Question about Logitech MOMO Force Wheel And Pedals Set
Sticking pedals The accelerator and brake on my Momo wheel "stick" on and cause my car to be uncontrollable.
  • 1 more comment
  • Anonymous Nov 17, 2007
    Can not get full acceleration. Checking in control panel - game controllers shows the brake is on quarter way, When I put the foot down on the accelerator the brake returns to the zero point but I only get three quarters of the maximum acceleration
  • troyce01 Jun 25, 2008
    Accelerator pedal often sticks on, and/or is always slow to return to "idle" disallowing "steering by throttle."
  • Anonymous Aug 06, 2008
    I have exact the same problem with two of the Momo force- wheels (I have to return the first wheel after a year and two years later... the second one starts with this problem)
MOMO's are notorious for the potentiometers going bad. There used to be a place that sold replacements, check www.digikey.com I think the top kit is for momo black, and the bottom one for momo red. I think they were zero balance when I checked.
963260-KIT-ND Q1465369 MOMO FORCE REPAIR KIT
963282-KIT-ND Q1465379 MOMO RAC FORCE FDBK WHL RPR KIT
as a last resort, take the information for the digikey potiometers to Radioshack and see if they can order you some.
Posted on Jan 21, 2008
Sticking accelerator in my 97 rav4 what causes this and how do I fix it
Make sure floor mat is not compromising accelerator pedal operation. Check throttle cable for sticking and binding.... lube if necessary. Check throttle linkage at intake for sticking/binding and repair as necessary
Nov 29, 2015 | 1997 Toyota RAV4
After turning on truck .an go to accelerate the truck hesitates an makes a "Brake sticking sound wen throttle is applied. .on the Traxxas Summit. .Thankyou!
do you here rumbling also from one or both sides front or rear if its four wheel disc brakes one or more brake calipers can be locked up or the emergency brake is not releasing in the rear if drum brakes in the rear the return springs could have broken this is what pulls the brake shoes back when you take your foot off the pedal and will make a lot of noise and cause resistance because the brake for that wheel is partially or fully applied LATER MAN!
Aug 21, 2014 | Cars & Trucks
My brakes keep locking up on 2001 ford taurus what causing it?
Could be sticking disc brake caliper(s), or sticking rear wheel cylinder(s). If one wheel locks up before the others, that would likely be the problem caliper or cylinder, since that brake wouldn't fully disengage, and would therefore be dragging (which would accelerate the wear on those brake pads or shoes, also).
b5fd73fc-fd03-41bf-b4d0-0a579f148a32.jpg 27e9fde0-af18-4af2-ae39-67b27c71e360.jpg
Jan 27, 2014 | 2001 Ford Focus
Hub making grinding noise tie rods need replacement
A grinding from the hub sounds like a bad wheel bearing.
Jun 01, 2010 | 2001 Buick Park Avenue
Front brakes sticking after a couple of miles
There are 2 causes, 1.caliper slides are in need of servicing/lube.2, caliper(s) piston(s) need to be serviced/cleaned. Recommend replacement of both calipers, if either doesn't work.
May 15, 2010 | Cars & Trucks
My Mountaineer accelerated while I was braking and
it could be either --throttle body sticking open will cause constant acceleration when u lift off pedal-cableless accelerator [electric gas pedal ]if a sensor or electronic part shorts out can open throttle body causing acceleration- would need to have it diagnosed to find out which problem is correct
Mar 01, 2010 | 2004 Mercury Mountaineer
Metal spring has broken under my gas pedal
Put the Brake spring under the gas pedal (think its the same part) and then get a "Squash Ball" (small hollow ball for the game Squash) and tape that in place of the spring, you brake pedal will now feel more firm like a real car....
Aug 01, 2008 | Logitech MOMO Force Wheel And Pedals Set
Momo accelerator allways on full in games
you need to change the setting in the game form digital feed form the pedal to analog
Jun 30, 2008 | Logitech MOMO Force Wheel And Pedals Set
Logitech MOMO Force Wheel And Pedals Set Logo
381 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
