Question about Sony Playstation 3 (PS3) Console
Ps3 Can't start - correct hard disk not found
Hi i get this problem after i upgraded my 60gb Hard drive to a 320gb. At first it worked but after an hr or so when i switched my ps3 back on it gave me a message saying "Can't start - correct hard disk not found " i have to switch the console off and on untill it finally shows me the list of user names and not the error message. ive read other reports off this online but no solid solutions. i Have removed the drive and put it back in and also ive reformatted the drive succesfully using the ps3 format method and still no luck after a while. Also the drive i have is an "Western Digital Scorpio WD3200BEVT 320GB 2.5" Internal SATA Hard Drive" please help if you can thanks Same PS3 HDD Upgrade problem. Works fine, however ocasionally upon startup I get that annoying message "Cannot Start. Correct Hard Drive Not Found". Then I have to turn off manually, turn off power supply at the back, and then turn everything back on and voila it starts up fine. Very annoying because I know the hard drive is not faulty and it does run fine, I just get this occasional startup error message and have to jump through these hoops just to temporarily solve it and it drives me crazy.. My specs: Upgraded 1st generation 60GB HDD (Seagate Momentus 5400 SATA) to 500GB (Seagate Momentus 5400 SATA) Please Help anyone!!
SOURCE: ps3 Can't start - correct hard disk not found
I'm getting the same problem.....but i was playing COD4 last nite on my 40G PS3 and I switched it off midgame.....without quiting the game first and then console..... I just switched the power off....
when i came back after a while and switched on my PS3, i get this message:
"Cannot start. The correct hard disk was not found"
what do i do??? i don't know what to do now.... i cant do anything at all!!!
It doesnt even go into the menu screen....i'm just stuck with this message......
Posted on Jun 01, 2008
Gamoc
  • 18 Answers
SOURCE: Ps3 60gb no operating system
First the PS3 doesn't use flash memory, it uses a 2.5in SATA hardrive. It can't be that there is no OS, otherwise the PS3 would write it to the hardrive, it must be corrupted or have some other problem.
I would recommend buying a 2.5in SATA hardrive - they're very cheap. Ask in store for one, or you can get one from Play.com. If that doesn't work, it's a problem with the PS3 itself and you should phone Sony.
Posted on Jun 20, 2008
gamerfixer07
  • 344 Answers
SOURCE: playstation 3 60gb not reading discs
The unit needs to be cleaned out very good. Any dust build up at all and restrick the air flow and parts will start failing. If cleaning the unit and the laser doesn't work you need a new laser. $50 on eBay for a do it yourself job. But I recommend calling Sony. This is a common problem that they may fix for free. Hope this helps.
Posted on Jul 04, 2008
bubulica2000
  • 55 Answers
SOURCE: 60gb ps3 wont play ps3 games
The issue is the laser (actually has different diodes for blu ray, ps2 format and regular DVD.
Seems like in your case the only one that is burnt is the blu ray.
Send it back to Sony for repairs or if you do not have warranty purchase a replacement lens and install it yourself.
Posted on Sep 25, 2008
I do believe that it is a firmware issue and not a hard drive issue. If it where a true hard drive failure, your hard drive would be completely useless. Since this error only happens at start up i believe this is what happens.
1) PS3 starts-up and displays the "wave" and plays the "music"
2) The hard drive spins and the PS3 firmware is looking for the "files" on the hard drive for start-up
3) If the start-up files are not found in a certain amount of time, this message is displayed.
I may be wrong but this is my guess.
Posted on Oct 18, 2008
I am trying to install a WD3200BEVE hard drive into a Dell Inspiron 6000 and it reads "Internal HDD Error" I received this hard drive from Dell after my previous hard drive WD600 went bad. Do I...
It's possible that the only problem is that the replacement disk-drive needs to be "initialized" for first-time usage. Or, it's possible that your Dell won't support your new _larger_ disk-drive.
Did they send you a disk-drive with _greater_ capacity than your old 60GB drive?
It's possible that they "upgraded" you, because they had no (small) 60GB disk-drives in inventory.
Take your Dell "System Restore" set of CD/DVD disks, and reinstall Windows.
The Windows Installer will "initialize" your disk-drive.
Dec 18, 2010 | Western Digital Scorpio WD600VE 60 GB Hard...
My ps3 shut off and says ... can not start the correct hard disk was not found
Have you recently upgraded the hard drive on the PS3? If so, this could be giving you a problem and a solution is posted here:
http://community.eu.playstation.com/t5/PlayStation-3-Media/Startup-Problems-After-Upgrading-To-320GB-Sometimes-Cannot-Start/m-p/4958411?view=by_date_ascending
Nov 11, 2010 | Sony Playstation 3 (PS3) Console
Ps3 cannot start. the correct hard disk was not found
Hi if you replaced your hdd or if the old went foul try this plug your controller in with the usb lead insert a game disk, put it on standby (red Light) press and hold the power pad you will hear beep,beep, then it will shut down, Do it again beep, beep then beep beep take your finger off then follow your instincts on what it says. Also you may have to replace your hard drive ,not very expensive good luck
Mar 27, 2010 | Sony Playstation 3 (PS3) Console
PS3- cannot start. Correct hard disk not found.
when your ps3 is standing upright the tall way tip it over and look at the bottom there should be a plate that says something about the hard drive. get a flat screwdriver and pry on the right side of the plate. The hard drive is directly behind that plate and is secured by a blue screw. take out the screw and flip out the little u shaped handle and slide it to the right and pull out your hard drive. Try blowing out all the connections and putting it back in hope this helps
Aug 06, 2009 | Sony Playstation 3 (PS3) Console
Cannot start. The correct hard disk was not found.
u will have to get a new hard drive i would get this one it is cheap http://www.walmart.com/catalog/product.do?product_id=10710953
you will have to take the cover off the hard drive.
Jun 30, 2009 | Sony Playstation 3 (PS3) Console
Ok there is only 1 500gb drive that is compatible with the ps3 and thats the Samsung spinpoint, go here to find out
http://www.1800blogger.com/2008/08/31/how-to-install-a-500gb-hard-drive-in-your-playstation-3/
Jun 20, 2009 | Sony Playstation 3 (PS3) Console
Ps3 hard disk problem
i replaced the hard drive and now it works fine. thanks for your help
Jan 02, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 upgrade
Yes, you can. And Sony lets you officially do that. Just for that it has a slot on the side. You just need to remove the screw and pull out the HDD. You can then replace it with any capacity 2.5" HDD also popularly known as laptop hard drives.
Dec 31, 2008 | Sony Playstation 3 (PS3) Console
My Playstation 3 will not start. It keeps coming up with an error message saying, "Cannot start. Correct hard disk is not found." Any ideas why?
Yes, You need to re-format your hard drive via your laptop or purchase a new hard drive.. sometimes they become invalid/corrupt and you need to reset it or put a new one in.. I suggest taking it out and put it back in to see if it was knocked loose if not then you need a new hd! a 60gb ps3 original via eba is 40$
Jun 19, 2008 | Video Game Consoles & Games
May 31, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
980 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
