Question about Toshiba Satellite Pro L300 Notebook
My satellite connects to the wireless system in our house via our mac airport, but internet explorer says cannot display web page
  • Toshiba Master
  • 4,806 Answers
Hi there.
Reset the wireless router and the modem by unplugging the power supply from the back of them for 30-60 seconds (do not terminate power at the wall because there is still a trickle charge in the wires), then plug them back in and wait for 2 minutes for them to reset themselves and try to reconnect.
Please post back with the results and for additional advice if needed.
Good luck and thanks for choosing FixYa!!
Posted on May 27, 2009
My Toshiba r15-s822 isn't connecting to a wireless network and the router I already installed the router to my pc even connected an internet cable to it but Internet Explorer wont open it keeps...
Try connecting to the Internet through the ethernet port (via a cable). If Internet Explorer loads the target page then you have a configuration problem with WI-Fi access : The wireless security settings are not allowing the computer to access the Internet.
If Internet Explorer does not connect with the cable then the problem resides with Internet Explorer. Try to reset the defaults. To confirm that download FireFox and use it. Besides you need two browsers just in case one acts up.
Jul 02, 2011 | Toshiba Satellite R15-S822 Tablet PC
Not connecting wirelessly to mac
Thank you for contacting Fixya Support, I am glad to assist.
Depending on what type of Internet service you are using, your Intel iMac comes standard with an Airport Extreme wireless card built in. As a result, if you are unable to connect wirelessly to the Internet, you will need to try this:
- Click on the Apple menu icon, located in the upper left corner of your screen and select System Preferences from the drop down menu.
- Now locate Network from within System Preferences.
- In the side window, make sure you see Airport and check also to see that it is turned on. If it is, then check the left side window to see if the AirPort connection is active.
Keep in mind, your modem or connection router of course, has to be able to provide wireless connectivity, otherwise, if you do not, there will be no need to try connecting via your AirPort Extreme card.
If your network has been physically set as a wireless network, then just turning on the AirPort card in System Preferences>Network will start discovering all networks within its range, including your own network.
So whether you are using an Airport Extreme, Express or a 3rd party (non-Apple-branded) router, you should be able to connect wirelessly.
If you are still unable to connect with these basic steps, here are a few articles you will need to review from Apple Support informational database:
Requirements for wireless Internet access with AirPort
Airport & Bluetooth interference (for connectivity issues)
So here are some basic steps and resources you can try.
If you have more questions please feel free to post a comment.
I hope this information helps.
Regards,
-Mactechtrainer
Aug 29, 2010 | Apple iMac Z0CY Desktop
Connecting Mac to new wireless router. Getting message: Safari cannot open page. Safari could not open the page "http://livepage.apple.com/" because the server is not responding. I'm not a normal...
Go to System preferences then under internet and network in the left hand column click on + sign at bottom of the column then under slect the interface choose airport click on create and then click on turn airport on and then select your network name and if a password is asked for put in the password.
If airport does not show up it probably means that your mac does not have a wireless card in it.
Hope this helps.
Nov 16, 2009 | Computers & Internet
Wireless internet connection
You need to set up a new log in code
Jul 20, 2009 | Dell Inspiron B130 Notebook
Not able to connect to internet via airport express
Have you checked your system preferences, network settings? You have to tell the mac to use airport or ethernet. It may be setup to use the hard wire and not airport. You should see a link to turn on airport in the upper right corner of your screen. I think you can turn airport on there.
Apr 03, 2009 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Cannot connect my Mac Pro to the internet via my Belkin wireless
With the router powered on, use a small thin object to press and hold the reset button for exactly seven seconds. The router lights will flash and this will restore the router to factory default. Connect your computer to one of the routers lan ports with an etherent cable. Open your web browser and navigate to 192.168.2.1. This should show the router status page with the default settings.
This will make the router unsecured again, so be sure to go back into setup and reset your Wireless security. I suggest using WEP authentication, and using a 10 digit ph # for your key (that way its easy to remember).
Dec 31, 2008 | Gateway 802.11g Wireless DSL/Cable Router...
I tried to set up HP Photosmart C4580 printer/scanner/copier with my Airport Extreme. However it is not connecting to the Airport Extreme. Diagnostic check recommends temporariiy disabling the Mac Address...
MAC address filtering is used to prevent unauthorised people getting access to your wireless network. you need to get into the Airport Extreme configuration using Internet Explorer or any other browser, then select wireless setup then MAC address filtering. You need to turn off MAC address filtering.
Check your manual on how to configure your Airport Extreme.
Dec 02, 2008 | HP Office Equipment & Supplies
Airport has signal
The airport has a wireless signal but its not supplied by your provider. In order to use wireless at the airpport you have to pay their provider too.
Your system can receive and send to the wireless network in the airport but usually when you have connected to their wireless network, once you open a browser (IE or Firefox) it will provide you with a sign up page where they want you to pay typically $9.99 for 24 hours of use of their wireless network, which you sign up for with a credit card.
So you should be able to recieve that page but you can't access the rest of the internet unless you pay them for access.
Sorry
Aug 14, 2008 | Actiontec GT704WG Wireless Router...
Airport connection - G5 Powerbook
Yes better get a new wireless card if there's a airport that can be connected via USB that will be better..
Good luck....
Jul 21, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Internet Explorer cannot display the web page
Could be a vista compatibility problem.
check Linksys website for updated driver and or connection manager.
check that you still have permission in firewall.
remove the software of the usb wireless adapter,reboot ,then re install.
just a couple of thoughts
good luck
Terry
Mar 26, 2008 | Compaq Presario 5000 PC Desktop
Toshiba Satellite Pro L300 Notebook Logo
78 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
