Question about Toshiba Office Equipment & Supplies
ERROR CODE CEE0 AND HOW TO RESET IT
WE HAVE AN ERROR CODE CEE0 ON A TOSHIBA E-STUDIO 451C MULTI-FUNCTION CENTRE. I LOOKED UP THE ERROR CODE AND IT SAYS THAT THE HOME POSITION OF THE TRANSFER BELT CANNOT BE DETECTED. I BELIEVE THERE IS A CODE THAT CAN RESET THE POSITION OF THE TRANSFER BELT - DOES ANYBODY KNOW WHAT THIS CODE IS PLEASE?
SOURCE: toshiba 160 error code
many thanks falz1982, your comments and the information given were very helpful.
Nasser Alaoui
Posted on Feb 13, 2009
  • 653 Answers
SOURCE: Toshiba e-Studio 232 is showing error message CF60
CF60 indicates Recycle Toner Transport area lock. U need to take out the process unit, remove developer unit, remove drum, drum blade & recovery blade, disposed all waste toner, make sure the gear can turn properly. Then reassembly back everything.
Posted on Jun 10, 2009
SOURCE: i need a master reset code for studio 550 toshiba PLEASE PLEASE P
error code c37
Posted on Sep 18, 2009
SOURCE: toshiba e-studio 161 error code H2?What reset
does not solve these problems H2? substituted for the other thermistors, but still nothing same error ... The whole problem of the scheme not remove the plug from the power supply and printer cable recorded the error, which now does not solve ... help ??????
Posted on Jan 18, 2010
  • 132 Answers
SOURCE: i am looking to reset
Hello
Fisrt off please hold down the 8+C buttons together, there will show a error code in the copy quantity display.
Now not knowing what the error code is, i am going to hope that it is C44 that is the most common
error code on the E163 machine. If it is C44 please do the following.
Switch off the machine.
While holding down 0+8 buttons, switch on the machine.
When ad shows on the display, input 400 then press the start button.
If the value is not 0, input 0 button and press the interupt and energy saver buttons to save the change.
Switch off the machine wait awhile and then switch the machine on again.
The problem should be sorted out.
If the error code is not C44 you will have to let us know what the error code is, by holding the8+0 buttons down together.
Here is hoping the machine is working
Regards
Posted on Apr 16, 2011
Toshiba e studio 451c error c360
replace your toner sensor or tdk sensor
Feb 13, 2014 | Toshiba E-Studio 3511 Color Copier
MY TOSHIBA E STUDIO 451c HAS AN ERROR F100 CODE. WHAT DOES IT MEAN?
That code error meaning that you have a problem with HHD
1st you reboot your machine with push 0+8 than 690 start 2 set(interrupt).
If it don't wok you mast replace your HHD with a new one from Toshiba.
Aug 11, 2012 | Toshiba E-Studio 3511 Color Copier
I am looking to reset my toshiba studio 163 spanner signal.the machien stoped functioning. i need he reset code.
Hello
Regards
Apr 15, 2011 | Toshiba e-Studio163 Copier
Toshiba colour photocopier jamming when copying or printing in colour. error code cee0. O k in black
"CEEO" indicates Transfer belt position detection abnormality.
U need to service the transfer belt unit, especially the reflection tape and sensors.
Apr 01, 2011 | Toshiba E-studio 281c Copier
En toshiba e-3511 sale codido de error CEE0
CEE0: Transfer belt position detection abnormality (normal speed):
The home position of the transfer belt cannot be detected.
This likely means that your transfer belt has gotten ripped. There are reflective strips on the transfer belt that tell the copier what position the entire belt is in before copying, and when the transfer belt gets ripped it causes the machine to not be able to find these strips.
You will need to replace the transfer belt and it would be a good idea to change the belt cleaning blade as well.
Aug 30, 2010 | Toshiba E-Studio 3511 Color Copier
Toshiba 451c Color Copier experiencing error F105
Hi how are you this is jack my personal Id (jack_pak@hotamil.com)
Dear follow the procedure .....
Other service call
[F105] HDD other error
(1) Check if the connectors of the HDD are disconnected.
(2) Check if the connector pins are disconnected or the wires of harnesses are open circuited.
(3) Perform the bad sector check (08-694). If the check result is OK, recover the data in the HDD. If
the check result is failed, replace the HDD.
(4) Replace the SYS board.
Thanks
Best Regards,
Jun 30, 2010 | Toshiba Office Equipment & Supplies
CEE0
Hi how are you this is jack my personal ID..(jack_pak@hotmail.com)
Dear follow the procedure step by step.
[CEE0] Transfer belt position detection abnormality (Normal speed)
If the error [CEE0] has occurred, check the transfer belt home position sensor-1. If the error [CEE1]
has occurred, check the transfer belt home position sensor-2.
Is there any stain or scratch on the reflection tape inside the transfer belt?
YES Clean the transfer belt or replace it.
Replace the cleaning pad if it is excessively stained.
NO
Are the transfer belt home position sensors-1 and -2 stained?
YES Clean them.
NO
Are the transfer belt home position sensors-1 and -2 working properly?
NO 1. Check if the connectors or joint connectors of the transfer belt home position
sensors-1 and -2 are disconnected.
2. Check if the connector CN361 on the LGC board is disconnected.
3. Check if the connector pins are disconnected or the wires of harnesses are opencircuited.
4. Check if the conductor pattern on the LGC board is short- or open-circuited.
5. Replace the transfer belt home position sensor-1 and -2.
6. Replace the LGC board.
YES
1. Check if the conductor pattern on the LGC board is short- or open-circuited.
2. Replace the LGC board.
More information please mail me ...
Thanks
Best Regards,
Jun 18, 2010 | Toshiba E-Studio 3511 Color Copier
Don't know the password for Toshiba estudio 450.
default password is 12345 for toshibas...go into user functions, administration...
everything is there...
Jun 18, 2009 | Toshiba Estudio 200L Copier
How to reset password for Toshiba 451C - Administrator
Password you will not be able to clean. Thera no this function in manual, you will help only in service centre Toshiba. Thank you. Good luck
Jun 10, 2009 | Office Equipment & Supplies
F120 fault on Toshiba estudio 232
HOW TO RESET ERROR CODE F-120 IN TOSHIBA STUDIO 232
Jul 09, 2008 | Toshiba e-Studio 232 Black and White...
902 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
