Question about Logitech Wireless Access Duo Optical Desktop Keyboard/Mouse KBWIREOPT
Reciever maulfunctioned My logitech wireless ex100 device isn't working when i plug in the receiver into the computer it says unknown device help?
  • 66 Answers
Ur keyboard & mouse must not be install properly
Posted on May 27, 2009
How to connect/sync the mouse and keyboard to the receiver?
On all wireless keyboards/mice there is a button on the bottom of each device that sends a signal to the receiver. I grabbed an image from google that shows where this button is on your model.
Press the button on the receiver then press the button on the keyboard. If that doesn't work I would try the other way around just in case.
Hope this helps.
If you still have problems with it I would try unplugging the receiver and plugging the receiver into a different usb slot and try pressing the button again after the receiver is connected.
Sep 10, 2014 | Logitech EX100 Cordless Desktop Wireless...
Logitech wireless mouse (m305) isn't working
Does this mouse need to sync with the reciever plugged into the computer?
Somewhere on the mouse and posssibly on the reciever plugged into the USB
port on the computer it should have a connect button. Usually to connect/sync
a mouse or keyboard press the button on the reciever first then press the connect
button on the mouse. Or if th mouse has a button just press the mouse button,
often the mouses lazer will blink until the mouse connects with the reciever then
just stay lit at this point it sould work. Another Question, how are the batteries in
the mouse?
May 19, 2011 | Logitech Cordless Mouse
Do I need to download software to use the wireless mount n receiver, model ex100
Typically you do not need to install drivers for mice and keyboards(wired or wireless) as Windows will take care of that for you once you connect the device. Most of the time the software you install from the manufacturer is used to configure the device. If Windows does not install the drivers by itself then you can download what you need from the Logitech.
Mar 12, 2011 | Logitech Cordless Mouse
I have the Logitech EX100 wireless keyboard and mouse. We had to change the battery as it went dead. Now that we have new batteries in we cannot get them to work. Any suggestions?
Do a Hard Reset method to clear the keyboard and mouse settings and reconnect it back to your computer:
• Remove the batteries from the keyboard
• Press the Connect button on the receiver for 10 seconds.
• Press the Connect button on the mouse.
(You might need a pencil tip or other small tip to press the connect button.)
• Insert the batteries back into the keyboard.
• Press the Connect button on the receiver.
• Press the Connect button on the keyboard.
Hope this helps
Please rate this solution, thanks!
Mar 08, 2011 | Logitech EX100 967499-0403 Keyboard
Keyboard seems to have lost range
This might help and might not. Check in system to see what devices you have on the same usb hub. The more things on the same hub the less power that goes to the transceiver for the mouse and the keyboard. Ideally if you can just connect the one thing to the one usb hub and try to leave it alone from there.
Hope this helps.
Jun 11, 2010 | Logitech EX100 967499-0403 Keyboard
I use a logitech mouse. I recent had some service
the only thing i can think of is if its usb you need to resynce the devices if you have tried that i cannot think of anything else :)
steven.
to resync them you just need to hit the button on the reciever (thing that connects to the computer) and hit the button on the bottom of the keyboard then go repeat the same thing for the other device.
Steven.
Apr 14, 2010 | Logitech Wireless Access Duo Optical...
I have a logitech Ex100 mouse/keyboard set & both have just suddenly stopped working. It tells you how to re-start the system by pressing 'connect' on the reciever & then the mosue &/or...
Mar 02, 2010 | Logitech EX100 967499-0403 Keyboard
Dead keyboard. Yes! I have replace batteries, uninstalled everything, booted pc.
i just got off the phone with logitech tech support about my 'dead keyboard'. I have a logitech wireless keyboard/mouse ex100. the mouse still worked and the keyboard just quit all of the sudden like. THE FIX! 1. Make sure in your device manager that the keyboard is still connected and working properly. if it is...
2. then remove the batteries and type on the keyboard for 10 seconds or so.
3. Then reinsert the batteries.
4. press the left alt key, left control key, and the f12 key all at the same time.
5. Then press the connect button on the reciever
6. press the connect button on the keyboard
7. press the escape button on the keyoard
8. test the keyboard
it worked for me :) that's how i was able to type this. hope it works for you
Jan 04, 2010 | Logitech EX100 967499-0403 Keyboard
Joystick is not finding the wireless receiver
On the front of the usb reciever you will see a green flashing LED. This is actually a button which when pressed will then start to blink more rapidly as it is now searching for the controller. If you then immediately press a button on the controller whilst these rapid flashes persist it will find the controller. Both reciever and controller will now show solid LED lights. Voila job done .....happy gaming:P
Dec 06, 2009 | Logitech Cordless USB Freedom 2.4GHz...
Three lights on reciever stuck on
Does re-doing the Connect process work? [i.e. press the button on the receiver, then on the mouse - repeat for keyboard]
Dec 29, 2007 | Logitech Cordless Desktop EX110
Logitech Wireless Access Duo Optical Desktop Keyboard/Mouse KBWIREOPT Logo
85 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
