Makes loud vibrating noise when turning off and on
Tv making a very loud vibrating noise when turning on and off. also bad enough to effect picture
    President:
  • 1,348 Answers
The high voltage transformer is going more than likely.
the picture is affected because the flyback transformer drives the horizontal deflection circuit as well
Posted on May 27, 2009
Emerson EWC20D3 20 in. TV/DVD Combo what is that loud whining noise from the back
What happens in this case is a small transformer or the high voltage transformer vibrate hard enough to make that sound--not loose or bad but can cause the vibration.
I have seen in customer's homes where it was loud enough to chase cats right out of the room even in a large room.
Two ways to deal with this----with the set apart locate the part by ear or even probing with a plastic tool---when you press close to it, the sound will diminish or go away.
Believe it or not (in our shop) once located we use a hot glue gun to take the sound away---
usually if very loud it is the high voltage transformer on the main TV board (see photo of a typical one) not on the black part but on the iron like (it is a different material) core that looks like a U bolt.
it can irritate but poses no danger.
Mar 28, 2012 | Emerson EWC20D3 20 in. TV/DVD Combo
Optoma ep716 continuous loud vibration noise when turned on.
the fan motor could be failing. turn it on with the top off. if one of the fans is moving slower, that'd be the one. since this is a dlp projector, the colorwheel motor berings might be on their way out as well. both need replacement.
Jul 25, 2009 | Optoma EP706 Projector Remote Control
Loud popping noise
The 23" CRT set may have a high voltage breakdown in the flyback transformer or focus divider. Take the back off and operate the set in a dark room. Look for anything that has a blue glow around it or sparks flying when the pop occurs. I won't guarantee this will find your problem, but it is definitive if you see these!
I once had a set with these symptoms. I stopped the blue glow and arcing by covering the focus divider with epoxy. It worked for a couple of months before the divider literally broke apart.
Mar 02, 2009 | Polaroid TLA-04011C 40 in. LCD TV
The lamp fan is making a vibration/noise
if the frequency of the sound changes more likekly you have a bad color wheel, if a certified service center is working whit it, call hitachi costumer service problably they will pay forr the light engine(where the color wheel is located)
Dec 02, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
TV turned off and wont come back
looks like the color wheel its bad in the set,color wheel its not spining at its proper speed( one of the segments may be broken)
thats the vibration you are hearing.. and the set its trying to turn on..until you replace the wheel you will be able to watch tv again.
hdtvman
Jul 03, 2008 | Samsung HL-R4266W 42" HDTV-Ready...
Sound at power on
The sound you are hearing is the degausing coil which will vibrate for a second when the tv is turned on. This part demagnetizes the picture tube and this sound is really quite normal. Depending on the position of this coil it may vibrate against the front cabinet of the tv and may sound loud at times. If this really bothers you then you need to have the rear cover removed and have it repositioned a bit do it won't vibrate so loudly. Or you can enjoy the buzz for the short time it happens and not worry about it.
Jan 23, 2008 | Sony FD Trinitron WEGA KV-32HS420 32" TV
HELP HL-R5067W LOUD GRINDING/VIBRATING NOISE
noise you are hearing can be the fans inside with bad bearings and or what im assuming given the info you gave.More likely the motor inside the optics engine (color wheel) is making noise..This will also cause picture problems..very expensive to repair..
Dec 13, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Very loud fan or vibration noise
Listen from the back of the TV and locate the source of the noise. There may be fan with a bad bearing. The noise will lead you to it.
Nov 06, 2007 | Soyo Dymond DYLT037A Television
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
Electro Med Services...
