Question about RCA 27F530T 27" TV
Horizontal secciom rca 27f530t
Tv rca 27f530t, there is a problem on the horizontal seccion, because the image looks like a cushion, I donĀ“t have diagram do you know if this a capacitor or what is wrong?
  • 1 more comment
  • panchisprs May 27, 2009
    yes my friend the picture or image looks like a cushion or trapezoidal, I was trying with presets inside but I can not solve the problem, I am not sure if a capacitor is failing or what it is.
    tv rca 27f530t
    your right, do you know where can I get the electronic diagram for free, or do you know how to solve this problem?
    I will be greatful for your answer.
  • Rommel Cana
    Rommel Cana May 11, 2010
    is it a trapezoidal picture?
SOURCE: programming code for rca 27f530t tv
0704 is the first code
Posted on Jun 01, 2008
  • 418 Answers
SOURCE: I got a problem with a ctc187 rca TV, no
Pincushion Board.
Posted on Apr 15, 2010
freetek
  • 5568 Answers
SOURCE: RCA TV has nothing but horizontal line
If you look closely at that line, you can probably see it shift color; this is caused by the video that is now compressed in height. The failed circuit is call a vertical amplifier and there are so many ways to accomplish this I can't give you a part number to look for inside but it should not be an expensive repair; parts and labor should be around $50 to $75 US.
If you have a service shop for standard TVs in your area, call them with the brand and model number and tell them you were told that the vertical amplifier (or section) has failed. They should be able to give you a fairly accurate quote.
If you were still satisfied with brightness and color, it isn't a bad idea to have it done since it is unlikely that ANY new, flat panel set will live even half as long as your RCA.
Posted on May 11, 2010
SOURCE: my rca console tv has white horizontal lines
Cold solder joints on the flyback transformer circuit board - probably because RCA used feed-thru steel rivets on their boards. Re-solder the connections using a good solder flux for clean solder joints and this will fix prob. The joints with the dull, pitted finish are the problem joints.
S. Hampton
Posted on May 16, 2010
gopakumarg43
  • 74482 Answers
SOURCE: RCA 27F530T is requiring a
Hello
You just unlock your rCA tv by any one following methods. One amoung them will surely unlock it. After unlocking it , you have to set its pass code.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won
    Posted on Jan 10, 2011
Tv problem
Check its horizontal output section circuit for any loose solder terminals. Resolder all suspected solder terminals by applying little more fresh solder. Replace the horizontal output transistor. If this transistor have some leak, it will overheat within minutes will shut down the picture.
May 26, 2012 | RCA 27F530T 27" TV
Universal Remote Codes, not an RCA Remote
0031 0004 0048 0054 0094 0100 0102 0107 0129 0191 0005 0009 0000 0162 0163 0342 0003 0015 0022 0096 0113 0125 0179 0187 0188
Mar 26, 2012 | RCA 27F530T 27" TV
Transistor d1878 get over heat
i have a sony kv-2197m3 i replaced tr D1878 tv turn on,but image it's bad in horizontal seize and tr D1878 was shorted again what's the matter? chek68@gmx.fr Post Solution
Oct 11, 2009 | RCA 27F530T 27" TV
Picture on screen is too far to the left
If its only the wide of the screen the problem is with the horizontal transistor near of the flyback, you can also probe the capacitors near, if the problem continues try to change or reconfigurate the EEPROM
Apr 12, 2009 | RCA 27F530T 27" TV
I recently acquired my grandmothers tv = an 2004 model RCA #27F350T and wondering if it is digitally ready for Feb. 19 - we are currently using an outdoor antenna with a booster.
I could not find a "RCA model #27F350T", but there is a RCA model 27F530T, and according to the users manual for that TV, it is not Digital ready. You will need a converter box if you wish to continue receiving antenna based broadcasts. Your users manual can be found at the following link.
http://tv.rca.com/RCATV/Assets/pdfs/27F530T_1620181B_IB_e-04.pdf
Jan 04, 2009 | RCA 27F530T 27" TV
Dvd player hook up
If the make and model number of your TV is as stated in the category posted. RCA model 27F530T 27" then you can find the owners manual at the following link.
Dec 28, 2008 | RCA 27F530T 27" TV
Programming code for rca 27f530t tv
RCA TV Codes.
11447, 10047, 10019, 10679, 11247, 11547, 10090, 11147, 11047, 11347, 10018
From http://www.satex.com/directv/tv_codes.html
Jan 06, 2008 | RCA 27F530T 27" TV
A mistake in my parts i.d.
TRY TO CHECK THE OUTPUT OF YOUR MAINBOARD,HORIZONTAL OUTPUT AND THE POWER SUPPLY,COLDSOLDER THE MAINBOARD OF YOUR TV.
Dec 31, 2007 | RCA 27F530T 27" TV
Video is "Squeezed" and "Choppy"
you have a problem in your vertical circuit i would recomend taking it to your local shop rca's can be real tricky to fix.
May 30, 2006 | RCA 27F530T 27" TV
RCA 27F530T 27" TV Logo
165 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
