Question about Nokia 3120 Cellular Phone
Not charging when charger is connected it shows "NOT CHARGING" Ihave a problem with nokia 3120 when i insert chager in mobile & power on it show NOT CHARGING. this problem crate by mobile software or hardware
  • Roberta Smith
    Roberta Smith May 11, 2010
    is that a brand new phone ?
5 Suggested Answers
jaffi
  • 8 Answers
SOURCE: NOKIA 6630 displays not charging when connect charger
hi dude,
>>> dont remove any thing from u r mobile, first confirm the problem where it is...
>>> first try to put the charge by using other charger... still u r getting same problem means change the charging unit
>>>good luck... thank u....
>>> dont forget to rating the solutions...
Posted on Feb 16, 2008
  • 31 Answers
SOURCE: my mobile is nokia 1600. battery ok. charging
Try Changing Battery Bcoz i think you are using new BL-5C battery
Posted on Jul 08, 2009
teknikgurun
  • 450 Answers
SOURCE: My nokia 1600 is not charging.......
clean the charger connectors against the phones mainboard (phone needs to be opened)
Posted on May 11, 2010
jaisonthomas
  • 356 Answers
SOURCE: when i insert any sim
it seems to be a hardware problem.give it to a authorised techinician. but before that we will have a try.try reinstalling your phones firmware using nokia software updater.it may solve your problem.else do wht i sais initially.
goodluck
Posted on Sep 09, 2011
Nokia n96 not charging
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Dec 17, 2012 | Nokia N96 Smartphone
Samsung gt e3213k charging problem.
First Option:
Second Option:
Sep 07, 2012 | Samsung Cell Phones
When i insert any sim card in my nokia 5230 it doesn't power on & when i remove sim from it, it works fine in offline mode & also having charging problem when i connect charger to mobile it...
goodluck
Sep 09, 2011 | Nokia 5230 Cell Phone
My phone is not charging. when the charger is connected it shows the battery icon blinking as while on charging. but it is not charging & the battery was also OK .
First Option:
Secend Option:
Aug 11, 2010 | Motorola Mobility ROKR E6 Smartphone
Nokia 3120 not charging
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Aug 09, 2010 | Nokia 3120 Cellular Phone
230 chauffeur doesn't charge. Batteries new and
hi, ok you mentioned nothing about the charger, is it built in ? or stand alone charger, can you try another charger ??
If you have a Electrical meter tester check that the charging socket pins do actually connect to the batteries if not check the charging socket,
of the three charging pins two are the positive & negative so should show 24 volts the odd one out the one in the middle just below the other two is the inhibit , that is normally grounded otherwords negative.
Sound like a loose connection so please check all connections if you are sure the charger is ok.
Regards
GeWiz.
Dec 10, 2009 | Electric Mobility Mobility Electric Power...
Not charging
Try using another charger. If you get the same problem even though you're using a known working charger, then it could be the battery.
Jul 21, 2009 | Nokia 2600
hi dude,
Feb 16, 2008 | Nokia 6630 Cellular Phone
Nokia 3120 Cellular Phone Logo
251 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
