Question about Panasonic Toughbook CF-51 Notebook
Replacement LCD for cf-51 toughbook doesnt fill entire display
Display only fills up 3/4 of screen and when resolution was adjusted, icons were bigger but display still only filled up 3/4 of screen
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 381 Answers
Try to update your video card graphics driver or install the mother board drivers...good luck
Posted on May 27, 2009
Replace a display
Replace screen maybe available from these WEB sites.
LCD screens and Inverters www.lcdparts.net http://www.yallstore.com
Nov 21, 2012 | Panasonic Toughbook CF-51 Notebook
Brightness on cf 29 toughbook
The backlight behind the LCD display is worn out and is built into the screen, the part can be replaced but it is a very tricky repair, most technician opt to replace the screen.
May 09, 2012 | Panasonic Computers & Internet
I have an IBM ThinkPad running Windows 98 Second Edition used to program older radios so it needs the older version of Windows. The display power on showing IBM Thinkpad full size, but when windows or DOS...
I've seen this before, the main problem is that the resolution is set too low, so it only fills part of the screen.
two ways to solve it.
1. Adjust the resolution to the optimal setting so it fills the entire screen.
2. Find the Picture Scaling option and have it Scale the picture to the entire screen.
To adjust the resolution, now its been a long time since I used windows 98, but I think you got to it by going to your desktop with the background, right click anywhere on the empty space and select properties, now on the window that opens it was the last page, settings I think, you should get an representation of your screen with a resolution lever and color options, pull the resolution lever one point to the right and hit apply and ok, do this until the picture fills the entire screen.
If your laptop has internet connectivity, I could take a look at it over remote support and solve the problem for you.
Oct 23, 2011 | IBM ThinkPad 380 Z (2635HGU) PC Notebook
Panasonic CF-51 LCD screen is very dim and fades to black. I replace the LCD screen and have the same behavior. Is this an issue with the Motherboard
Yes that sounds about right now.. but did you replace the Inverter board as well... I mean did you replace everything including all electronics attached too? Or just the LCD, see it may be the driver?
Feb 06, 2010 | Panasonic Toughbook CF-51 Notebook
My son has a Dell Inspiron 1300 hooked to my wireless port. The computer when we received it had full screen, but now the width has a gap on the left and right about an inch or so. the height is ok. Is...
Go to Start >Control Panel > Display or Personalization (XP vs Vista)
Display Settings.
Adjust the resolution... The bigger the numbers are ie. 1440x900, the smaller the font and icons, the larger the resolution ie 800x600, the bigger everything gets and fills the screen back up.
Try several settings... Windows will give you 15 secs to make up your mind or revert. You'll find a happy medium doing this.
Nov 09, 2009 | Dell Inspiron 1300 Notebook
How do I adjust my monitor? My home page does not
I'm not sure what operating system you're using nor what you mean by your "home page". If you mean your browser window doesn't fill the whole Windows desktop, what happens when you maximize the window?
If your desktop looks huge with tiny icons (and tiny-looking windows, if you have any open and not maximized) all clustered in the middle of the screen, your display resolution may be set higher than you're accustomed to. In most versions of Windows you can go to Control Panel | Display, see what your current resolution is, and try adjusting it. The higher the numbers, the "bigger" the desktop area (and the smaller the icons and everything else). If you adjust the resolution higher than your monitor can handle, you may lose your display and have to restart the computer in something like Safe mode to get to Control Panel and readjust it. If you adjust the resolution lower (or run in Safe Mode) your icons may not fit on the smaller desktop and may get scrambled. In that case, first straighten out the display resolution, then move your icons back where you want them.
Jun 14, 2009 | HP LP2065 (Silver) 20.1 inch LCD Monitor
Screen does not present full display
may be ur display & graphics driver not installed properly
May 27, 2009 | Panasonic Toughbook CF-51 Notebook
I believe that my display module is flawed
the problem is its a lcd liquid crystal leak you need to replace the lcd you can get them from dell.com
Apr 07, 2009 | Panasonic Toughbook CF-51 Notebook
Panasonic cf-51 laptop from iraq
I'm sorry Joel, these screens are considered sealed units, and you can't get replacement parts for them. You'll have to purchase an entire screen. Give your brother my regaurds, Semper Fi !!!!
Aug 05, 2008 | Panasonic Toughbook 51 Notebook
Display resolution problemw with Dell Inspiron 8000
I had the same problem you described as small screen in the middle with black border around it. The only resolution that made the screen fill the LCD panel was 1024 x 768. THAT IS WRONG!!!
Dell Inspiron 8000
PROBLEM - Small Screen in the Middle
FIX THIS PROBLEM - Try (Function Key + F7)
Nov 21, 2007 | Computers & Internet
Panasonic Toughbook CF-51 Notebook Logo
678 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
