Disable Hard Disk Pre-Delay in the BIOS Setup (Advanced > Drive Configuration menu).
  • Disable system functions and features if you do not need them. Examples include:
    • Legacy USB - this must be enabled if you use a USB keyboard or USB mouse outside the Windows* environment (Advanced > USB Configuration).
    • Unused I/O ports, such as serial, parallel and IEEE-1394 ports (Advanced > Peripheral Configuration menu).
    • Event logging (Advanced > Event Log Configuration menu).
    I hope you find this solves your problem. All the best! Greg
Nov 10, 2009 | Intel D845GVSR Motherboard
I have a P5WD2 Asus MoBo, manual says it has USB 2.0 but when I check my hardware I dont see any enhanced USB controller
OK, I downloaded the latest Intel Chip configuration utility, then rebooted and enabled USB 2.0 support in the Bios. This seemed to fix the problem as the Enhanced USB controller now shows up in my hardware.
Jul 21, 2008 | Computers & Internet
BIOS settings to boot from bootable USB Key
Hello
Here is a link for your motharboard manual
ftp://download.intel.com/design/motherbd/mv/A6514501.pdf
Your needs are in page 113
AYADI
Apr 08, 2008 | Intel D850MV Motherboard
Update my Intel D845GVSR Bios Version to VA84510A.86A.0056.P20, then my USB driver is not working at all.
I followed the suggestion of changing the BIOS configuration to the recovery mode, however one thing was missing - it required a startup disk and I didn't have one. I then changed the BIOS configuration to the config (pins 2 & 3) mode, booted up and went to the BIOS/CMOS setup and a new menu tab appeared called "maintenance". I went to the advance tab and selected USB configuration and, instead of a blank screen, there appeared a selection for USB support and it showed disabled. I changed the setting to enabled and three more lines of information regarding USB came up, but required not further changes. I went to F10 and saved and exited and I now have me USB capability back.
Mar 10, 2008 | Intel D845GVSR Motherboard
USB2.0 to work
In the CMOS setup, on the Advanced tab, USB Configuration, enable "High-speed USB", according to this page. The instructions there may not be the same as yours, as Gigabyte may be using a different BIOS. On this page is the latest Intel INF Update Utility for your Intel 845 chipset.
It is also possible that your motherboard does not support USB 2.0. The manual I saw was suspiciously quiet about it.
Dec 06, 2007 | Gigabyte GA-8IRX Motherboard
Still Doesn't Work
You needed to configure bios (F2) when you first installed the processor,
now the Bios hangs before anything can happen,  You need to remove the Bios Battery (looks like a coin on the mobo) for about 30 secs (with the power disconnected)  then re-insert the battery and power on.
you should get the same power on message as you did the 1st time (maybe with a missings settings error too but this is expected)
Enuro12 is right about legacy USB in that your keyboard should work in BIOS (setup)
Oct 12, 2007 | Intel Motherboard
Intel Desktop Board D845WN Motherboard Logo
458 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
