Question about Whirlpool 18.2 cu. ft. Top Freezer Refrigerator ET18PKXG
We can't replace the capacitor because the value is erase. i don't know the right value.. And is there an specific starting relay to use? Or is there any compatible capacitor and relay for it?
What is the value of running capacitor in refrigerator model: SJ-D48G-GY? We change the capacitor and relay but the capacitor is heating and the power is turning off and on..
  • Whirlpool Master
  • 4,654 Answers
The capacitor would need to be checke when not connected to power. There may be another reason for the capacitor and relay heating. For example the motor winding are breaking down or the wiring to the compressor is incorrect. below is a photo of where to locate the model number of your refrigerator. I will help you if you like, Thanks, Sea Breeze
Posted on May 27, 2009
Need to know the exact value of capacitor about msi 848p neo2-v .the capacitor beside processor b'coz i want to replace it since the motherboard is not my hand. somebody know the pls tell me.. th
Hello here is the homepage:
http://www.msi.com/product/mb/848P%20Neo2-V.html#/?div=Manual
The value is printed in on the capasitors.
You can unsolder them but, mark the location where it goes
and remember plus and minus.
This will probably cost the same, as a new mainboard to renew them all.
A electronic repair shop, can order the capasitors for you.
A brand new mainboard, is sold today for around 100 dollars, in a online shop.
Your mainboard has socket lga775, so you don`t need to buy a new cpu, but you probably have to buy a new windows, and ram modules as well.
Good luck
Jan 13, 2013 | MSI 848P Neo2V Intel 848P Socket 775 ATX...
Tip
Hard Start Capacitor A hard start capacitor, its only purpose is to add...
A hard start capacitor, its only purpose is to add additional starting torque when the compressor is starting and for just a few milliseconds.
It is wired thru a normally closed set of points in a potential relay and in parallel with the run capacitor, when the compressor is starting the start capacitor is in the circuit adding additional starting torque to the compressor, when the compressor reaches a certain speed it generates enough back EMF (voltage) to energize the potential relay coil and open the normally closed set of points and take the start capacitor out of the circuit and then will stay open, keeping the capacitor out of the circuit as long as the compressor is running. The hard start capacitor is only in the circuit or working for a few milliseconds, it’s not doing anything once the compressor s back EMF opens the potential relay coil.
These potential relays have different cut in and cut out voltages, so the same relay won’t work with any compressor and may actually damage the compressor or shorten its life if you don’t use the right potential relay. The compressor manufacturer and the local parts store list the correct capacitor, start relay and start capacitor for every compressor and now they are putting the information on the compressor on the nameplate with the model and serial number.
As a rule of thumb you can use a capacitor or start capacitor within 10% of its rating if you can’t get the correct one.
on Feb 17, 2010 | Heating & Cooling
How much micro frard will i use for air compressor 0.5 hp
I don't believe there is a standard value for a specific horsepower rating. I have serviced and replaced plenty of these capacitors and the manufacturers say it is important to use only the value that the motor is originally supplied with. I have not seen it correspond to horsepower directly. Some motors use both a start and a run capacitor and I've never seen them identical. Horsepower listed ratings can vary wildly if it is not directly listed on the motor spec label. I believe .5hp corresponds to about 6 to 8 amps at 120 volts.
Oct 16, 2012 | Air Tools & Compressors
I have a pair of Goodmans Magnum SL speakers. Crossover capacitors.
The capacitors in my Magnums are 3.3uF and 8uF and don't need replacing as they are the foil type (which essentially last forever) rather than non-polar electrolytics (which fail after about 10 years).
Apr 06, 2012 | Audio Players & Recorders
Turned it off, now it wont turn on, can hear relay click when pressing power button, power LED on front is always on, no picture no sound, if I unplug for 30 mins, when I plug it back in I believe I can...
Good day!!!!
If you hear a clicking sounds of relay inside that means your TV have a voltage on the power supply section.However,when the high voltage attempt to switch the voltage will dropping down and the TV won't turn ON that,s why you hear a HV (high voltage) charge or what we call HV (high voltage) oscillation..
That problem is commonly cause of faulty capacitors on the power supply section..You can easily identify the bad capacitors if it is look like bulged/dome or sometimes leak in oil but not all faulty capacitors have an obvious indication like that because sometimes faulty capacitors look like good but the actual capacitance value change its either lower or higher than the original capacitance value.In that case you a special tester called capacitance meter to identify the faulty capacitors..
This is the sample image of bulged/dome capacitors.
Please let me know if you found any bulged capacitors on the board..If that so kindly replace it only with same type,ratings and value..You can buy it locally or online and if you want sir I'll be the one search it online just give me the value ex.2200uf/50v. uf-means microfarad and v is for voltage..
If you can't find any bulged capacitors let me know,maybe that is time to proceed for advance troubleshooting.In that case you will need a multimeter tester for voltage checking..in this stage you need a moderate technical skills to perform this kind of troubleshooting this stage not advisable for the non-pro so let me know if you have any electronic background..If you don't have electronic background as much as possible I can't advice that because its too dangerous..I can diagnose the problem base on what you see and observation..
Just keep on touch!!!!
Hope it helps..
Try to watch this video on how to replace bad capacitors..
Jan 14, 2012 | Hitachi 43FDX20B 43" Rear Projection...
My problem is, how can i know the value of a damage capacitor which is exploded, innovision mag crt monitor..
For your information there is no value of a damage capacitor. It may damage transistor. So there is a complicated network of caps and coils with relay switch. You have to removed each cap and checked it for short,open, and correct capacitance. Replace the capacitor soon. Purchase a compatible capacitor and solder it.
Mar 29, 2011 | Mag Innovision InnoVision 800 Monitor
Can i replace a 3300uf 10v capacitor with a 400v 22uf capacitor
The short answer is no. You can replace a 3300uf 10V cap with a cap of similar value but a slightly higher voltage (3300uf 16V or 25V).
Changing the capacitance value will significantly alter the circuit. Please note that the value listed suggests that it is a component in the power supply, specifically a filter cap.
Dan
Feb 26, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Miele freezer too cold -35
I've just fixed this problem with a Miele 7132S. It was a capacitor on the electronic circuit board. A very simple job to replace and cost about £2. I got the solution from another poster wonkothesane on diynot.
Note that the electronics is connected directly to the mains supply so remove the plug from the wall before you start!
The module is simple to remove: open the freezer door and under the module are three slots with catches - just push each in turn with a small screwdriver and pull the module gently forwards.
The power supply uses a 0.47uF 275V Class X2 capacitor which had gone low value so there was insufficient voltage to operate the relay. The compressor is connected to the normally closed relay contact so the freezer runs all the time.
For safety reasons it is critical that you only replace this capacitor with exactly the same specification component as you remove!
While I had the thing apart I also replaced two electrolytic capacitors in the power supply, a 100uF 50V and a 470uF 10V.
Sep 04, 2009 | KitchenAid Superba Architect KSCS25INSS...
My sony KV32 FX65B trinitron stopped working.. i took it to a technician and he said i needed to replace the FBT (fly back transformer) along with two transistors. I just replaced them and when i start...
When it is shifted to right vice versa, it indicates a distortion on the horizontal output. Try replacing all the capacitors around the horizontal output area with the same original value. Make sure the horizontal output transistors you replace hasn't started going gone bad already if you know how to check them. Them dimness in the picture is caused by the horizontal output not putting enough high voltage to the CRT. Look for leaking capacitors too. Also replace the resistors around the horizontal output, they may have burnt out or changed in value from overloading cause by the malfunction of the flyback, and the transistor.
Jun 27, 2009 | Sony FD Trinitron WEGA KV-20FS100 20" TV
Problem with capacitor of air conditioner?
the ratings of the capacitor should be on the capacitor itself in mfu sounds to me like the compressor stuck and cycling on overload is the capacitor distorted or swollen
Dec 29, 2007 | Heating & Cooling
Refrigerators Logo
299 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
