Microsoft Visual Basic Enterprise Edition 6.0  for PC
Problem for Microsoft Visual Basic Enterprise Edition 6.0 (361-00667)...
Creation of connection object
By guruk2k5 on May 27, 2009
how can i create a connection object and recordset object to send a data from form(text box) to back end i.e.MS-Access. plz let me know connection provider(oledb) syntax
Solution #1
posted on Jul 14, 2009
Not Rated)
randyprevost
Rank: Wiz
Rating: 81%, 167 votes
A connection string combines all the information your web application needs to connect to a database. Dreamweaver inserts this string in your page?s server-side scripts for later processing by your application server.
A connection string for Microsoft Access and SQL Server databases consists of a combination of the following parameters separated by semicolons:
Provider specifies the OLE DB provider for your database. For example, here is parameter for Access:
Provider=Microsoft.Jet.OLEDB.4.0;
For the parameter value of your OLE DB provider, see your provider vendor?s documentation, or consult your system administrator.
Here?s an example of a connection string that will create an ODBC connection to an Access database called trees.mdb:
Driver={Microsoft Access Driver (*.mdb)};
DBQ=C:\Inetpub\wwwroot\Research\trees.mdb
Here?s an example of a connection string that will create an OLE DB connection to a SQL Server database called Mothra located on a server called Gojira:
Provider=SQLOLEDB;Server=Gojira;Database=Mothra;UID=jsmith;
PWD=orlando8
Was this helpful?
Yes
No
Popular Solutions for Microsoft Visual Basic
Questions and Unsolved Problems for Microsoft Visual Basic
Do you recommend Microsoft Visual Basic Enterprise Edition 6.0 (361-00667) for PC?
Answer
Answer
I have downloaded matlab but when I try to run it it comes up with ''error starting desktop''
Answer
I open a link with word document and I get code execution has been interrupted, and it asks me if I... (More)
Answer
I need a to design an application that contain two protein sequences. The second and first sequence... (More)
Answer
i wish to preview a text base report before printing . i used rich text file but the out put is... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Microsoft Visual Basic...:
Top Programming Tool Experts
Rank: Guru Guru
Solutions: 1409
Experience: I have owned a computer networking sales and service company.
Ask Me
Find more Programming Tool Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
