Question about Newpoint (200897) (DHN200897) UPS System
No back-up when current goes my computer and ups switches off without i getting to shut it down. when i un-plug the ups it just cuts off. i am not getting no back-up time
  • nerdman Oct 21, 2007
    this is nerdman, i didnot connect it when i first set it up. how do i check the battery
  • nerdman Oct 23, 2007
    its the newpoint 200897. i tried running it without load and it came on, like it was working but the battery level was jumping from 100-18.. an if it has any load it just cuts off.. giving no backup
    Novelist:
    Champion:
  • 382 Answers
YOur UPs is defective. Check the battery. DId you connect it when you first set it up?
Hope this helps.
Posted on Oct 21, 2007
While I was cutting grass the Engine shut down. Pulled the brake up. Push the PTO back down to shut the blades down. I started the engine, engine runs perfect.
try replacing the battery most with an electric clutch PTO have to have a really strong battery as the alternator system is not strong enough by itself
Jun 16, 2015 | Garden
How do I get the part where the plug for turn signal switch go thur this without cut and rewire it?
Take apart the tilt steering column, buy the small harness, and replace.
(Harness has turn signal switch, etc. on one end. Harness goes down the column, and plugs in; on the other end. Or cut wires, solder, and use heat shrink tubing. Slide heat shrink tubing up one wire BEFORE soldering. Slide down onto soldered connection of wire, heat ->heat shrink tubing )
Nov 20, 2012 | Cars & Trucks
Emachine will not shut down
Back up and reinstall the operating system,can't help without knowing what is the actual problem...
Mar 28, 2012 | E-Machines eMachines Desktop PC
My check engine light has come on. I went to auto zone and they hook up the diagnostic computer. The code came back as bank one and bank two. I replaced the mass air flow sensor but when plugged in my...
it could be a bad one take it back and request a new one also you could try un hooking the
battery for 5min so it clears the computer then hook it back up ant see if that works for you
hope this helps you
good luck
bob
May 11, 2011 | 1998 Ford Explorer
When i shut down windows xp, it goes through all and the hard drive shuts down but the cpu fans and coooler fans keep going, then i cannot switch it back on unless i reach to the back of the computer and...
It seens like a motherboard or power supply problem.
If you have a spare PSU, replace it with the current computers PSU. If you don't have a spare, you can always take one from another computer.
If the problem is still showing up, then the motherboard may be defect and will have to be replaced.
Sep 22, 2010 | MSI K9VGM-V Motherboard
IBookG4 shuts down un-expectantly w/ battery fully charged
your having an overheating problem its either your processor or your chipset inside the laptop..let it rest for a while put a cooler pad under your laptop while using it to prevent further damage..i suggest you backup all your data also before it crashes permanently..also bring it to your nearest mac service center...hope this helps
Aug 31, 2009 | Apple iBook G4 Mac Notebook
Computer Randomly Cuts off
processor overheating. When it gets too hot it automatically shuts your pc down and boots it back up. Even if the fan is running, it could not be supplying enough cool air anymore.
Jul 27, 2009 | Computers & Internet
When shutting down the compressor, oil comes out intake filter
hi there,
well,if your air compressor was shut off this due to pressure switch w/c auto switch off your compressor,the pressure switch acquired already the cut off pressure.if the pressure goes down the cut in set up reached it will start your compressor
to run.
regarding oil spillage when shutting down check the oil level on the sight glass of crankcase
a red line indicate oil should not exceed on that level line,if the oil exceed try to drain oil.,on the side bottom of engine there is a drain plug.until on limit level .,besure that machine is shut off/breaker is off.have a nice day don't forget to rate me,thank's
Apr 28, 2009 | Ingersoll Rand Type 30 Electric Driven Two...
ONLY 2 MINUTES MAX OF BATTERY BACK-UP TIME BEFORE EVERYTHING SHUT
you can program your power bottom to hibernate, and connect the screen direct without the UPS, so you get more time...then when the electricity goes off, without seeing the screen just push the power bottom to hibernate.
Dec 03, 2008 | Minuteman Office Plus 500 UPS System
Newpoint (200897) (DHN200897) UPS System Logo
148 people viewed this question
Top Newpoint Computers & Internet Experts
David Payne
David Payne
Are you a Newpoint Computer and Internet Expert? Answer questions, earn points and help others
