Would like to be able to take tension knob off for a part so that I can clean the rust out inside but I don't know how to take it apart
SOURCE: thread tension dial
Hi , the two washer are assemble the curve should be back each other , first put a piece of thin tosser like a small nail put spacer can struck the tosser ,put washer back to back cone retainer next spring next cover with number indicating tensioner of thread next the knob.Put the tread between two cuve for enough tension.
SOURCE: About my needle thread tension know
If you contact you local Brother retailer and explain the problem and give your model number they ought to be able to order a replacement which you can install yourself, or, probably more prudent, ask them if they will do it and also check for any other associated "modifications" made by the little fellow.
USA Dealer Search
or.......There ought to be one similar in your home country
SOURCE: Singer 6105 Tension knob
First make sure that the thread you are using in the bobbin is the same brand and type as in the spool that is threaded. I've read that using different weight threads at the same time can cause tension problems. I have actually had this problem and following this advice it went away. If this doesn't work you may need to have the machine serviced, unless someone else in the forum can advise otherwise. Good luck.
