Question about HP ProCurve Switch 1800-24G, 22-Port Web Managed 10/100/1000, 2-Port Dual RJ-45
Network problem i have 2825 hp switch i want to config as a router is it posibal
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 116 Answers
No, this is a layer 2 switch only.
Posted on May 27, 2009
Ruckus multimedia vf2825 ip not accepting en my ppc
You mean it won't allow your PC to connect to the wireless network?
See if the troubleshooting tips on page 19 of the manual help:
http://support.alcadis.nl/files/get_file?file=Ruckus/MediaFlex/MF-2111/Manuals/MF2111%20User%20Manual.pdf
Nov 02, 2014 | Ruckus Wireless Ruckus Mediaflex 2825...
Tip
Why lose a router settings after a power outage?
Question:<br> After a power outage <a href="http://www.3anetwork.com/cisco-1900-series-routers-price_c12"><b>Cisco 1900</b></a> lost my router configuration, was saved, reload the configuration, save, reboot and no problem.<br> How to know if my router is properly, all my services run smoothly? Why it happens that configuration is lost?<br> Are there any benefits the settings saved in flash?<br> Answer:<br> Did you check if the NVRAM was empty or running config was empty?<br> If router booted with empty running config, it could be that startup got erased (NVRAM issue) or that it did not load it from startup to running (likely config-reg) issue.<br> Since in your case config-register ix 0x2102 and was not changed, the problem should be with NVRAM.<br> From me exprience, I have seen that in the following cases:<br> - config was not saved to NVRAM;<br> - at the time of powerdown the NVRAM startup file was accessed for editing (e.g. saving running config) and got corrupted or erased;<br> - NVRAM HW issues cause file system problems.<br> Is it reproducible in your case? E.g. if you powercycle the switch, do you see the same problem with config loss? If yes, check the NVRAM content. <a href="http://www.3anetwork.com/cisco-1900-series-routers-price_c12"> <b>Cisco 1900 router</b></a> That could give some hints.
on Aug 22, 2013 | Cisco Computers & Internet
Windows Vista won't let me config Arris tg862g router options
hope this help you.
you need yo reset the router, there is a reset button on the wireless router that you need to click for 10 sec after that, connect everything to your PC and follow instructions on this link bellow.
https://bendbroadband.com/residential/support/detail.asp?kb=100196
May 06, 2017 | HP Computers & Internet
I have purchased a D-Link DES 1026G unmanaged switch but have no idea how to go about setting it up. We have 8 computers running windows xp a Iburst broadband internet connection and two printers ( 1x HP...
hi,
well depending on any other items in you network. it appears that you would conect one of the 2 gig(on right side) ports to your router(iburst).and all other systems directly to this switch 24 ports. considering this is unmanaged there is no config. it works flat out across the network segment created by your Iburst router.
GL
hope this helps
Don't forget to vote for me
Thank You
Jammer
Jul 19, 2011 | D-Link DES-1026G 24-Port Ethernet Switch...
Need to change NAT settings. None of the IP address take me to the router config page.
Its simply because this device is dumb (no config) it is just a standard switch no routing aka: NAT.
http://kbserver.netgear.com/pdf/fs105_fs108_install_guide%20.pdf
Jun 12, 2011 | NetGear FS108 Networking Switch
Need to accses a switch that has been configured with two factor security. The switch is currently connected via serial to my pc. how can I clear all the config so as to configure same switch for an other...
When prompted for the password, press the clear button and hit enter. This will let you into the switch.
Next to clear the config, type "erase startup-config" at the # prompt, then follow the prompt to reboot the switch.
Nov 02, 2010 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
Dhcp setup on a Cisco 2851 router
Let's look at how to configure basic DHCP on an IOS-based router. For this example, we'll start off with the default configuration on a Cisco 2611 router running IOS 12.2. (The configuration should be the same—or very similar—on all IOS-based routers).
To begin, connect the router's Ethernet port to a switch, and connect the switch to a laptop, which will serve as the DHCP client.
To configure Cisco IOS DHCP, follow these steps, which include sample commands:
1.Configure an IP address on the router's Ethernet port, and bring up the interface. (On an existing router, you would have already done this.)
Router(config)# interface ethernet0/0
Router(config-if)#ip address 1.1.1.1 255.0.0.0
Router(config-if)# no shutdown2.Create a DHCP IP address pool for the IP addresses you want to use.
Router(config)# ip dhcp pool mypool3.Specify the network and subnet for the addresses you want to use from the pool.
Router(dhcp-config)# network 1.1.1.0 /8 4.Specify the DNS domain name for the clients.
Router(dhcp-config)#domain-name mydomain.com5.Specify the primary and secondary DNS servers.
Router(dhcp-config)#dns-server 1.1.1.10 1.1.1.116.Specify the default router (i.e., default gateway).
Router(dhcp-config)#default-router 1.1.1.17.Specify the lease duration for the addresses you're using from the pool.
Router(dhcp-config)#lease 78.Exit Pool Configuration Mode.
Router(dhcp-config)#exit
I hope this is helpfull for you.
Thanks
Vikrant
Oct 26, 2009 | Computers & Internet
HP ProCurve Switch 1800-24G, 22-Port Web Managed 10/100/1000, 2-Port Dual RJ-45 Logo
130 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
