might be that the water level in the tank is to low. if both buttons release the same amount of water then you have to increase the water level in the tank by adjusting the height of the floater on the inlet valve. look inside the tank and there should be a WL mark meaning water level should be set to this level minimum.
Try lowering the float level. This will reduce the amount of water in the cistern and lower the pressure on the flapper so when you flush the water will not flow as fast into the bowl.
All toilet bowls have a preset water level determined buy the design of the internal s-trap and can not be change. However if the water level in the tank is not as high as it should be this will affect the water put into the bowel as the bowel in refilled by the flush valve and if it is set to stop before it get filled to the proper setting the bowl water level may be low. A quick test is to see if the water level in the tank is up to the line in the tank most all toilet tanks have a line either stenciled or marked with a indentation in the porcelain. Another way is to mark the level in the bowel with tape or a marker then pour water slowly into the bowel not fast enough to flush it wait to see if it stays higher then the mark you made or settles back to that level.
Hi, W/D here. Check the water level in the tank. The force to flush waste comes from there. Normally the fill line is cast into the back of the tank, but sometimes it is on the overflow tube. Raise the level if it is low. Also, make sure that the tubing from the fill valve is connected to the over flow tube (the tall tube). Best regards, --W/D--
Make a small mark with a pencil or marker that can be erased of were your water line is in your bowl. Pour some water from a bucket into the bowl SLOWLY and see if the water line rises or drops back down to your original mark. If it drop back to the original mark, then that is the way the toilet was made. You won't be able to do anything about it. If it rises and stays at a higher level, then you have a problem with the fill tube in the tank. You will need to call a Pro!
