Question about Dell Vostro 1000 Mobile AMD Sempron Processor 3500+ 60GB/1000MB PC Notebook
Hear power on, black screen. wont do anything.
Push power button and it tries to come on. I can hear it running, and power light is on. screen stays black, wont do anything.dell vistro 1000
  • kobilb May 27, 2009
    There was no display on both laptop and external monitor. So it looks like I have to get it serviced. Thanks for your tips.
    Novelist:
  • 79 Answers
Two suggestions:
Toggle the display by pressing Fn+F8 (Function key+F8). Wait a few seconds between attempts in order to allow the system to switch display ports.
Attach an external display to the system and power it on. Once you think it has had time to boot, toggle the display as described above.
Do Either displays work at any point during either test?
If no, the display chipset on the system board has failed & the system board would need to be replaced. If only the external display functions then you have a failed LCD, or the cable/connectors between the LCD and the system board are suspect.
Posted on May 27, 2009
  • 3 Answers
- try to connect you machine to an external monitor
- if the display appears on your external monitor the problem would be the LCD screen of your laptop (need to replace it)
- if there is no display on both laptop and external monitor i suspected it's the motherboard faulty
- send your laptop to service center to replace it (if it is underr warranty it's free
  • prez012 May 27, 2009
    your welcome! :)
I have a black screen when i push the power button, it wont turn on but i hear the fan
i have had a problem like this but im not sure if its the same.
I had dropped my laptop and the whole thing just went black. i would press the power button and the power light would come on but the screen would just stay black and the eventually when my laptop heated up the fan would go on but still there would be a black screen. I later realized that my motherboard had been damaged. and this is a very serious problem and new motherboards cost nearly just as much as the laptop itself.
So if you have the same problems as i had then your motherboard has been damaged and you will have to get it replaced
Jan 24, 2013 | IBM Thinkpad T43/p Notebook
When i turn on my laptop i see the vaio symbol and then the screen goes black. nothing after that. i read a little about it on the net, and apparently it could have to do with static electricity when...
2 things it can be
  1. dc jacks bad to find out take battery out and try to turn it on
    you may have to wiggle it to one side to get the power to work but if this works and u dont get it fixed right it will kill the motherboard that just the way to test it
  2. leave it running and try to see if u see or hear anything
    if u just let it sit if u do see i light image that the bacl light or the inverter is out
Aug 31, 2010 | Sony VAIO VGN-N250E/B Notebook
HPW2338h goes black after about 3 seconds. Push power button on, it turns on and then black after 3 seconds. Power light on monitor stays on.
hi,
you can try to change the screen resolution with a spare monitor to a different setting, usually higher 1024X768, then unplug the old monitor and then plug in the flat screen. try different resolutions untill it submits. if you cant get it to run on your machine, take it to another computer and see if you can get it to run on that. if it wont run on either then you have a problem with the monitor. pawn shops usually have flatscreens for way cheaper than new..
jm
Dec 15, 2009 | HP w19 19" LCD Monitor
Screen stays either black or white
Replace the entire DAC board (board with power suplly going into it) for easiest solution.
Aug 19, 2009 | ViewSonic VA703mb Monitor
Acer Aspire one screen stays black
i have this problem 2 days ago.. and this works on me... maybe on your's too you may need to flash your bios. why need to flash the bios.. ? 1. had the black screen of death. or deleted the bios how to flash the bios: STEP 1.download the AA1 BIOS from this link: http://www.acerpanam.com/synapse/data/7117/documents/AS1_BIOS_3309.zip 2. extract the file 3. rename the file 3309.fd to zg5ia32.fd 4. put zg5ia32.fd and FLASHIT.EXE onto the usb drive now, start the process STEP 2 A. make sure the power cable is in B. the laptop is turned OFF C. Plug the usb stick in! STEP 3: Press and HOLD down the FN and ESC key together then press the power button, while holding the buttons release the power button and continue holding FN and ESC for about 5 seconds release the buttons and the power light will start to blink let the laptop run and DO NOT PRESS anything this can take upto 8 mins when it's done the laptop will restart. this works on me... good luck.. and i hope it will help you.....
Jun 15, 2009 | Acer Aspire One PC Notebook
Getting power but wont boot up or anything
pull out everything in the computer except what's required to boot...so any pci cards or video cards (if you have onboard video). you can also try pulling out the ram (while unpowered AND unplugged) and then booting to hear beeps...if you pull the ram out and the computer doesnt make a sound, its probably a bad motherboard and needs to be replaced. if you hear beeps, try replacing the ram or disconnecting other parts...like harddrives, optical drives, modems and what not.
Apr 26, 2009 | E-Machines T2792 PC Desktop
Have a ws-42413 mitsubishi TV
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 08, 2017 | Televison & Video
MX 6124 Gateway notebook screen stays black when powering up
Repaired! This sounde like a fuelty screen or screen inverter. To check this, connect to an external monitor, if the external works properly, then it's the screen or inverter. If the external doesn't work, let me know and we'll run the problem down to a more indepth (internal) trouble shoot.
Jun 28, 2008 | Computers & Internet
Dell Vostro 1000 Mobile AMD Sempron Processor 3500+ 60GB/1000MB PC Notebook Logo
973 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
