Question about Porter Cable CFBN125B 1 1/4" Brad Nailer And Compressor Combo Kit
Won't build pressure air compressor
I have two porter cable pancake air compressors they won't build pressure
  • 351 Answers
Most probably the one way valve in the heads unless the drain tap is opened
Posted on May 27, 2009
Porter cable pancake compressor will not shut off replaced manifold, still the same.
I would look at the pressure switch which shuts the electric off when the air pressure reaches its limit also check all wires going to and from this switch. Best checked with a multi-meter.
Feb 07, 2015 | Porter Cable Air Tools & Compressors
Porter Cable Pancake compressor builds pressure, but will not shut off when max pressure is achieved. Pressure switch is NOT the culprit.
Most P/C compressors shut off at 150psi. If the pressure switch is bad, the pressure will rise until the safety pops. If the safety is not opening, then most likely the cylinder / piston ring is worn to the point that pressure will not increase past safety range (cylinder could be scratched near top ). If cylinder and piston are ok, then air is leaking somewhere (check all joints with soapy water). Good luck
Sep 17, 2013 | Hitachi EC12 Portable Electric 2hp Air...
My Porter Cable Job Boss compressor won't shut off. It builds up pressure but just continually runs.
Pressure switch - replace as soon as possible
Overpressure would be possible in that tank - it is dangerous !
Oct 20, 2012 | Porter Cable 4 5 Gallons 150PSI Job Boss...
I have a Porter Cable pancake compressor Model CFFN250N-2 which worked great last year. This year I turn it on and it just continues to build pressur euntil the safety valve blows.
i think you have a problem with the pressure control. unplug the compressor and open the controller. check all the connections and really look it over. these pressure switches today just do not hold up well. sometimes there is enough moisture in the unit that it can freeze over winter and crack. if yours has a plastic hose to connect then check that over as well. check this site. they have a good parts break down ans look ar parts 111and 112 and 113. all called pressure switch service kit.
http://www.ereplacementparts.com/porter-cable-cffn250n-type-compressor-parts-c-129_1662_3092.html
Apr 24, 2011 | Porter Cable Air Tools & Compressors
My four-year old PC pancake compressor starts fine but only builds up 60 psi no matter how I adjust the pressure regulator. The compressor motor runs continuously. I checked for air leaks and can't find...
First take off the head on the air pump and check the reed valves on the valve plate. If they got hot and warped or cracked they'll work to a point then no more pressure can be built up. Next check the pistion ring and cylinder wall. If either is damaged you'll only get so much pressure build-up then it will leak past the piston.
Mar 07, 2011 | Porter Cable C2002 150 Psi 6 Gal...
The drain plug on my Porter Cable pancake compressor leaks so badly that it no longer build pressure. The compressor is just a little over 1 year old and I have always drained the compressor after each...
Yes...the drain valve on the bottom of the tank is just a standard 1/4 Drain Pedcock that you can purchase at most hardware store.
You can also find these in the hardware section of Lowes or Home Depot where they sell the Air Compressors.
Oct 24, 2010 | Porter Cable C2002 150 Psi 6 Gal...
Trouble building pressure
I would check the reed valves in the pump. One of them may be broken.
Jul 09, 2010 | Porter Cable C2002 150 Psi 6 Gal...
Air Leak From Pump Head on Porter Cable C2001 Pancake Compressor
The real question is where exactly is the leak coming from. Compressors have a pressure release valve designed to let the pressure off of the compressor motor so it can start when there is pressure in the tank. This valve is often the culprit and fairly easy to replace. You can order it direct from porter-cable online. Just in case double check the drain petcock sometimes these get worn and won't close completely and can easily be over looked when trouble shooting.
Jun 12, 2010 | Porter Cable 18 - Gauge Brad Nailer and...
Porter Cable CFBN125B 1 1/4" Brad Nailer And Compressor Combo Kit Logo
430 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
