Question about Acer (4432A-002) CD-RW Burner
Cant install program from DVD drive GWA-4164b
Trying to install SPORE from DVD drive. The drive periodically is able to see the disk and begin install. Most times I cannot even read the disk. All other CD/DVDs I have tried in this drive work I can't install my Sims2:apartment life too!!!
  • bazlabb May 27, 2009
    My disc is clean and it's original.
    Plus, I can't read any DVD-rom too. Can anybody help ME?????????
  • John Moore May 11, 2010
    Are the disks clean on the read side? Are the disks original or copies?
  • 489 Answers
Do you use orginal CD or DVD. if you saying yes. your CD/DVD drive is getting break down
Posted on May 27, 2009
  • 256 Answers
As Bunty1981, it may be the lens in the drive is dirty. To fix this, you will have to remove the drive from the computer, open the drive case and use a "Q"tip to gently clean the lens. re-asemble the case and install the drive in the computer. If this does not help, then ametehan may be right. This means uying a new drive and installing it into your computer.
  • 66 Answers
Its ur drive lens problem
Hl-dt-st dvdrrw gwa-4164b WONT READ CD OR DVD
need to replace Drive. sounds like its dead.
Nov 02, 2010 | Acer (4432A-002) CD-RW Burner
DVD is reading, Not reading some CDs (CD-R Which is written)
Hello,have you checked what format is the cd? your burner supports only CD-R and not CD+R,also check the cd if is dirty or scratched!
Jan 18, 2010 | LG GWA-4164B DVD±RW Burner
My LG GWA 4146b wont read any disk i put in, just
is it for a particular disk or all??
assuming for 'all' and with all data cables n jumpers r sitted correctly....
if u r a professional, open it up, with the lens assembly there is a small preset, turn it using a screw driver a little anti-clockwise..clean the lens with clean cotton using isopropyl alcohol..
if not done, replace the lens assembly..
or else, replace the drive with a standby n see..
..contact ur System Admin/Vendor....
Oct 27, 2009 | LG GWA-4164B DVD±RW Burner
My DVD drive (Dell GWA-4164B HH 16x DVD+/-RW) will not read DVD's
click on the below link and download the avs dvd player...it is free and a great universal player.
http://www.brothersoft.com/avs-dvd-player-free-44678.html
Oct 11, 2009 | Computers & Internet
Model #GWA-4164B DVD Writer does not recognize any disc Cd or DVD. computer sees the drive when you install a DVD it tries to read and fails . Try to explore it indicates please insert a disc. Firmware is...
It sounds as if the disc drive laser has died, when they burn out they will not recognize any disc inserted. fortunatly a replacement drive is relativly inexpensive to replace.
Aug 24, 2009 | Hitachi Computers & Internet
First check that your system meets the minimum requirements...ie. you have at least 512mb of ram, CPU of at least 2Ghz Pentium4 or equivalent(with off-board video), and your hard drive has >4GB of free space.....can view full list at:
http://www.amazon.com/Spore-Mac/dp/B000FKBCX4
Is SPORE on a duel layer dvd? If your drive is on the older side, you might try a newer one or you can try the following:
--take out an empty flash drive with
--go to a computer that will read the disk...if you have another computer or u can use someone elses
--put the disk in their computer and if the computer is able to read the disk, then put your flash drive in the computer and copy the disk onto your flash drive...
-y-ou can now try to install the program from your flash drive instead of using the disk...
NOTE: Trying this method wont cause any damage, but if the disk is encripted or if the install software is set to check for the disk during installation, then this may not work, but is worth trying since because a) even if it doesn't work, no harm is done, and b) you wont need to replace your disk drive if it does work.
Feb 12, 2009 | Acer (4432A-002) CD-RW Burner
Dell dvd burner does not recognize media
sir, try using NERO software and make sure that your cd-r or dvd-r has no scratch and it should be new. hope that helps!
thank you for using fixya
CHARCOIS
Feb 06, 2009 | Dell (0R649) CD-RW Burner
HL-DT-ST DVD+RW GWA 4164B DOENSN'T WORK
open explorer and go to 'My Computer'
right click the DVD/CD-ROM Drive
click on the tab labeled 'Recording' (usually on the far right)
click the option that is labeled 'Enable CD recodring on this drive'
...and POOF, magic happens...
Dec 31, 2008 | Computers & Internet
Open Questions:
Přeji hezký den. Mám velký Přeji hezký den. Mám velký problém s dvd mechanikou ve svém PC. Pc mám cca dva roky a dvd mechaniku jsem sotva využila 5x. Před nedávnem jsem pro svůj pc využila doporučovaný program na vyčištění Cleanr a nechala ho dělat svou práci bez mého zásahu a po té, když jsem chtěla spustit dvd, tak dvd mechanika se mi otevře, vložím dvd a zavřu, chvilku světýlko bliká a nemá to snahu ani začít načítat a tím se tedy ani nespustí. Prostě vůbec nereaguje. Zkusila jsem aktualizovat ovladač (mám u něj vykřičník) a to mi vykázalo, že ovladač je správně nainstalovaný a funkční. Tak co mám ještě udělat, abych vlastně skoro nevyužitou dvd mechaniku ve svém pc mohla používat? Omlouvám se, že se tak rozepisuji, ale bohužel moc nerozumím technickým záležitostem v pc. Softwer ovladače je : HL-DT-ST DVDRAM_GSA-H40N ATA Device model pc: ASPIRE M1100 ( ACER ) rating : 220-240Vac,3.15A,50Hz Opsala jsem co se dalo, pak je tam jen S/N + číslo a SNID + číslo. Budu moc ráda, když mi pomůžete. Dopředu děkuji a přejei krásný den. S pozdravem Bundzíková Světlana
Feb 28, 2017 | Acer (4432A-002) CD-RW Burner
See all Acer (4432A-002) CD-RW Burner Questions
Acer (4432A-002) CD-RW Burner Logo
175 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
