Question about Bosch WFL 2063 Front Load Washer
Drum not turning (WFL 2260)
Machine fills with water, timer switch makes appropriate clicking noise but drum/motor does not start working.
On rinse cycle maching fills with water but goes no further.
No problem on drain cycle.
On spin cycle nothing happens.
Have cleaned chamber bottom right and pulled the odd black plactic thing a few times to see if sensors are detecting some problem.
  • 5 more comments
  • setnic Oct 22, 2007
    Belt is fine but motor turning very easily by hand so suspect it is a motor problem.
  • sorentjensen Aug 27, 2008
    need to remove the carbon brushes how to proceed?
  • Anonymous Oct 31, 2008
    exactly the same problem as posted by Setnic
  • Anonymous Mar 20, 2014
    Water taken in but drum bdoes not turn. When on spin cycle the timer counts down but drum does not move. No blockages, filter clean all wires connected
  • Anonymous Mar 23, 2014
    Any ideas please,on a Beko WM 6143S that makes a crackling sound when draining. The crackling has now stopped,but on starting the washing cycle,it fills up, the drum turning as normal then does not drain ( you can't even hear the pump making the usual motoring sound). After about 5-10 minutes the machine switches off ( on 'Ready mode ) with the water still inside
  • Anonymous Mar 25, 2014
    sometimes it will run the cycle from beginning to end
  • Anonymous Mar 30, 2014
    the machine makes a clicking sound but then nothing happens
  • 64 Answers
Possibly the belt is off/broken? can you hear the motor turning when the drum is supposed to be revolving? If not supect the motor carbon brushes, or some other fault with the motor/and /or circiut, at best it may be a burned out wire to the motor
Posted on Oct 21, 2007
  • keith wagstaff
    keith wagstaff Oct 22, 2007
    ok then. back to my original response.  Supect the motor carbon brushes, or some other fault with the motor/and /or circiut, at best it may be a burned out wire to the motor. Have a look underneath for a broken wire into the motor.(tip the machine back & lean it against the wall),if no sign of a break suspect motor fault, could be carbon brushes which is fairly easy to fix
    MAKE SURE POWER IS OFF
  • jddramoore
    jddramoore Mar 26, 2013
    The wiring seems fine how do I check the carbon brushes
How to fit bearings in wfl 2260 bosch max washing machine
dose drum has to come out also replace element
Mar 02, 2015 | Bosch Washing Machines
Wfl 2260 5 years old The drum does not turn the
if you can here the motor running have you checked the drive belt is still fitted to the drum,,,they fall off at times or wors still they brake,,,
Jul 04, 2010 | Bosch WFL 2063 Front Load Washer
Machine doesn't start, just clicks like it's trying to reset
That clicking sound is most likely from your overheat safety switch located on the motor. This trips when there is too much bind or friction from the drum causing your motor to overheat I would check the drum bearing first by trying to turn the drum on your machine from the door area.
If it turns, it may be ok, but just to be sure, take the rear cover from your machine and remove the belt on the large pulley, then try starting the machine again. If you hear a hum and the clicking goes away you most likely have a bad drum bearing.
Mar 24, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
WFC 2260 - Machine Fills and empties, but drum doesn't rotate
You probably need to replace the brushes in the motor.
Remove rear panel, remove belt from drum, undo 2 screws securing motor, unplug lead to motor, lever motor back with a screw driver, keeping hold of it, and remove motor.
You will find the brushes located at the opposite end to the motor pulley.
Please leave a fixya rating for my proposed solution.
Thankyou.
Feb 03, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Maxx WFL 2260 not draining - nothing in filter - help?!
sounds like a simularproblem i had, a 5cent piece got caught in the drain solenoid (just between the drum and solenoid) , i had to lift up the front and spin the drain pump fan, on empty, then disassemble and clean pump assy and remove 5cent piece, hope this helps.
Jan 25, 2009 | Washing Machines
WMA54 Hotpoint Aquarius drum does not turn during wash or spin
Start checking the lid switch, if this is stuck the machine wont start.
If the drum does not move at all, the motor, the motor control unit, the motor coupler, the control board may be faulty.
For more details you need to observe if machine is draining and pumping water inside during cycle, see: It doesn't spin
Jan 06, 2009 | Hotpoint WMA54 Front Load Washer
Bosch Maxx WFL 2260
My drum stop, then I put in new carbon brushes. It works very good in 2mouth, now it stop again. Wht can be problem?
Jan 17, 2008 | Washing Machines
Bosch WFL 2063 Front Load Washer Logo
588 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
