Question about D-Link DI-624 Air Plus XtremeG Wireless 108G Router (790069250842)
D-Link Wireless Router Response Time
Respone time has recently gotten poor when utilizing wireless cards but fine when wired directly.
    President:
  • 2,961 Answers
Make sure you have the latest firmware version, then back up your current password settings and username etc, do a hard reset of your router and input the settings again from the back up and see if there is any change in the performance, but make sure you have a signal of no less than 24mbps ortherwise pages will not load, the reason for good connection via cable is you get a guaranteed 100mbps connection to the router.
Posted on Oct 21, 2007
My D-link seems not to be stable in connection to internets
Connectivity issues:
Network adapter power settings:
The first thing you'll want to do to prevent your wireless connection from dropping is to see if your computer is managing your wireless card's power. It may be instructed to shut off your wireless connectivity after a certain amount of idle time goes by. If you have system specific utilities, such as Dell's Quickset, make sure that the wireless power management isn't set to shut off the card if your computer is idle for a certain period of time. Second you'll want to check the settings on your wireless card via your device manager. In Windows XP
  • Right-click on "My Computer" and select "Properties"
  • Select "Hardware" and click on "Device Manager"
  • Find your wireless card under "Network adapters" and double-click it.
  • Verify that there aren't any auto power management settings enabled that might be shutting your card down prematurely
Adjust your wireless router settings
Nov 20, 2010 | D-Link DIR-615 Wireless Router
Can't get wireless to work on laptop
You may use the System restore utility on windows by going to all programs then Accessories... Open system Tools and then System Restore. You may resotre your system to an earlier time, time when you are still able to connect to your router wirelessly.
^_^
Jul 16, 2010 | Dell Inspiron E1505 Notebook
Have a wireless network through netgear WGR614 v6 working fine with 2 old ibm/toshiba laptops with vista and an acer on ethernet recently bought a new hp laptop with windows 7. This laptop gets very...
check if the laptop has wireless utility other than the built in windows wireless. (example intel proset wireless). if yes, uninstall the wireless utility and Update the wireless driver of your laptop by downloading the latest driver from ho web site.
Jun 10, 2010 | NetGear WGR614 Router
I have the DIR-655. Poor coverage/Signal strength
What kind of construction surrounds your router? Weak signal indicates walls reducing signal strength. Try a repeater in weak areas.
Dec 30, 2017 | D-Link Xtreme N DIR-655 Wireless Router
The router has #3 link/act lighted up (LAN) and when i connect to internet with router it says limited connectivity, but internet works fine with modem?
I assume you are getting this on your wireless connection.
Sometime you get this message because the computer's wireless card didn't get a issued with an IP address from the wireless router when you opened the browser. This can occur when you power up both the computer and the router at the same time, but the router had not finished booting up in time to issue an IP address to the computer.
You can right click on the wireless icon on the Task Bar and then click Repair, this will force the wireless router to issue a new IP address to the wireless card. When the wireless card gets an IP address then you can access the Internet.
Dec 01, 2009 | D-Link DSL-G604T Wireless Router
I bought recently a lenovo laptop (G450) loaded with windows 7. I have wireless internet in my home that I use with my other windows xp laptop and it works fine. I never ever been able to connect to the...
have the same problem.  even after assigning a valid address statically to the network card and connecting with a wired connection, i cant even ping the router
Nov 12, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Problem maintaining wireless signal
Changing channel wont help,you should use specific ip setting then automatic ip setting
Jan 19, 2009 | Dell TrueMobile 1184 Wireless Broadband...
D-Link Air DWL 650 connecting to my Dlink router
You need to go into the wireless driver advanced properties and set the SSID, WEP Key, channel and others. Wherever there is an 'auto' option, choose it.
I never got the dlink utility to work. I let windows manage it and change the device settings in advanced props.
Nagu
Oct 30, 2008 | D-Link Air DWL 650 802.11b Wireless...
Intermittent Enabling
First you can try to uninstall and reinstall the driver of the wireless adapter on that desktop. Unplug and re-plug the wireless card. If it is a wireless PCI card, make sure the antenna is tightly screwed on. Install just the driver of the wireless card and not the utility/software that came with it. You can also try to change the channel on the wireless router by going to the router's user interface. If you're on channel 6, choose channel 11 and save the settings. Then power cycle the router, unplug the power for 30 seconds then plug it back in. Check now if you can connect wireless.
Oct 29, 2008 | Linksys WRT160N Wireless Router
Wireless connection problem whenever I switch on my laptop
you need to isolate first which of the devices is giving you the problem.
- check first the connection from your modem by connecting a computer directly to it. check if you'll loose the connection from the modem. if so, you need to check with your internet provider if they're having maintenance from time to time since that could be the reason why the router is not providing the connection to your laptop automatically and you need to restart it to sync with the modem first.
- if you have a proper/stable connection directly from the modem, next thing to check is the connection from the router. check if your wired computers are getting the same problem. if so, you may need to check for loose/faulty cables or you may need to upgrade the firmware of your router. if the wired computers are not getting the same problem, it's time to check the wireless settings of the router.
* access the router's page by typing http://192.168.0.1 on your web browser's address bar (default username is "admin" while the default password is "password")
* go to the wireless settings page and check if the wireless name (ssid) is not the default. if it's still using the default ssid, customized it to prevent interference from other dlink network near your area
- if you have check the modem and the router, it's now time to check the wireless adapter, make sure that it is connected to your own network. if you are using it's software utility, make sure that you have created a profile using the same ssid as of your router. you can also update the driver of your wireless card if you have checked the above mentioned and you're still having the same problem
you can also try to use another wireless computer and check if it'll experience the same problem to properly isolate the if it's the router or the wireless adapter problem. you can also try to install the wireless card to another computer and check if you'll have a stable conection. if so, there could be a software (like a firewall or an antivirus software) that is giving you the problem.
hope this'll help you and just ask me if you have other concern.
ciao!
Jun 25, 2008 | D-Link 802.11g Wireless Router WBR-1310...
D-Link DI-624 Air Plus XtremeG Wireless 108G Router (790069250842) Logo
104 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
