Question about Ruud Handle Air Conditioner
Compressor of the Ruud A/C outside unit is making unusal loud continuous noise. I open the case, its not the fan or fan motor, loud noise is coming from the compressor, and it is also heating up a lot. Please let me know what my options are. Thanks.
  • arahman030 May 27, 2009
    Thanks, localwonder.
    Any idea how much the new compressor and labor will cost. Thanks, again.
  • 6,784 Answers
OK, you will need to replace this compressor. the internal seals have ruptured, causing the loud noises. the heat is from the metal to metal friction. the compressor can be rebuilt but, it will be more costly than just replacing it with a new compressor.
Posted on May 27, 2009
  • Michael Masters
    Michael Masters May 27, 2009
    Its hard to quote a labor charge but, most labor charges are set at 50 an hour on most home visits with a 2 hour minimum. the compressor kit will run you 159.00 tops.
Ok if the compressor is making a hissing noise it might be the compressor is over charged you need AC tech to check that if is not over charged and still making the noise you will need to replace the compressor because the internal seals are rutptured causing the noise .
Posted on Feb 25, 2010
Sometimes, when the inside blower shuts down, the
I was leaning towards a bad contactor. Either sticking sometimes or not making good contact. I would inspect the contactor for pits or burn marks near the contacts. DO SO WITH POWER OFF of course...but, what's the reset button you are referring to?? I'm assuming this is a heat pump, please send model number!!
Jul 06, 2017 | Ruud UAKA060 Air Conditioner
Fan isn't turning
turn the power off, take the cover off the top and try to spin it. If it spins hard then it was the motor. If it spins easy the the capacitor is probably bad which
would cause the fan to go bad.
Usually this can be a dual capacitor which also controls the compressor. Sometimes just replacing
the capcitor can do the trick, if not then the worst
is that you will have to replace the motor and still use the new capacitor
Feb 02, 2010 | Heating & Cooling
I am getting a loud rattling noise. could this be my compressor
Noise can come from these areas:
The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows: If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer. If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer. If the freezer is on the left, the fan is on the back wall, halfway up or near the top. Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead. To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it.
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting). The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
Jan 29, 2010 | Frigidaire Refrigerators
Ruud heat pump, acheiver, 14 years old. The heat seems to be on but the unit outside is frozen over and fan out there is not turning. The motor runs all the time. Is this okay?
In the heat mode the outside unit should have the fan running. In the defrost mode, the fan should not be running but in both cases, the compressor runs.
Jan 02, 2010 | Ruud UBHC Air Conditioner
On tempstar heatpump the outside fan makes a loud noise
Well, that could mean a lage list of problems from which to choose, 1st I suggest you isolate the fan to be sure it is the problem; Hopefully you have an outside disconnect box for the unit, stop the power at this discoonnect and wait 3 minutes. Place a large stick or metal bar throught the topgrill to hold back the fan blade from turning. Now connect the energy at the disco box ( you may want a second person so you can hold the stick in place). You will not harm anything by holding the fan from turning for a short time. If you hear the noise that you suspect after the unit runs for 20 seconds, then the problem is most likely the compressor. If you do not hear the noise, then remove the stick and aloow the fan to turn. You at this point should be able to see if the blade is clangging, or the blade is imbalanced and vibrating, or the noise is coming from the fan motor itself. The most likely problem is the bearings of the fan motor are worn and the motor is screaching or laboring; in which case you need a new motor unless you are savy enough to replace the bearings in the motor (however, this is not always cost effective unless you really know your stuff). Check the blade for fatigue fractures in the metal and check the mounting points that hold the motor in place-----sometimes these mounting points also fatigue after years of vibrating and need to be reinforced with oversize washers or the entire top grill piece needs to be replaced if the cracks are too severe. Goodluck, Macgivor
Jan 02, 2010 | Ruud Central System Air Conditioner
RRUDD ACHIEVER 30, OUTSIDE FAN WON'T SPIN.
does the unit outside run at all,can you hear a humming noise or the compressor run or is it just dead.if you hear the comp. run or a humming noise then i would say it needs a new motor.but if you hear absolutely nothing out there,what i would do if you dont have a meter, is open panel on condenser and push the contacts in on the contactor when this is done its like jumpstarting the unit,it should all come on ,compressor and fan motor,if motor comes on then your contactor is bad (cost approx.$50.00) if it doesnot come on then its motor when replacing motor be sure to get a new capacitor with it (cost $80.00 to $120.00 plus cap 5mhz.$5.00 to $15.00) depends on where you get it home depo/menards/etc.high priced try granger or a local a/c distributor youll get it much cheaper.hope this helps
Sep 29, 2009 | Ruud UBHC Air Conditioner
Loud clanking noise when washer is coming to a stop
  • If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, halfway up or near the top.
  • The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly.
  • If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor.
  • The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
May 19, 2009 | Whirlpool LSR5132PQ Top Load Washer
GE side by side Refrigerator makes LOUD SQUEAK when running
Mar 24, 2009 | GE Refrigerators
Ruud achiever 10 seer air conditioner
It sounds like your condenser fan motor may be locked up or the capacitor that helps give the condenser fan motor a kick to get it started may be defective. Try turning your system on and using a long screwdriver try to push the fan blade on the condenser fan motor to see if it will run normally if you give it the starting boost it needs.If it does run at full speed and doesn't over heat or start and then slow down then you probably only need to replace a simple 10-12$ capacitor. If it barely turns, makes an odd humming sound or overheats etc. then you will have to replace the condenser fan motor. This is assuming that the outdoor condenser has the 220v supplied and the 24v supplied to the compressor relay, that the compressor relay is engaged and suppling 220v to the condenser fan motor.
May 28, 2008 | Ruud Matching Split Air Conditioner
Heating & Cooling Logo
2,142 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
