Question about Microsoft Computers & Internet
Auto cad internal error problem GEDIT 3
When I sign in to auto cad and start working on any drawing I get an Internal GEDIT 3 error pop up and it closes cad down how do I fix this problem I am using cad on my compaq lap top and have for some time now this problem just recently started I removed cad from the system re started the computer and re installed the program and it started again please help if you can Larry Poplin lpinvegas@msn.com 702 400 7469
  • Microsoft Master
  • 4,806 Answers
Hi there.
Uninstall AutoCad again and download CCleaner from here >>>>
http://www.filehippo.com/download_ccleaner/
Once downloaded use the cleaner to get rid of any temporary files that are in hidden folders on the computer then use the registry cleaner to remove any registry entries or unused file extensions.
You will see in the screen shot CCleaners registry tool, where is says scan for issues click on that, once it's completed click fix selected issues, it will ask you if you want to back up to the registry, click on yes and save, keep on scanning for issues until it says no issues found.
Restart the PC and then reinstall AutoCad, hopefully the problems will be solved.
Please post back with the results.
Good luck and thanks for using FixYa!!
Posted on May 27, 2009
How to disable the video on a A780L motherboard
North Bridge Co nfig uration
BIOS SETUP UTILITY
Chipset
vxx.xx (C)Copyright 1985-200x, American Megatrends, Inc.
Select Screen
Select Item
Go to Sub Screen
General Help
Save and Exit
Exit
Enter
F1
F10
ESC
NB Chipset Configuration
NB CIMx Version : 4.4.0
> PCI Express Configuration
Primary Video Controller [PCI-GFX0-GPP-IGFX]
NB Power Management Features [Auto]
> Internal Graphics
Internal Graphics Conf
Internal Graphics Configuration
BIOS SETUP UTILITY
Chipset
Select Screen
Select Item
Change Option
General Help
Save and Exit
Exit
F1
F10
ESC
Internal Graphics
UMA Frame Buffer Size [Auto]
FB Location [Above 4G]
AMD 780L HD Audio [Enable]
Internal Graphics Mode [UMA]
Surround View [Disabled]
Options
Disable
UMA
T his item allows you to select the memory mode used for internal graphi cs device.
Options: UMA (Default) / Disable
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwiwq5ik2rXQAhWKP48KHU--AYMQFggcMAA&url=http%3A%2F%2Fmediapool.getthespec.com%2Fmedia.pdf%3Fm%3DQNJ2kCQfmVPhBYToYbwEQw%253D%253D%26v%3DPD&usg=AFQjCNGEH6Nge9c54_Uk8domc9vJiL0eTw
Nov 19, 2016 | Computers & Internet
Need schematic drawing of Kitchler 15E120BK
1) Kitchler 15E120BK has same operating manual as Paradise GL22730:
http://waterheatertimer.org/pdf/Paradise-GL22730BK-transformer.pdf
2) There is no internal schematic drawing or CAD drawings that I can locate online.
Dec 29, 2012 | Kichler TRANSFORMERS - PROFESSIONAL SERIES...
I have a MARANTZ ARCH and it has just started to develop problems with the cd draw it opens and closes fast a few times then will open and close normal also the flap will fold down draw will come out the...
If the system is less than 3 years you still qualify for manufacture warranty, usually it is accumulated dust, you can open the system's case and clean with a dust cleaner can, you can buy at staples, best buy, radioshack, and any major store.
If dust is not the problem than is an electronic problem, there is one electronic component that is in charge of closing the flap at xx speed. If that one is burnt out you can replace it, I recommend you have an electrician look at the circuit. or Contact the Marantz for warranty at: http://us.marantz.com/us/Support/Pages/ServiceCenter.aspx
May 24, 2011 | Marantz Arch 1.0 Shelf System
My dvd does not play error 10 device manager and yellow sign optiarc dvd rw ad 7563a ata device
Is this an internal or external drive? if it is an internal one then on the device manager screen where it is hows the yellow sign on signoptiarc dvd rw ad 7563a ata device, right click on that an click on uninstall.....And if any pop up comes up click on ok and restart the pc after that. Wait for the pc to reinstall the driver for the dvd drive. And then check the status of the dvd drive on device manager. If it does not have any yellow sigh then try again.
Feb 17, 2011 | Gateway (5500652) (  5500652)...
I have owned a Acer V193w monitor.My problem is that when i work in Auto cad 2004, the shapes are not coming exact..........its like if i draw a CIRCLE in auto cad i can see that s not exactly as a CIRCLE...
I use Auto Cad and Solidworks aslo, you need to set your PC video resolution to the native resolutionof this monitor to get correct aspect ratio: 1440 x 900 @60Hz since this is 16:9 display.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Oct 23, 2010 | Acer Computers & Internet
How to unlock password protected auto cad files.
it appears that autodesk2_bing.gif did infact pull the command to unlock drawings from the newer apps. but the way to get around it is to find a file of the same name, only with a .dwk or .dwl extension, and then delete it. then when you open the drawing, it will run the recover command and fix it up for you to view and edit again
Jun 11, 2010 | HP Computers & Internet
I got a remote controll helicopter and when I installed the software for the Flying Model Simulator, it brings up an error saying that D3DRM.DLL IS NOT LOADED.. What can I do to run this program so I can...
The D3DRM.DLL file is the Dynamic Link Library for Direct3D Retained Mode, an older DirectX display technology that was not included with Windows Vista. Direct3D is used to render three dimensional images in applications where performance is important; the most common examples of which are games, CAD drawing programs and graphics editing software.
The error message displayed varies by program, but some some of the more common ones are:
  • "Failed to initialize Direct3D with current settings"
  • "Cannot find the file d3drm.dll"
  • "This application has failed to start because d3drm.dll was not found"
  • "D3DRM.dll is not loaded"
This error is usually a sign that the d3drm.dll file has been deleted, corrupted or altered in such a way that makes it unusable to your program.
To fix errors like this:
1. Install the latest version of Microsoft DirectX. It will fix the d3drm.dll error.
2. Uninstall the game or software program and then reinstall it again.
3. Update the drivers for your video card.
4. If it doesn,t work copy d3drm.dll file to the system folder.
Hope it helps.
Mar 18, 2010 | Microsoft Windows Vista Ultimate Edition
How do you fix the error 8001050f? i have a wireless connection to my wifi and its 100%, i can browse the web but theres an error when trying to sign in to psn. it was working just fine earlier toady.
same with me. i think you have to send it out to get fixed...i freaking out right now, almost got platinum on resident evil 5 and (8005010f) just popped out of no where
Mar 01, 2010 | Sony Playstation 3 (PS3) Console
Error message "the built-in flash's auto pop-up was obstructed. turn the power switch to off and on again" I've done that with no luck. Any ideas what to do?
the internal computer has got its wotnames twisted
remove the battery and replace This is a hard reset on the internal computer.
Please rate my help++++Thanks for using FIXYA
Nov 11, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Computers & Internet Logo
2,633 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
