Question about Mastercool 67680 Evaporative Cooler Air Conditioner
Frequent short cycles of the Mastercool swamp cooler
The cooler starts and runs for perhaps 3-5 minutes and then stops for about the same length of time. I beleive there is some way to lengthen the cycle so that is will run longer and stay off longer. It is probably an adjustment in the thermostat. The unit cools nicely but the on/off is annoying and probably not good for the motor. In the desert here swamp coolers are a blessing because we get moisture in the air besides much cheaper to run than the A/C.
  • shazam32 May 27, 2009
    I should have mentioned that I already replaced the thermostat.
  • shazam32 Jun 20, 2009
    Thanks for the info. Turns out that the breeze from the cooler hits the thermostat, making the cycles to short.
    Bill
    Problem Solver:
  • 11 Answers
Short cycling can also occur in a thermally protected motor if it is overheating. If the other solution did not work, make sure the belt on the motor is not too tight or too loose. A handy person can check the amperage with an amp probe to make sure it is in limits. The adjust the pulley to put it into specs.
Posted on Jun 20, 2009
When can i use my swamp cooler?
Posted on Jul 15, 2009
    Sergeant:
  • 293 Answers
Try to replace the thermostat. Short cycling of motor only happens when the thermostat is set to a very high temperature.
Posted on May 27, 2009
  • Boyet Soriano
    Boyet Soriano May 28, 2009
    Then try to replace the relay that goes with the thermostat. The holding coil might not functioning well.
Swamp coolers
Does it come back on automatically and how long does it take?
May 16, 2014 | Mastercool 67680 Evaporative Cooler Air...
Can you usen the sam air vent for heating and swamp cooler
Yes you can. I have that set-up in my house. The only problem is when moisture laden swamp cooled air goes past the heat exchanger. This could cause the exchanger to rust out, allowing carbon monoxide to come into the house when the heater is used. This can be avoidid by having a one way damper made by an HVAC shop, and installing it at the heater.
Apr 16, 2012 | Mastercool 67680 Evaporative Cooler Air...
New pads smell like urine. What can be done to eliminate this horrible odor?
Try some Downy fabric softener. Or replace them with Aspen pads.Thank you for choosing FixYa.com
May 18, 2011 | Mastercool 67471 Evaporative Cooler Air...
We have an older swamp cooler and need to have some windows in our home open to get best cooling. Does a mastercool need to have some windows open in our home to give max cooling?
The solution is to install "up ducts" These devices are easy to install and are fairly cheap. With a swamp cooler the best way to use them is to allow them to draft outside with the "up duct" you get the drafting to the outside but also get to remove attic heat too.
Apr 24, 2011 | Mastercool 67680 Evaporative Cooler Air...
Need to find blower motor for mastercool swamp cooler mod. # mmb12b
easiest way would be to take the motor to a local Electric Motor repair or replacement shop. All mediaum to large cities have them...
Aug 20, 2010 | AdobeAir Mobile Swamp Evaporative Air...
My Mastercool Trio System has experience a failure od the compressor fan. ACExperts, the installer and only dealer in El Paso has gone out business.
is this not a Evaporative cooler if so there is no compressor the only two motors one for the Fan and a Sump pump. and most you spend 200 for fan motor. this is swamp cooler!
Jul 04, 2009 | Mastercool 67471 Evaporative Cooler Air...
Remove the front and rear panels off of a MasterCool P12
Lift yhe panel and pull out at bottom. The ones that come out usually have hand slots
Jun 09, 2009 | AdobeAir Mobile Swamp Evaporative Air...
Water is not going into swamp cooler
CK THE FLOAT THAT OPENS AND CLOSES THE water valve.. press down on float to see if water is available,if water flows float needs adjusting. If no water then check to seeit hasn't been turned off for the winter -good luck
May 11, 2009 | Mastercool 67471 Evaporative Cooler Air...
Replacing pads
How do I replace a rigid pad on my Mastercool swamp cooler?
May 22, 2008 | Mastercool 67680 Evaporative Cooler Air...
Mastercool 67680 Evaporative Cooler Air Conditioner Logo
1,462 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
Boyet Soriano
Boyet Soriano
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
