After starting the motor cold (88ci) it runs for about 20 seconds then does a sort of putt like its not getting fuel or something and runs a little more then putts one at a time until it stalls, but once it starts waiming up it goes away, I've owed the bike for three years, it has 50,000 miles on the motor never had any issues with the motor until now, runs good and stong, i just don't know why its doing this now, I have a KN filter and Exhaust since I bought it so I've done nothing new to it, other than regular mentinence....
See if you have any error codes (DTCs).
To pull the codes:
1- Turn ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting should illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word "diag" should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module [Carbureted)
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC's the code will be displayed or the word "none" will appear if there are no DTC's. Push the odometer reset button again to view additional codes if they exist.
7 - Record the codes.
8 - If DTC's are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC's again by repeating steps 1 to 9. If the code is current it will reappear.
9 - Press and release the odometer reset button to continue to the next module.
10 - Turn ignition switch to OFF.
On models not equipped with a tachometer "No Rsp" will appear when the tachometer identifier is selected.
"No Rsp" will also appear if the run/off switch is in the off position when doing this procedure.
Also if the code set is a historic code (not a constant light) after 50 start and run cycles of at least 30 seconds each in duration, the light will extinguish itself as long as the error hasn't occurred again.
If it were a current code, the light would remain lit while running.
SOURCE: Running Fuel for 2006 Street Bob FXDBI
These bikes were designed to operate on REG. fuel. If you need a cleaner or feul additive to help use P.I. from Amsoil. If you are interested in saving money and fuel and on this product contact me and I'll show you how. [email protected]
Well,...either someone has toyed with the baffles inside the mufflers,or they have rusted,and are starting to come apart. My reccomendation would be to buy a set of aftermarket slip-ons,or a full exhaust system.Good Luck!
