Question about Cell Phones
How to connect a Motorola HS820 headset with a Sony Ericsson C510
I am wanting to connect my Motorola HS820 Bluetooth Wireless Headset to my new Sony Ericsson C510 but can't seem to do this. I have tried serching for headset, serching for my device but I'm not having any luck. Please help.
  • jamescham442 May 27, 2009
    Thank you for your help. I will buy a different headset.
  • 464 Answers
The interface between motorola and sony ericson works only in some models..try some other headsets (of your friend's ). of the same company.if it works then its not possible to connect the device
Posted on May 27, 2009
How does one turn on a Motorola 537w bluetooth
To power your headset on, press and hold the Multifunction for 3 seconds until LED flashes rapidly.
To turn your headset off after use, press and hold the Multifunction button for 3 seconds until the headset flashes rapidly and turns off.
Hope it helps
Apr 16, 2011 | OEM Systems Motorola Bluetooth Headset ,...
My droid 2 is not recognizing the motorola hs820 bluetooth device; I have no info on how to set the hs820 to pair
I think I can help here:
Make sure your headset and phone are charged before doing anything else. The blue light on your headset will come on when it is charging, and will shut off when fully charged.
To put your headset in pairing mode, make sure it is completely off first (no blinking blue light). Then hold down the Call button for 6-10 seconds until the blue light stays on. (It will likely flash once and shut off, but keep holding until it is all the way on and stays there!)
From there, go into the settings on your Droid 2 and access the bluetooth connections. Do a new scan for your headset if you don't see it listed, pair, and connect!
http://www.motorola.com/mdirect/manuals/QG-HS820_9494A71A.pdf
Feb 23, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
I want to connect a motorola H700 bluetooh to my sonyericksion t616 how do I do this?
you can connect your sony ericsson t616 to your motorola h700. for that you have to switch on the bluetooth in your phone then you must switch on your bluetooth headset. after that from your phone select the option "search for any devices". but i would suggest that you can go for a sony ericsson bluetooth headset instead of any other brand,because motorola might not be compatible.
Oct 23, 2009 | Sony Jabra Earbud Headset - Ericsson T610...
Sony Ericsson not recognising motorola n356 headset re bluetooth.
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’.
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Chris (ziraffa)
Dec 23, 2008 | Motorola Mobility Bluetooth Hands Free...
Can't hear headset
Here is a list of compatible bluetooth headsets taken from the Blackberry web site.
  • Flamingo™ Bluetooth Headset *
  • Jabra® BT250v
  • Jabra JX10
  • Jabra BT125
  • Logitech® Mobile Pro™ Headset
  • Motorola® Bluetooth Headset H500 **
  • Motorola Bluetooth Headset HS820
  • Motorola Bluetooth Headset HS850
  • nXZEN™ 5000
  • Plantronics M3000 Bluetooth Headset
  • Plantronics Discovery™ 640 Bluetooth Headset
  • Plantronics Explorer™ 320 Bluetooth Headset
  • Plantronics Voyager™ 510 Bluetooth Headset
  • scala-500™ ***
  • Sony® Ericsson® Akono™ Bluetooth Headset HBH-602
  • It may be a compatibility issue with the H700. You may want to make sure the volume is turned up fully on the headset as well.
    Good Luck
    Jun 28, 2008 | Motorola Mobility H700 Wireless Headset
    NOT PAIRING ANYMORE
    1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
    3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
    4.Select HS820 once a connection is detected.
    5.The passkey "0000" is now entered to confirm the connection has been made.
    6.The cell phone screen will now read "Bluetooth Connection".
    Tips:
    1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
    2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
    3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
    please give good rating if the solution works.
    Thanks for using FixYa.
    Mar 15, 2008 | Motorola Mobility HS820 Consumer Headset
    Bluetooth headset won't play music
    hello,
    All the bluetooth wireless headset are only capable of making/receiving voice calls.
    Y?
    its a bluetooth software which is installed on ur cell phone. it is not capable of listing the music through the BT headset. BT 1.1 Software version only lets you listen to mono.
    BT 1.2, Version playing music through a BT headset while music is playing on laptops.
    and again we need to find out what BT software version is on the phone and if sony erricsson came out with better BT software for your needs.
    hope this little information helps.
    TY
    Nov 29, 2007 | Sony Ericsson Walkman W810i Cellular Phone
    Headset will not pair up eith razr phone.
    Have you pressed and held the button on headset until light is always on, as this is in pairing mode, then search devices with your phone.
    Jan 15, 2007 | Motorola Mobility HS820 Consumer Headset
    Cell Phones Logo
    108 people viewed this question
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
