Question about Apple 20gb Ipod Mp3 Player With Click Wheel System
My ipod says www.apple.com/support/ipod when i turn on my 160gb ipod it reads a big red x and the apple.com/support
    Problem Solver:
  • 13 Answers
This indicates that the hard drive inside the iPod classic has gone bad.
Check Apple's Warranty web page to see if your iPod is still under warranty: https://selfsolve.apple.com/GetWarranty.do
Simply type in the Serial Number located on the back of the iPod, and your location. Who knows, if you are lucky, you may be able to send it in to get it fixed/replaced for free.
Posted on May 30, 2009
    New Friend:
Www.apple.com support/ipod.com
Posted on May 06, 2013
4 Suggested Answers
PyroPCMan
  • 405 Answers
SOURCE: apple ipod 20gb
Try a reset:
How to reset iPod To reset an iPod with a Click Wheel, including:iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation)iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation)
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds.
You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector)Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Hope this helps
check out my blog at:
http://www.pchelpforanyone.blogspot.com
Posted on Apr 03, 2008
SOURCE: my ipod says www.apple.com/support/ipod
Try to put it in disk mode and restore it. If that doesn't work then you need a new hard drive.
ipod hard drive
http://www.ipodrefresh.com
Posted on Aug 13, 2008
  • 10 Answers
SOURCE: i turn the ipod on an it keeps on showing the
You need to restore your iPod from Disk mode:
  1. Before placing the iPod into disk mode, you should verify that it is charged.
  2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
  5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
  6. Open iTunes.
  7. After a few moments, your iPod will appear in the Source panel in iTunes.
  8. Select your iPod in the Source panel. You will see information about your iPod appear in the Summary tab of the main iTunes window.
  9. Click Restore.
Hope that helps.
Cheers.
Posted on Jan 03, 2011
Ipod is disable
Go to Apple and find out:
http://www.apple.com/support/contact/
Jan 20, 2013 | Apple 20gb Ipod Mp3 Player With Click...
Problem with ipod classic
Hi! YOu need to disconnect your ipod from the pc.
Put the ipod into diskmode by following these instructions-
ht1363_2.jpg Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect
After doing this open latest version of itunes and then restore your ipod to factory settings by selecting it from itunes.
Dec 29, 2008 | Apple iPod classic MP3 Player
My IPOD 160GB only shows the apple screen or a X in a red circle
my ipod is not charging and not coming on what i can do to fix it
Nov 30, 2008 | Apple 160 GB iPod Classic (Silver) +...
Ipod classic 160gb
http://fixyouripod.weebly.com/
Jul 02, 2008 | Apple iPod MA446LL/A MP3 Player
160GB iPod
Hey, watch this tutorial and try the things it suggest.
Id highly recommend, restarting, and returning the device into the original state.
All this is covered in the video here:
http://www.apple.com/support/ipod/tutorials/troubleshooting.html
If that doesnt help contact the appel support.
Feb 25, 2008 | Apple iPod MA446LL/A MP3 Player
Apple 20gb Ipod Mp3 Player With Click Wheel System Logo
471 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
