Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
D-link wireless wont work after high speed disconnect.
Phone line went down ...high speed works when plugged direct now but wireless doesnt. I originally did the install....without computer skills,,,help!!
  • 1,305 Answers
It's pretty easy to remedy...
1. turn off all computers including wi fi laptops... turn off routers, modem, wifi router as well.
Here's the trick:
Turn on your main router... the one that is plugged direct to your modem.
turn this on before anything else... once it's booted up, turn on your modem... it will cycle up and find the first ip address which will be your router that was turned on previously...
Then turn on all the other routers, wifi computers.... the main router should give all the other equipment their addresses automatically and you should have wireless working at that point...
Good luck... let me know if it gets you up and running.
Posted on May 27, 2009
My phone went black and the tricks people say wont work cause my power button doesnt work
Did you drop your phone? I'm adding a link that may help you. Follow the video instructions at your own risk. How to fix black and unresponsive iPhone screen
Feb 27, 2014 | Apple iPhone Smartphone
Tip
How to Check main causes of Hissing Noise on phone line ?
The main causes of Hissing Noise on phone line
* Weather:
Precipitation can leak into phone lines and cause disruptions. Lightning, even at a distance, can damage the connection.
Checked the connections the cable and the Sockets
If you have the Test socket or the First Socket where the Telephone is is entering .. check the Connections there
* Electrical interference:
Check the Power lines,
Check radio or television transmitters, transformers and other electronic devices may causing noise on the phone line.
* Other phone devices:
Check for the Connection to the FAX check by unpluging the FAX Machine or answering machines,
Disconnect the other phones and line splitters --
Disconnect the Splitters or devices that allow two phones to fit on one phone jack -- can cause phone line noise.
* DSL services:
The high-frequency signals coming from DSL (digital subscriber line) devices sharing the phone line can create problems for other technology connected to the line.
***Note : high-frequency signals coming from DSL helps for FAST Internet Connection speed which sometime cause the problem to the Phone or Voice signals for this need to contact to ISP to check the Voice margin .. that may effect your internet Speed
IF the above wont work..
You can try keeping the device near Heater .. it could be the Moisture which might causing this issue
or
Show the Device to the Service provider to repair it
on Jan 22, 2010 | Cell Phones
When my Xbox is plugged in my phone line doesn't work.
The Xbox 360 Console is not compatible with a dial up connection or a phone line. It will only work with an Ethernet connection and some sort of high speed internet. You can also use the wireless built in the new 360s or purchase a wireless adapter for the older models if you have a wireless router with high speed internet in your home already.
Mar 04, 2011 | Microsoft Xbox 360 Console
Router works well most of the time....then for past two weeks it won't rout to other 2 PC and will not allow me to access modem. If I disconnect and plug in direct to PC modem works. Called high speed...
I have had similar problems in the past with 3 different brands of wireless routers, including the linksys Wireles-G router. In all cases, it was the same scenario, worked fine for a year or so, and then started giving inconsistent intermittent connectivity problems. Resetting, recycling etc. etc. would work for a while and eventually it would become unusable, and I would end up replacing. I went from a D-Link wireless router, to a Belkini, to a Linksys, and now use the Apple airport wireless, which I have also recently replaced with another Apple airport wireless. So unfortunately, I can't tell you if it's me doing something to kill them or if they are just short life expectancy for wireless routers, but the only fix I have experienced is replacing the router. Good luck...
Aug 30, 2010 | Linksys Wireless-G WRT54G Router
The magic jack is pluged into the phoneline directly
OK.. First of all, I am hoping you understand the basics of the MagicJack concept ?? Highspeed Internet connection on your PC, MagicJack plugged into your USB port, with a phone plugged into the other end of the MagicJack ? It requires High Speed, no dial up, and marginally works on my wireless Broadband due to atmospheric influences. It DOES work on my bluetooth wireless cell modem just based on the better speeds I get from the modem vs. my wireless Broadband.
1. If you have a Cable Modem or Wireless Broadband Dish for internet, follow the steps below.. IF you have DSL, skip to # 2.. if you have Dial-up skip to # 3,
I personally own wireless Broadband, so my ongoing experience is from here. I own a MagicJack for traveling and a Vonage line, for my house fax line service because the MagicJack is not strong enough, power wise, to push through my CAT/5 house, phone lines. Vonage does provide phone for the entire house, for the most part, cleanly, because Vonage uses a powered router to provide the final signal, which I then jumber over to a phone jack to connect into the house. It also requires that you disconnect your external phone lines, that would normally go back to the "Big Bad Phone Company". This can be done at the demarcation point, where your regular phone lines connect into a box, outside your house ? The internet I have, is in my shop, about 150' from the main house, Vonage's router power's the whole house, just fine.
2. With DSL, you will have good solid speeds, but you will still have the issue of, MagicJack, being too low in it's power source, because it comes from the USB port of your PC. You are basically going to be stuck with a single wireless or corded phone, for the MagicJack service. In this case, since the DSL is fed through the BBPC phone lines, you will not be able to 'pipe', even Vonage back through your house phone lines.
3. If you're on dialup, you're going to have poor service, out of the box.. you're just not going to be fast enough to be clean.
As an added note.. Your query for help is concerning.. again, high speed internet into your PC, MagicJack plugged into your PC's USB port, the phone plugs into the MagicJack's RJ-11 phone port.
Thank you for your time in these matters.
Respectfully,
Toby White-Beebe
P.O. Box 474
Penryn, CA. 95663
(916) 300-9410 Cell
(916) 473-7409 Home Fax
2008 VA Certified NACI Low Risk Security Clearance
2008 VA OCIS/ROB Affirmation of Compliance
2008 VA Certified OIT Contractor
2008 Dell Certified Lead Systems Expert - DCSE
1999 A+ Certified Service Technician
Aug 08, 2009 | Computers & Internet
Netcomm NP745n wireless USB adaptor drops in and out of connection on about a 10-15 sec, cycle
I would like you to attempt this troubleshooting technique which helps alot of people:
1st: Unplug your High Speed router then unplug your Wireless Router (ALL WIRES)
2nd: Shut Down your Computer(s)
3rd: After 60 seconds of your High Speed Router and Wireless router being disconnected please plug the High Speed router back in make sure that it appears Online/Connected then plug in your Wireless Router make sure that it appears Online/Connected.
4th: Turn on your computer, login in and reattempt connection.
If this process does not work, I would like you to take a few minutes and go over this URL that will help you find a place to put your Wireless Router to make sure you receive Good/Excellent Signal which is http://www.microsoft.com/athome/moredone/wirelesstips.mspx Microsoft "10 tips for improving your wireless connection." Is there anything else I can help you with?
Oct 27, 2008 | Computers & Internet
Belkin wireless modem router
I know how you feel. I was suckered into buying a Linksys compact wireless router and it's performance was the pits. I solved the problem by buying a new wireless router from TP-Link and it runs like a real gem. All 3 of my laptops surf on the internet wirelessly simultaneously together with my wired desktop with nary a trace of speed degradation considering that my line is only a 128 Mbps DSL line!. You've got to try TP-Link. It is so low-cost yet high-performance you'll be saying "best buy" over and over and over.
Jun 16, 2007 | Belkin (F5D6230-3) Wireless Router
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
164 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
