Question about MicroBoards PF-2 InkJet Printer
Pf2 not printing red ink with new cartridge # PRF38ML
Defective cartridge, contact Microboards and they'll send you a replacement for free if there is more than 80% of the ink still left.
Posted on Jan 19, 2010
Why won't a new tri-color cartridge print red?
Tri color cartridge contains Cyan,Magenta & Yellow color inks, mono cartridge contain black ink, combination/mixing with these inks desired color out put will prints on paper.. If any one or more inks are missing/dried, result mis matched print outs on paper.
In your case I feel it's Magenta ink is not firing..,nozzles may clogged, try to clean the nozzles with solvents & try it...If no result ,. replace the color cartridge..
Mar 28, 2015 | HP PSC 1315 All-In-One InkJet Printer
Ink red light on . which colour is out?
When red ink light flashes - one or more ink cartridges is low. When you print, a message on your screen will tell you which one(s).
When red ink light remains on - one or more ink cartridges is empty. When you try to print, a message on your screen will tell you which one(s).
Furthermore: When following the procedure for installing a new cartridge, if the red ink light was on or flashing, pressing the ink button will cause the carriage to stop with the cartridge that needs replacing under the "ink out mark" (ink droplet with a slash through it).
Jan 08, 2010 | Epson Stylus C66 Inkjet Printer
My Microboards PF2 does not print color properly.
The next to last cartridge I installed did not print properly. It seemed like all the colors were not there so I weighed it on a postage scale and it weighed less than another new one I had. I called Microboards. They said to send it to them and they replaced it. It may not be that, but weighing it should give some indication if it is.
Dec 07, 2009 | MicroBoards PF-2 Disc Printer
Pixma MP830 is printing things green that should be red
when you change all new cartridges (make sure all cartridge ok, and the cartridge pins connection ok) still red color lost, it is the trouble at print head ink chanel some of that is too dry for longer time less using , most CANON printer head is separated from the ink cartridge, two way you may try:
1) take out the ink cartridge, drop down a little the special cleaner (best clean tools buy from dealer), to the head ink chanel hole, then set back the ink cartridge and waiting minutes
2) try put the print head bottom surface touch a little cleaner or water 1-2 hrs, if you can take out the print head unit. still not fixed for some case that should change the print head unit.
Feb 06, 2009 | Canon PIXMA MP830 All-In-One InkJet...
New tri color ink cartridge will not print red
Probably bad, there's actually no way to check ink levels.
Jan 22, 2009 | HP DeskJet 960c InkJet Printer
Black ink too heavy - Microboards PF2
you can adjust the dry time. go to printer and faxes and right click select preference, there should be tabs select features then below should be advance features select that and there you can adjust the dry time and amount of ink.
Jan 18, 2009 | MicroBoards Print Factory InkJet Printer
Pf2 ink cartridege recognition issues
Sounds like you have either a defective ink cartridge, or the sensor that recognizes the cartridge is either dirty, broken or out of alignment.
Microboards will help you out at no charge if your printer is still under warranty. Otherwise you can contact an authorized Microboards repair center like
http://www.techwaredist.com/repairshop.asp
Apr 29, 2008 | MicroBoards PF-2 InkJet Printer
Hi I have just inserted a new HP ink cartridge 94 into my HP PSC 2350, as the ink was running low. I was printing photos, which keept printing with a red line throughout the picture. After inserting the...
Try opening the printer properties and cleaning the print heads (should probably be done each time a cartridge is changed), it uses some ink up but should clean the build up from running the previous cartridge dry and hopefully solve your printing problem.
Good luck.
Mar 29, 2008 | Computers & Internet
Only 1 copy at time
The previous poster is most likely correct. You have to use Microboards ink for the PF-2, PF-3 and PF-Pro printers. The part number you need is the PRF38ml. The PF-2 printer has a sensor for the barcode on the PRF38ml as well as a RFID chip for verification.
If this does not fix your issue, then the sensors that scan the barcode and the RFID chip may be broken, dirty or out of alignment. If so, you need to contact Microboards or an authorized Microboards repair center for repair services.
Dec 15, 2006 | MicroBoards PF-2 InkJet Printer
MicroBoards PF-2 InkJet Printer Logo
214 people viewed this question
Top MicroBoards Office Equipment & Supplies Experts
isaac johny
isaac johny
Tom Chichester
Are you a MicroBoards Office Equipment and Supply Expert? Answer questions, earn points and help others
