Question about Philips Philishave HQ7780 Electric Shaver
Replace batteries on phillishave HQ7780
Batteries will not hold charge & need replacing. I do not know what type of screw driver is needed to remove the shavers screws
  • gsohxxx Mar 02, 2009
    I have a Phillishave 8885 and it holds 5 minutes of charge then dies. Who fixes these things ??
You neet torx T9 , quite cheap.
Posted on Dec 21, 2007
How do I replace the battery?
to replace the batteries in your Go-Go you need to remove the battery case from the scooter and turn it upside down . as you use an AGM gel battery you will not spill any thing i change mine out every 400 charge cycle as they are good for about that long. on the bottom of the case you will find 8 screws you need to take out to open the case you will need a 6 to 8 inch long Philips screw driver for this. after you remove all the screws you need to turn the box up right and remove the top.inside you will find 2 batteries. you will need to replace both batteries to ensure the full 24 volt to power the scooter. yes you use any AGM gel battery.i get mine at batteries plus as it cost about half the price.
carefully using 2 wrenches loosen and remove the small bolts and nuts holding the cables leads to the batteries' terminals, there should be 2 black and 2 red. now either draw how they attached to the positive and negative terminals or mark them in some manner.The batteries have two velcro strips on the bottom of each battery. remove the strips and place in the same position on the new batteries now place the new batteries in the box and press down firmly to seat the velcro, attach the cable leads to the proper terminal, replace the top and turn box upside down and replace the screws. now the batteries are ready to charge up so you can do as i do... race like at speed demon around in circles... happy scooting
Aug 29, 2011 | Pride Go-Go Elite Traveller Plus HD...
Re Phillishave HQ7780 Why does battery fail completely when switched off at the end of each shave and then has to be recharged before it will operate again.
It sounds like the battery no longer holds a charge correctly and needs to be replaced. You will find replacement batteries at shaveroutlet.com. See link below. Also, scroll down the page for helpful videos to aid in installation
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
Aug 04, 2011 | Philips Philishave HQ7780 Electric Shaver
After fully charging the battery the charge fails after 10 -15 mins of use. How can I solve this issue? Thanks Tony
the battery is dead and needs replaced. You will find the correct battery type at shaveroutlet.com. See link below
To replace, start by removing the lotion packet cover on the back. Remove the screw on the back near the bottom to remove the pointed bottom of the shaver. Then remove the 4 screws to remove the battery compartment cover and access the batteries. For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Feb 21, 2011 | Philips Philishave HQ7780 Electric Shaver
Does not keep its charge.I was hoping to fit new batteries and I have no manual for my phillishave HQ5812
The manual does not show you how to replace the battery as it is not intended for the user to change. To change, first remove the two screws on the back to remove the back cover and access the battery. For easiest replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
You will find the correct battery for your model at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/batteries/shaver-battery-pack-for-most-shavers-p-211.html
Dec 24, 2010 | Philips Health & Beauty
My shaver will not hold a charge. What could be the problem
Remington model R-9500
Your shaver will not hold a charge because the shavers internal batteries need replacing. If you know how to solder, you can do it yourself or you can have it professionally done. You can purchase batteries or professional repair service from shaveroutlet.com. See links below.
http://shaveroutlet.com/shaver-battery-pack-for-most-shavers-p-211.html
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
If you feel this is something you want to try yourself, you will need to remove the back cover of the shaver. You will easily notice two screws on the back. There is a third screw that is near the very top on the back and it is underneath the trimmer where the trimmer connects to the shaver. Remove these 3 screws to take off the back cover.
Inside you will see the batteries. You will need to remove the metal clip that helps secure them into place. You will then need to use a soldering iron to remove the wires from the ends of the old batteries. Solder the new batteries to the wires and put everything back together in reverse order
Once the job has been completed, charge the new batteries for 24 hours.
Jan 24, 2010 | Remington Titanium SmartSystem R-9500...
Once it is fully charged it last for a few minutes then switches off
it sounds like the batteries need replaced. batteries can be purchased at shaveroutlet.com. repair services are also available
Dec 22, 2009 | Philips Philishave HQ7780 Electric Shaver
Phillips 990 shaver new batteries
shaver batteries can be purchased at shaveroutlet.com
Dec 21, 2009 | Philips Philishave HQ7780 Electric Shaver
Electric Shaver will not charge
There are 4 small philips head screws deeply recessed on the rear of the razor. Unscrew these and the back half of the case just lifts off. Unsolder the battery leads and fit new battery pack.
Feb 12, 2009 | Philips Philishave HQ7780 Electric Shaver
Have a Braun series 8000 shaver battery not charging
Well if it's not charging at all and you are not getting any lights, then you could have one of two issues. Either you have a bad power cord or PCB board. If it's just not holding a charge then you can replace the Batteries.
Sep 23, 2008 | Philips Philishave HQ7780 Electric Shaver
Philips Philishave HQ7780 Electric Shaver Logo
1,009 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
xxxxxx xxx
rostit
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
