Question about Brother PE-150V Computerized Sewing Machine
Brothers pe150 embroidery machine will not let the needle pick up lower thread
The machine was working just fine till I adjusted the thread density button, now it will not embroidery at all. I have changed the needle , thread and even the bobben thread and it still will not embroidery. I hava a brother PE150 embroidery machine that was sewing fine then the lower thread knotted up. Now it wont let the needle pick up the lower thread
  • 109 Answers
It sounds like the timing is off and needs an authorized repairman.
Posted on Aug 23, 2010
Why is my machine making a clicking noise when embroidering
The reason for clicking could be one of so many issues from one that could be resolved with a slight adjustment to one that needs a technician's hand. Start with where the clicking sound is amplified.
If it's louder at the top, coming from inside, it would definitely need a tech. If it's coming from the pantograph (the embroidery unit arm that holds the hoop), it could be a fraying cable (call a tech) or maybe just the hoop isn't set into the grooves properly.
If it's clicking only when the needle penetrates the fabric, check to see if the needle is damaged or dull and change it; or if the sound is evolving from further down in the bobbin area it could mean that the hook is not meeting with the needle properly and it needs to be timed (call a tech) but first check to see if maybe the bobbin's in backwards or if the needle is seated correctly.
If it happens only when you stitch one particular embroidery design, it could mean that the design is stitch intensive - lighten the density and remove unnecessary stitches.
If you switch from regular sewing to using the embroidery unit, make sure you have made all of the necessary adjustments to settings on the machine like lowering the foot feed and whatever else is required of your model (check your manual).
Bottom line, make sure you have everything threaded right, bobbin area and all thread paths clean, a new needle properly seated and all other things set right and if that doesn't solve the problem, call a tech.
Jul 31, 2014 | Brother SE400 Computerized Sewing and...
I have a Brother SE270D and my top thread won't pick up my bobbin thread
Replace the needle with a Schmetz needle. If that doesn't work you need to get it serviced
Feb 21, 2014 | Brother 98-Stitch Computerized Sewing &...
Upper thread keeps breaking on my Brother HE-1 embroidery machine, tried adjusting the tension and nothing seems to work
could be a dull or bent needle. Could also be a burr on your hook. Try changing the needle first. If it's a burr on the hook or the needle plate, you have to take it to a tech for maintenance
Sewing Tech
Oct 25, 2013 | Brother HE-1 Embroidery Machine
My brother pe150 embroidery machine does not pick up bottom thread and wont sew
try changing the needle
rethread the machine--use every thread guide
make sure the bobbin is not warped
make sure the bobbin is inserted correctly in the case
it's very possible that the timing of the machine is off & the machine would need to be checked at a sewing machine shop
Mar 20, 2012 | Brother Sewing Machines
How do you change the timing on brother pe150 as it wont pick up bottom thread
Full details on how to adjust the timing appear here in my Brother PE150 blog. You will need a few basic tools including the stubby screwdriver that came with your machine.
Mar 20, 2012 | Brother PE-150V Computerized Sewing...
Brother pe150 won't pick up bobbin thread
Hi. This may sound silly, but the most likely reason the upper thread doesn't pick up the bobbin thread is that the needle is in backwards. (Sounds silly, but it's true!)
Needle shanks have a flat side and that flat side has to go in a particular way for your machine. With most modern machines, the flat side goes to the rear, facing away from you. Check your manual to be sure.
The second most likely reason is that your needle may be bent. Check that your needle is straight (or just use a new one).
Hope this helps!
Happy Sewing,
Robbie
Mar 14, 2010 | Brother PE-150V Computerized Sewing...
Brother VX-1120- The needle is not picking up bobbin thread.
I had the same problem with my brother vx-1120 sewing machine. I set the needle to lowest position by using the hand crank. Then I loosened the knerled set screw that holds needle in place. Then I moved needle shaft till the eye of needle is just lower than the hook on the shuttle loop maker. It made my mechine work. There are instuctions for ajusting timing on machine but I think these mechines are built to not fix and throw out. Just because there where no ajustment marks at all on machine, any machanical machine will needed to be ajusted sometime.
Jul 08, 2008 | Brother CS-8150 Computerized Sewing...
Brothers pe150 embroidery machine will not sew
If you tighten up your needle thread, reduce the tension of the needle thread.
For embroidery, and zig-zag, and because the needle makes side movements, it needs more needle thread.
So try to keep you needle thread not very tight,
and tight up your bobbin case tension more, so that the two threads meet under the meterial.
Mar 30, 2008 | Brother PE-150V Computerized Sewing...
Brother PE150
You need to adjust your top tension and maybe your bottom tension ( the little screw on the bobbin cover) Also check your needle and make sure it's straight.
Feb 07, 2008 | Brother PE-150V Computerized Sewing...
Brother PE-150V Computerized Sewing Machine Logo
351 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
