Question about Intel Pentium III , 900 MHz Processor
Want to change my server
I have four computers, and I want to add another one, I want it to be my server, coz the specs of this is much higher than my server,what will I do make my additional pc to be my server???
  • ultimitloozr May 11, 2010
    What kind of server do you want it to be? What operating system are you planning on running on it? What services do you want it to provide? How fast is your current network? What kind of load do you expect to be placing on this server? This is just the start of a very long list of questions that need to be answered first.
    Sergeant:
  • 270 Answers
You can instal windows 2000 server with sp4.connect all pcs through chords
Posted on Jul 17, 2009
  • Bobin Thomas
    Bobin Thomas Jul 17, 2009
    you can instal windows 2000 server with sp4.connect all pcs through chords
  • Bobin Thomas
    you can instal windows 2000 server with sp4.connect all pcs through chords,
How do you play sound on a BenQ PC monitor with VGA no Audio Cables For a HP Proliant microserves Gen 8, I need help
it is a server not a PC, so no sound jacks there.
if you do see 3.5mm line out jack green there'
then it does have sound. easy no? or optical jack.
One can be added, in most or all cases.
If you look at the drawing in the manual here,its missing.
note lack of server sound jacks?
3.5mm or the like.
/9da35884-da52-49e7-ad7b-cf3fc44493be.jpg
Dec 31, 2017 | HP Computers & Internet
Hello i take from my work a proliant ml350 g5 can i put on this server a better vga card?
You can add the vga card just make sure it is compatible for your server board. You would not be able to take an SLI card in put in this server. There are many that will work, again check the expansion card specs on the server and make sure your vga card matches those.
Good Luck
N.I.T.
Jan 23, 2014 | Computers & Internet
Windows server 2008 raid setup on a dell poweredge 2850
2 drives indicates they are RAID 1, which are mirrored. 2 x 36GB = 36GB. This is an industry standard config. If you make any changes you will lose the array making it RAID 0 (no RAID - no longer hot swap), and or the complete loss of OS / data.
Instead make another logical drive for data storage. You need three or four drives to set up as RAID 5, again an industry standard config.
Make sure to back up in all instances. GL
Nov 14, 2012 | Dell PowerEdge 2850 3.8GHz 2u Server...
Thank you for the last one. know i want to set up mu 3laptops on the windows server 2008 r2 standered and use the server as a domain and the laptops as well like a domain.
first you need to setup the roles in the server, go to the manage server console, ( can be found as a shortcut in the taskbar or under start menu ) then open the console and go to add roles.
1 - add active directory
2 - in the process it will ask you to install the DNS server role ( do it )
3 - after installing the role in the CMD command prompt type DCPROMO
4 - the DC controller installation and setup will beging ( do not do anything during this proccess )
5 - when asked by DC setup to choose what type of domain functionality level do the following
1 - windows 2003 ( this is for compatibility for windows server running 2003 and XP machines )
2 - Windows Server 2008 ( at this point nothing lower than XP can be added to the DC of course domain functionalities will increase - Only other 2008 server domain controller can be added and cluster migration from server 2003 to 2008 is not supported. )
3 - Windows Server 2008 R2 ( at this point only machines running Vista and 7 can be added to domain - windows xp is no longer supported. All the functionalities of the domain controller are available)
keep in mind once you promote the domain controller to a higher level it can't be brouht to a lower level.
once active directory is installed restart you server and the you should be able to add the clients pc or laptos to the DC example
- right click over my computer icon
- click on properties
- computer name
- change the computer from workgroup to domain
- type your FQDN ( fully qualified domain name) example: mynetwork.local or mysite.com
- apply changes and restart
- your computer will be part of the domain next time system boots up.
Mar 01, 2011 | Computers & Internet
Acer aspire one no video
Check the specs of your laptop regarding the memory. If the new memory that you installed is compatible with your laptop or not.
Example: If your laptop handles like DDR 200 and you did installed DDR 300 or above with the limit or specs of your laptop, then it will coz some harm on your computer.
Try to review and check the specs of your laptop right away so that you can refund or exchange your memory into a compatible one. Thank you.
Oct 07, 2009 | Acer Aspire One PC Notebook
Change server
Contact me for product advice and support, or see my website at
http://www.motherboardsrus.co.uk
chris e/m me at compdoctor2005@btinternet.com
May 27, 2009 | Intel Pentium III , 900 MHz Processor
Its processor is only 800 mhz, can i upgrade it into a more higher mhz?
insteading of changing the motherbard for making it fast try upgrading the memory cards it add extra memory stcks in the computer to make it faster...
Apr 25, 2009 | Computers & Internet
Installation problem
Boot from the XP Professional CD
Oct 14, 2008 | Microsoft Computers & Internet
Ahielyd@yahoocom
call tech suprt on software your using tell them nee dto recatve new pc upgraded the cpu ok they will hook ya up
Jan 19, 2008 | Computers & Internet
Printer Spooler
Exactly what it says...(smile) Click on start click on run Type services.msc A box will open up Make sure all items below are set to automactic To make the changes double click on each item change to automactic if diabled. Then click apply when you are done. Restart the compputer and try testing your printer again. Printer Spooler LexBce Server Remote Procedure CallRPC) Hope this solves your problem
Sep 16, 2007 | Epson Stylus Photo R220 InkJet Printer
Intel Pentium III , 900 MHz Processor Logo
290 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
