Question about Microsoft Zune JS8-00001 Digital Media Player
My 30gig zune is froze and unresponsive. Please help
I have the 30gig Zune. I kept having big problems with it. It Ususally cleared itself up, but one day it just kept freezing so I turned it off and back on. When I turned it back on it became frozen of the please wait screen 3. It will not let be turn it back off. It does not respond to any buttons at all. I need help.
  • 393 Answers
There is a "lock" button on the top on the left side make sure this switch is turned to off.
Try one or more of these solutions to resolve this problem:
  • The Zune may be locked. Move the hold switch to the unlocked position. It may help to move the switch back and forth. Then press the play/pause button for a second.
  • The battery may be drained.try recharging it
  • To reset your Zune, press and hold the back button while pressing up on the Zune pad. Resetting turns Zune off and on again.
Posted on May 27, 2009
My zone is frozen and won't respond to any key combinations
plug it into the back port of your computer or plug it into a wall charger
Aug 23, 2009 | Microsoft Zune 2nd Generation Digital...
ZUNE FROZE WITH LOGO AND PROGRESS BAR
This is a fatal error porblem. If you go to the Zune Microsoft website you will find many others have the same problem. There is no fix for it as of yesterday afternoon. We have had problems with our 30 and 8 gb Zunes and finally returned then to Best Buy and got IPods.
Jan 01, 2009 | Microsoft Zune JS8-00001 Digital Media...
My Zune froze from using the wrong charger
Reset Zune: Press and hold the back button while pressing up on the control pad.
Connect Zune to a power source: If the Zune device is in sleep mode, this action will wake the Zune device and turn it on. If the battery does not have a charge, you may have to wait several minutes for the Zune device to turn on.
Also, make sure that the hold button on top of your zune is turned to the off position.
Hope this helps!
If this helps Rate this a FIX-YA.
Jan 01, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My Zune 30GB is frozen on the start up thing!
Disassemble and disconnect the battery for about 10 seconds. All Zune 30's apparently siezed this AM. MS is working on their solution, not sure when it will come out. The battery disconnect is at least a temp fix. Mine works fine after doing it.
Dec 31, 2008 | Microsoft Zune JS8-00001 Digital Media...
30GB Zune Froze
all of the zunes 30gb in the world went dead last night go to zune support.com and request a repair they will be helping you soon .
My zune is froze up
reconnect to a computer with zune software all 30gig zunes had a newyears bug they should all work now once connected to a pc
Dec 14, 2008 | Microsoft Zune JS8-00001 Digital Media...
Zune 80 GB - Won't Charge
my 30gig was doing same thing i opened it up and one of cables just slipped out of port very simple to fix open you zune where the charger goes in there is a black cover remove this carefully then remove the 2 very small screws next use a very thin flat surface be very careful and you can see the edge where it seals just put you thin applient into the side and gently pull it up go all the way around once at top be gentle dont use the knife or whatever you used just slide it appart the back will come off then just reconnect cables good luck
Sep 30, 2008 | Altec Lansing M604 Computer Speakers
Rello 30gig zune need help
you can try and reset it by holding on the back button, and up on the d-pad. that should work it did for my 30 GB
Jun 20, 2008 | Microsoft Zune JS8-00001 Digital Media...
Zune Froze, erased content, and wont sync with PC.
Yes. There are several solutions to this. Rather than retype them, you may want to check out the forums at www.zune.net or support.microsoft.com.
Most likely you'll have to remove the Zune software from the PC, re-install it, reset the Zune.... I think you get the picture.
May 20, 2008 | Microsoft Zune JS8-00001 Digital Media...
Microsoft Zune JS8-00001 Digital Media Player Logo
383 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
