Question about Panasonic Toughbook CF-51 Notebook
Screen does not present full display
Displayfor lcd only fills up 3/4 of screen. tried adjusting resoluition, icons got bigger, still only 3/4 of screen filled
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    Is the machine XP or Vista?
  • 66 Answers
May be ur display & graphics driver not installed properly
Posted on May 27, 2009
Screen Positioning in HDMI LCD connections
When you say "Projection" do you mean a portable LED projector? If you mean an LCD flat panel display, then you will probably find the resolution you need is more likely to be 1440x900. But, just because your screen says 1366x768 doesn't mean the video output will fill the screen.
May 19, 2013 | Sony VAIO Computers & Internet
Hi, I have an LG Flatron w2343T and on a recent restart the screen resolution came up all distorted in that all the icons are bigger and my wallpaper photo is enlarged to the point that I can only see...
For some reason your screen resolution changed, to adjust it
Right click on a clear area on your screen, select Properties,
select the Settings Tab, Screen Resolution, adjust to the desired
resolution
Jul 13, 2011 | LG Flatron L2320A 23" LCD Monitor
My HP Pavilion dv8210us has white column that blocks out start and icons on screen, everything else I can see any ideas how to fix?
try displaying monitor on external screen. if it is present then it is the video card and motherboard failure.
if it is not present on external screen then it most likely needs a new lcd.
hope this was helpful
Dec 10, 2009 | HP Pavilion dv6000z Notebook
My son has a Dell Inspiron 1300 hooked to my wireless port. The computer when we received it had full screen, but now the width has a gap on the left and right about an inch or so. the height is ok. Is...
Go to Start >Control Panel > Display or Personalization (XP vs Vista)
Display Settings.
Adjust the resolution... The bigger the numbers are ie. 1440x900, the smaller the font and icons, the larger the resolution ie 800x600, the bigger everything gets and fills the screen back up.
Try several settings... Windows will give you 15 secs to make up your mind or revert. You'll find a happy medium doing this.
Nov 09, 2009 | Dell Inspiron 1300 Notebook
How do I adjust my monitor? My home page does not
I'm not sure what operating system you're using nor what you mean by your "home page". If you mean your browser window doesn't fill the whole Windows desktop, what happens when you maximize the window?
If your desktop looks huge with tiny icons (and tiny-looking windows, if you have any open and not maximized) all clustered in the middle of the screen, your display resolution may be set higher than you're accustomed to. In most versions of Windows you can go to Control Panel | Display, see what your current resolution is, and try adjusting it. The higher the numbers, the "bigger" the desktop area (and the smaller the icons and everything else). If you adjust the resolution higher than your monitor can handle, you may lose your display and have to restart the computer in something like Safe mode to get to Control Panel and readjust it. If you adjust the resolution lower (or run in Safe Mode) your icons may not fit on the smaller desktop and may get scrambled. In that case, first straighten out the display resolution, then move your icons back where you want them.
Jun 14, 2009 | HP LP2065 (Silver) 20.1 inch LCD Monitor
HP Pavillion zd8000 with less than full screen view
IF YOU GO TO START, CONTROL PANEL,DISPLAY, SETTINGS YOU SHOULD BE ABLE TO SELECT YOUR MONITOR THERE,GOOD LUCK MATE.
Jun 14, 2009 | Acer X193W LCD Monitor
Replacement LCD for cf-51 toughbook doesnt fill entire display
try to update your video card graphics driver or install the mother board drivers...good luck
May 27, 2009 | Panasonic Toughbook CF-51 Notebook
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
Monitor image size
There is nothing wrong with the monitor, the issue is that the web page you are looking at is designed for a lower resolution than you LCD is set for (Web pages are normally designed for 800 x 600 or 1024 x 768) you like have a wide aspect ratio monitor.
As I sit here writing this on my 12" wide aspect LCD I have a 2" wide white space on each side of my screen due to my 1280 x 800 aspect ratio.
The issue is one of WEB PAGE DESIGN not the fault of your computer video settings. The web page is written using page frames and fixed aspect ration settings to ensure that the page displays properly regardless of monitor type.
If you had a high end LCD (WUXGA 1920 x 1200), the web page would fill the upper left 1/4 of the screen.
If you lower the resolution of your display, then you'll have fuzzy icons and text, so essentially, get used to it.
Eventually, wed design will catch up with current display technology.
Jul 24, 2008 | Computers & Internet
ACER AL2223W
right mouse click on the desk top screen go to properties, go to settings, see if that helps
Nov 26, 2007 | Acer AL1916W 19" LCD Monitor
Panasonic Toughbook CF-51 Notebook Logo
79 people viewed this question
Top Panasonic Computers & Internet Experts
micky dee
Computer Repairing
Computer Repairing
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
