Question about Epson LX-300+II Matrix Printer
Can print correcly
My printer appeared unknown word when printing after i change the printer parallel port cable to usb converter cable ... my printer was Epson LX-300+II ... thx for hu cn help..
  • 66 Answers
Plz check all the settings, language setting must be check , after that if the problem not solved then uninstall the driver and again reinstall the printer driver
Posted on May 27, 2009
I have an old serial printer that works fine, I can not connect it to my new computer via a parallel to usb cable convertor on windows 7!
Hi craig931, First try downloading the latest driver of your printer and your usb converter compatible for windows 7. Second Checked your device manager if your printer and usb to parallel driver properly installed, it should be there. If not yet installed try using different usb port one at a time until the cable have been detected. Third if you see already the printer port force to change it to USB001 or Com1, then try to print. regards,
Sep 26, 2011 | Office Equipment & Supplies
Hello, My laptop died, so had to get a new one. Unfortunately now I can't get to the printer which is attached to my D-Link Dir 450 because I had the WEP or whatever fancy connection and don't have the...
Hi James,
It sounds like you're halfway there. You now need to find out the IP Address that the USB convertor box is using by going into the D-link router. Note it down (including the dots separating them) and then go into the printer poperties of the printer on your laptop. (Sorry I don't which operating system you are using so I'm going to have to assume that you know how to do this. If not, drop me a line.)
Click on the Ports tab.
Click on the Add Port.. button below the list of ports
In th window that pops up click once to highlight the Standard TCP/IP Port option and click the New Port.. button underneath the selection box.
A wizard will appear. Click Next.
In the next window enter the IP Address you noted from the router noting the dots between the numbers in the Printer Name or IP Address box. (Note that the Port Name box will autofill.)
Click Next (you may have to wait a moment for the settings to take effect).
Another windows will open and the default selection is Generic Network Card. (Leave it as is and click next.)
The finish windows will appear. Check the settings . The defaults are as follows:
SNMP: No
Protocol: RAW, Port9100
Device: (The IP Address that you enterred earlier)
Port Name: IP_(The IP Address as above)
Adapter Type: Generic Network Card
Click Finish and get back the pinter properties page at the Ports tab.
Check that there is a check mark next to the port you have just created (i.e. IP_(IP Address you enterred earlier)
Click Apply and OK.
Return to the properties and print a test page.
Let me know how you go. Cheers.
Dec 17, 2010 | D-Link DIR-450 Router (DIR450)
I have an HP LaserJet printer 4050N with RJ45 and Parallel Port. The Printer is kind of far from the WireLess router and I can't connect it. Unfortunately, my PC doesn't have a parallel port. The best...
Another option is to find an old laptop, with "wireless" capabilities and a Parallel Port.
Connect the printer to the laptop.
Connect the laptop to your wireless network.
Tell the laptop to "share" the printer.
Then, any computer on your network can "find" the networked printer, and can print to it.
Jun 12, 2010 | HP LaserJet 4050 Printer
It is possible to convert the cable of lq-2180 from parallel to sb cable?
No!
Are you trying to connect your printer to a PC using the USB port?
If so, it would be far better to purchase a USB to Parallel port cable.
The data passing over the USB cable will have to converted from a serial format to a parallel format before the printed can store the data,
Next, the converted has to add the required control signals in order for the printer to read and latch the data.
Don
Apr 18, 2010 | Epson LQ-2180 Matrix Printer
Can not print with Epson LX-300
The USB to parallel converter does not always work.
You should buy a Parallel port for your computer if you have can extra slot inside the machine. The cost for the parallel port is usually under $20.
thanks adi
Oct 03, 2009 | Epson LX-300+ II Matrix Printer
USB to Parallel connection (Panasonic KX-P1121)
I would recommend buying a Printer parallel port connection (PCI to LTP1), install it into the system, and use the printer parallel cable.
Sep 02, 2009 | Nikon COOLPRINT Thermal Printer
Connecting a HP 4550 parrallel printer to a USB Laptop
in order for you to use USB on this printer. you need to get "HP175x jetdirect, USB to parallel" which is print server box use to convert USB to parallel print port fo rolder printers that don't have USB or use as multiple pinters for network.
price is around $70 USD.
Jun 05, 2009 | HP Color LaserJet 4550 Printer
Printer doesn't work when use usb parallel converter.
Forget about using parallel converter. Just use the USB cable it works best anyway.
Easiest way is this.
1: Turn printer on. (Green light. ready to print)
2: DISCONNECT the usb cable from the PC.
3 DELETE the Zebra LP2844 & Zdesigner drivers from the printers & Faxes folder. Just highlight them and hit the delet key. Don't worry Iknow what I'm doing.
4: Plug in your USB cable back into PC.
Just sit back and wait, your PC will automatically detect your printer and re-load your driver software.
Send me the cheque now!!
May 12, 2009 | Zebra LP 2844 Thermal Printer
Printing does not work on Xerox Workcenter XD125F
Does the printer show up when you unplug it from the USB port and plug it back in? Does it say New Hardware or Printer found?
Does it print from a parallel port or does your computer have one?
Unlikely the cable since I have used those on that product before.
If it will print from a computer parallel to parallel, I would suspect the cable obviously.
You can take the back off the printer and reseat the board, and connectors.
What happens when you popo the printer itself?
Jan 31, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
Epson LX-300+II Matrix Printer Logo
287 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
