Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Kenmore Elite Refrigerator Model 795.7756 (Trio)
Icemaker is not making ice. Instead, water is dripping from the icemaker. What is the correct arm position to make ice? Up or Down? I powered the icemaker on/off but this didn't help. I also pressed the button that cycles through, when the cycle is completed - the arm is in the down position but then slowly goes back to the up position. Any suggestions?
  • 1122 Answers
SOURCE: kenmore elite trio bottom freezer refridgerater 795 7555
there are 3 ways it can be held on,screws,snaps,clips or slides one way up or down or side to side,to make sure what you have get the model number from inside the frig. ,go to sears .com click on parts put in your model number and your whole frig diagram will come up and you will see exactly how it comes apart,let me know how you do-mike
Posted on Oct 01, 2008
tech master
  • 120 Answers
SOURCE: Kenmore 106.71192101 refrigerator icemaker doesn't produce ice
ok follow these steps to trouble shoot 1st remove white cover from front of ice maker there you can now see the module of the unit .that would be part number 35 on the parts list. 2nd get a 12 gauge insulated wire about 2 inches long and stripp the ends of it . insert it in the two holes in front with letter h and t live there for about 20 seconds now look at the forks inside are they moving if yes check fill tube for a plug of ice that wont let water fill the the ice maker if no they dont move repl that part 35 you can repl your self just disconnect unit remove the three bronze philip screws and pull out ahh but first remove wire harness so it will be easy to pull out ok thanks
Posted on Oct 17, 2008
  • 11 Answers
SOURCE: No ice from icemaker of Kenmore Elite model 106
I just resolved an issue with my kenmore elite side by side refrigerator icemaker (model 106).
It was expensive because I took the long road to fixing the unit myself.
My problem: No water going up to the freezer water dispenser into the icemaker but the water in front of the door working just fine.
-first thing i tried was the simplest. The Internet is clogged with this miracle fix of using a hair dryer to melt the frozen water line going to the dispenser output. This is highly unlikely for our model since the water line is protected within the refrigerator frame.
-2nd thing I replaced my water filter (thinking that there wasn't enough water pressure to trigger the solenoid valve. $40, and still no luck.
-3rd thing was I tested for voltage going to the solenoid. No voltage going to solenoid, so I wasted $30 for a new solenoid.....still no water.
-4th thing was I ordered a new IR sensor and receiver (since the reciever end is where the relay that sends the voltage to the solenoid to turn on and allow water to go up to the dispenser).
My IR sender and receiver appeared to be working flakey.
Installed, still no water. $58 BUCKS ON EBAY (EVERYWHERE ELSE $100+)
-I finally removed the freezer front little white door, I TURNED OFF THE FREEZER SWITCH SO NO VOLTAGE WAS PRESENT, removed the release latch underneath the freezer unit and disconnected, and removed the freezer unit to inspect it further.
When I removed the protective white cover that covers the mechanical wheel, I had a few parts come flying out of it. Turns out that the wheel accessories were damaged. THERE ARE NO REPAIRABLE PARTS ON THE FREEZER UNIT. I FOUND ONE ON EBAY FOR $39 BUCKS + $9 SHIPPING! $48 BUCKS, SWAPPED THE HARNESS AND BOTTOM COVER, AND IN 20 MINUTES, I WAS BACK IN BUSINESS. STARTED MAKING ICE IN ABOUT A HALF HOUR!!!!!
when in doubt, replace the freezer unit for $48 bucks! 7 out of 10 times it will fix your problems. All techs replace the IR set at the same time too which will set you back another $58 bucks.
Good luck! ;)
Posted on Mar 16, 2009
buffalonyman
  • 1865 Answers
SOURCE: Kenmore Elite Trio 22.4 Cu Fridge - Flecks of "Tin Foil" in Ice
Perhaps the solution to to change out the ice maker unit
Posted on May 03, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Posted on Jul 01, 2009
Water freezing in tube to icemaker
Change the water control valve because it is not shutting off once the ice maker is full. The valve is sticking open slightly once power is off to water valve. What is the model number of your Kenmore Elite Model numbers for Kenmore most times look like this example=> 321.456789 Sea Breeze
Kenmore Model Numbers
Apr 01, 2013 | Kenmore 26.5 cu. ft. Side-by-Side...
Replaced water filter on my Frigedaire refrigerator and it is leaking where the filter is it is making ice when the bar is raised for no more ice it does not lead but when the bar is down to make ice is...
The problem there is going to be one of 2 related causes.
The tube in the back of the icemaker where the water enters it is partially frozen and when the water comes into the icemaker some of it is spraying into the bin instead of filling into the icemaker.Remove the icemaker and check and thaw that tube.
That tube is out of place so once again instead of water filling into icemaker correctly some of it is running into ice bucket instead of icemaker.
Gene
Aug 11, 2011 | Frigidaire FRS3R5EMB Side by Side...
Our Kenmore Elite french door bottom freezer, automatic icemaker, no water/ice dispenser on the door - is leaking quite a bit - had to mop up the floor three times today. first time it's happened since...
Check for cracks in the water supply tube from the house plumbing valve to the ice maker. Could also be the valve itself.
Turn off valve for a day to diagnose which.
Oct 21, 2017 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
I need a repair manual for a kenmore automatic icemaker
we always replace the unit we not open it b/c there are very small parts that might get damage its 122$ but if u want to try take the whit cover and open 3 screws then the unit open and the arm can be change make sure u put all together correctly...good luck
Dec 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator icemaker won't work and refrigerator fills with wate
check your fill tube you might have an ice build up on the end
the fill tube is where the water dumps into the ice machine
Oct 03, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Funny fridge noise, kenmore elite trio
I have a Kenmore Elite Trio and the freezer was making a frog sound. I found the solution.
My model number is 596.75523400. The sound will stop when the freezer is opened. It will stop again when the freezer drawer is open and the light switch is pressed to turn off the light. The ice drawer was full but it had stopped making ice.
Here is the fix in less than 10 minutes using only a screwdriver.
  • Take out the two freezer baskets
  • Remove the freezer door from the two slide tracks.
  • Unplug the icemaker electric connection at the back wall. Depress the clips on the side of the plug and wiggle it loose.
  • There are 3 screws that attach the icemaker to the left freezer wall. Remove the lower screw and unscrew the top two about ½ way out.
  • Slide the icemaker up so the slots slip over the 2 screws.
  • Put the icemaker in the sink and run a bit of water on the frozen cubes until they fall out.
  • Take the screwdriver and check the water inlet hose/pipe for ice that obstructs the flow of water into the ice maker.
  • Re-mount using the 3 screws and plug in the electric connector. Make certain the water inlet tube is positioned thru the retaining hole before you remount the screws.
  • Replace freezer door and baskets.
Nov 01, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Error message
Hello gravyblast.
Welcome to Fixya.
You said, your Kenmore Elite Trio, model 795.7756 or 7757 has an error message simply reading ER IF. No pressing of buttons, or combination thereof changes anything. Also, the ice maker has stopped working although it is turned on.
Can anyone help?
I cannot pull the refrigerator out to unplug and reboot it, thus I don't know what to do.
Try tripping the breaker off for 5 minutes and then see if this method resets the system?
Do not turn it back on for at least tree minutes. That's why I said, Five!!!
Lets see how it resets while I look your fridge up.
Write back. Huuum
7:11 pm eastern standard time . I'm here!
Sep 17, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Apr 30, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore Elite Trio 795.7756 /7757 problem
I had the same problem, freezer full of groceries defrosting or crisper drawer freezing produce. Sears Appliance Repair sent servicemen out twice and both times I was assured the problem was fixed. After freezing produce the third time I insisted they come and get the faulty appliance. The replacement has worked perfectly since day 1. INSIST ON A REPLACEMENT
Sep 03, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
103 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
