Question about HP Pavilion dv9000z Notebook
Message that battery needs replacing last week but it was still going
HP DV9500 wont power up. The power adapter light is on and when i turn on the laptop the light on the front blinks 3 times
    Scholar:
  • 100 Answers
Remove the battery and ac adaptor. also remove any peripherals.
Make sure that ac adaptor is working ok
Then press power button and hold that for 20 seconds to statically discharge the notebook. Then plugge that into the mains (without battery) and try to turn on. IF Notebook will not boot. Call service as mainbord needs to be replaced.
Posted on May 27, 2009
Hp dv 2500 mb-ct:P74511B2DV33T2 p/n GS846UA#ABA s/n 2CE7380QWD Laptop wont boot Lightning led flashes three times with or with out battery. Have done hard reset. Battery wont charge,blue power input...
My HP flashes 3 times when my battery is dead. Because of this I'm guessing that the AC Adapter is not working properly because it should turn on even with the battery out as long as it's plugged in. Many power adapters have a light on the actual converter box, you want to take a look for that light. If it is on, there is a problem with the cable and/or the connections between that box and the computer. If it is off, try another outlet. If you've done all this troubleshooting I would probably recommend getting a replacement AC Adapter. They are specific to the computer so make sure you purchase the correct one. Last time I replaced one the cheapest I found one (Dell Inspiron 1525) was @ Amazon.com
May 05, 2011 | Computers & Internet
I HAVE A HP PAVILION DV9700 I DO NOT HAVE A POWER ADATOR CAN I RUN POWER FROM MY OTHER PC TO THE DV9700 TO POWER IT
As long as the adapter you are going to use matches the specs of the required adapter, you shouldn't have any problems, check ebay for a replacement
Feb 24, 2011 | HP Pavilion dv9500 dv9600 and dv9700 FF...
3 weeks ago My Laptop HP Pavillion Entertainment system DV9500 shut off while I was using it and now it doesn't even power on. I purchased a new power supply thinking that was the problem but still can't...
unplug the ac adapter from the laptop and remove the battery
press the power button for about 5-10 secs
while the battery is out, plug in the ac and turn on the computer if still doesnt turn on
use a known good adapter and plug it in if it still doesnt work then motherboard needs to be replaced
hope this help
Sep 07, 2010 | HP Computers & Internet
Dell Mini 10 Won't turn on. When I press the
try to power drain pc first. to do that, turn pc off, remove battery and ac adapter. press down power button for 15-20 sec, then but all back in and try to turn pc on. if still no go, you may need to replace battery or ac adapter, f it still wont work, possible motherboard replacement is needed.
Mar 29, 2010 | Dell Inspiron Mini 10 Notebook
Hp dv2500 wont turn on
does the laptop plug in tightly to the power socket
if not the pavilion part to get the system power needs replacement
contact a local technician and state the power adapter plug-in on the motherboard needs replaced
these commonly go bad on pavilions
it should cost you less than 100usd to repair
or rma the laptop if you have warranty coverage left on the hp dv2500
good luck
Sep 28, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
My comp shut off and wont turn on anymore.. lightening bolt comes
Please remove the battery and ac adapter and then press and hold the power button for 25 - 30 seconds after that connect the battery back and then try to turn on the machine. if not remove the battery and just plug in the adapter and then try to turn on the machine. If still not working then try to swap the ram. or else your system motherboard requires to be replaced.
Jul 15, 2009 | HP Pavilion dv6000z Notebook
HP Dv9500 not charging battery
Sounds like the AC port is faulty, these can be a real pain to get hold of replacements and a complete nightmare to replace if you are not very experienced with a solder iron! my advice would be take it to your local computer centre to have the port replaced but expect to pay around £70. if you do attempt to do this yourself you will need solder wick to soak up the solder holding the port in, a very steady hand and time.
Jul 02, 2009 | HP Computers & Internet
Dell inspiron 1501 work fine turn off last night now wont turn on
You mentioned trying a different battery, try a different AC adapter.
When plugging in the ac adapter to the wall, see if the POWER LED comes on on the adapter, then when you connect it to the computer, see if the LED stays on.
If the issue occurs with both AC adapters (No battery installed) then the motherboard has failed. If one ac adapter works but the other doesn't then the adapter is bad
Feb 01, 2009 | Dell Inspiron 1501 Notebook
NV3 Camera - won't turn on or charge
have been having the same problem. Just pulled the lead out straight and stretched it and now it is charging red light on constantly. May have been a kink in the lead?
Jun 24, 2008 | Samsung NV3 Digital Camera
HP Pavilion dv9000z Notebook Logo
227 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
