Question about Invacare Nutron R51 Folding Power Wheelchair
Left motor gears/clutch do not fully engage.
Chair's left rear wheel jolts as you move the joystick in any position. Almost feels like the gears are stripped. Removed the top of the gear box and all the gears are fine.
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
My gear feels loose when I move ot.now I have to turn the chair on and off 2 or 3 times to make it go.what could it be?
A 14 hr charge with the Joystick left on. There is a circuit that has to be reset. The circuit is tripped by controller getting too hot or having too heavy a current draw on the motor. Leaving the joystick on during charging is okay and will not hurt anything.
Mar 18, 2016 | Invacare Pronto M41
Hoveround won't move.
Double check to be sure drive levers are fully engaged. Go down and up a few times. If problem persists have Hoveround come and check it out. One of the drive motors may have shorted out when you continued driving with gravel in the wheel.
Mar 29, 2015 | Hoveround MPV5 Electric Wheelchair - Used...
What is Code 35
assuming this is a Pride Q600 or simular powerchair.with the q600 what usually happens is grease leaks into motor .the motor current
draw then goes up and chair tries to go in circle.first check the outer motor brush & spring for burning.if you have a dc clampmeter check current draw with joystick forward aprox 3 amps.if over replace motor.if no clampmeter run chair for 10 mins wheels off ground Then feel both motors if left one red hot .replace it.hope this helps
Dec 06, 2014 | Health & Beauty
Power steering electric
If the chair wants to drive left then you have a disengaged left motor clutch lever or a left motor going bad. Then M51 will not give an error code if the clutch is disengaged. If the chair is veering left as you are driving but you are still able to turn to turn right then the motor is not likely to be disengaged but has a brush or gear problem.
It is also possible that the joystick is not working well. The joystick is much less likely to be the problem unless it is damaged somehow.
Sep 02, 2014 | Invacare Pronto M51 Power Wheelchair
I have an error code 5 on invacare pronto 51 surestep
This indicates a fault with the left parking brake. Check to see that all the connections are tight by unplugging, and replugging them in, check to see if there is any damage to any of the cables, but first, make sure that the neutral lever on the motor is fully engaged in the drive position...sometimes these get bumped and the controller/computer thinks the chair is out of gear. Move the lever to the full neutral position/out of gear, then reengage it to the drive position.
May 02, 2014 | Invacare Health & Beauty
Yellow invacare wrench
Motors must be fully locked in gear to drive. Also many chairs require the joystick to be turned off before putting them in gear or turn chair off and back on after engaging the motors.
Dec 23, 2013 | Pride Jazzy 1103 Ultra Standard Power...
Blinking yellow wrench light on pride jazzy 614 HD
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
Jan 06, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
Jazzy 614HD will not move. Lights flash from right to left, then cuts off. Unlock instructions are not effective. Chair is fully charged.
If chair has a tilt, recline or lift seat on it it may be going into lock-out mode on its own due to a limit switch fault. If you don't have any of these options then I suggest you remove the joystick, controller and any wire harness between the two and send them to a shop like mine for repair.
The usual lock out light chase is from left to right - not right to left so this is suspect of a different issue.
Dec 28, 2012 | Pride Jazzy 614 Hd JAZZY 614HD
I bought used mprv 4 hooveround, been setting for a couple years and I put new battries in it,I put it in driveand all the lights come on you can near something running when you move the lever forward,...
take the freewheel levers and move them up and down a few times then leave them both in the up position. Turn on the chair and see if it works correctly The noise you hear are the motors or motor running because one or both levers are in freewheel.The clicking you hear is the electric brakes engaging when you move the joystick Hope this helps
May 06, 2011 | NRS Hoveround MPV 4 - Hovaround Used...
My wheelchair dose not move
The chair has two levers, one for each motor, that disengage it for freewheeling, or pushing the chair without power. These take it out of gear. Place the levers in the locked, gear-engaged position and it should go for you. Here's a link for the manual for your chair, and it will show you where the location is to place it in gear.http://www.invacare.com/doc_files/1125085J.pdf
Apr 16, 2009 | Invacare Pronto M51 Power Wheelchair
Invacare Nutron R51 Folding Power Wheelchair Logo
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
gnshome
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
