Question about Alphasonik (PMA640A) Car Audio Amplifier
What is the very best way to wire 3 sets of speaks and 2 subs through a 4 ch. amp and a 2 Ch. amp.?Thank you, Paul
I have a 2002 Volvo C70 convertible and I have put in an aftermarket car stereo and I need to know the best way to wire it because I have tried several ways and its still not the best way, I am sure. I want the most power I can get from these components with the cleanest sound possible. What is the best way to wiring my car stereo so that it sounds the very best possible. It has a clarion double din 385 head unit, a pair of Cliff design 5 1/4 component in the front doors and matching tweeters in dash. also in the lower half of the door are 8"inch, Oxygen Audio Technology Audio Air2 3-way speakers. the rear panels have Rockford Fosgate power series 6.5". There are 2 10 Audio Pipe subs in the trunk. The main Amp is the new 4 channel 1600 watt. Ground Pounder made by Crunch. and a 600 or 700 watt 2 channel MA AUDIO amp...? How do I wire the very best way? Thank You, Paul von
  • paulvon13 May 27, 2009
    Hello Hoyzee,
    Thank you so very much for the help.... I am not down on all of the lingo. Therefore; if you could be so helpful and send me a quick drawing of where the speakers wires should go I would Greatly appreciate it....
    Thank you,
    Paul
    Novelist:
  • 149 Answers
Ummmm Im gonna give this a try-If it were me i would run the 4 channel ground pounder on the doors and rear panels -the front 2 channels run the component set exclusively at 2 ohms per channell and run the 8 inch 3 ways in parallel with the rear deck speakers for a combined load of 2 ohms per channel on the rear channells-naturally the 8 inchers and the 6.5's are going to be able to handle a little bit more bottom end than the component set so you can feed a little more midbass to those rear channels- I dont know the resistance of the coils on your subs or the model of the MA amp you are using but if you can throw 600 or 700 on your subs that should be sweet enough- hope its not a waste of your time or maybe you already tried it set up that way-good luck though
Posted on May 27, 2009
  • hoyzee1 May 28, 2009
    Hi there okay first of all starting with the component set-does it have a passive crossover network that comes with it or does the tweeter just have a capacitor that filters out the bass/midrange? You should have a passive crossover that came with it if so hook it up normally one set of wires to the tweeter and one set of wires to the midrange- the front r/l channels wire up to the inputs on the crossovers-are ya with me so far?If the component set did not come with a crossover then no biggie theres a crossover on the amp-if thats the case then run your speaker leads from the amp front channells to the doors at this time you will want to thread the speaker wires from the tweeters in the dash down to the doors as neatly as possible-at this junction you will attach the leads from the amp to the midrange(component) and you simply attach the tweeter to the component + goes to + and - goes to - that is called parallel wiring. how it affects your amplifier is that it lowers the resistance that the amp has to push against which increases the power output as more current is allowed to flow. Now that you have wired up your component set to the front left and front right channells of the amp you can address the 8 inchers and rear speakers- These you are going to wire up almost identically except you will connect to the rear left and right channels of the amp- Run your speaker leads to the front doors just as you did with the previous wires for the components and connect them to the 8 inchers - do what you must to keep it neat and when your done with that part put your doors back together again -your done with that part- Moving on to the rear speakers just run a set of wires to the rear panels and get that all hooked up nd now you should have 4 sets of loose wires leading to the amplifier- 2 sets from the left and 2 sets from the right You want to connect those sets from the left in parallel(++ --) and connect the parallelled wires to the left rear channel of the amp -do the same for the right your mids and highs are now all connected to the amp-set the crossovers on the amp to high pass(HP) set the frequency for the front component speakers at around 100 HZ set the frequency for the rear channels to about 65- 80 HZ set all gains to halfway turn off any bass boost features and it should pump out some loud clean sound.If the components get a little muddy sounding turn the frequency of the crossover up a little bit and see if it filters out the mud- same with the 8 inchers and rears adjust the crossover until it sounds right to you-at this point you are running your amp at 2 ohms which delivers all the power that the amp is rated for. I am sending a simple diagram on parallel wiring -which i found by searching for "parallel wiring" and theres a lot of step by step places that break it down for you if you want to gain that knowledge-good luck-let me know if you have any questions
    Parallel
    2 x 4 Ohm speaker = 2 Ohm load
    2 x 8 Ohm speaker = 4 Ohm load
    2 x 16 Ohm speaker = 8 Ohm load
I have 2 pioneer 6x9 400w, pioneer GM 6500f 760w amp and a kenwood KFC W1012 sub, how d i get the best sound from these?
pioneer gm 6500 is a 4 ch amp rated at 60w-4 way to small of an amp to run your sub. UNDER-POWERING your sub is more likely to damage spkr than over-powering. my advice,get mono-block to run sub
Jan 04, 2013 | Pioneer 6X9 5WAY 400W SPKR Car Speaker
Installing APX490 in a boat with 4 speakers and 1 subwoofer. The factory manual shows a diagram with each of the 4 wired to an individual channel and the subwoofer - wired to - terminal of the LF speaker...
A better solution would be
1: Get a seperate amp for the sub itself
2: Run 2 speakers on ch 1 and 2 speakers on ch 2. I assume your speakers are 4 ohms, in stereo mode that amp is stable to 2 ohms. The bridge the subwoofer on ch 3 & 4. That will work if you just want to use that amp. If you need more help you can email me @ thefowlerfam09@yahoo.com Hope this helps...
Apr 04, 2010 | Clarion APX490M Car Amp
How to wire for 3 ch mode
this is the manual and you will find all you need in it.
http://www.fixya.com/support/p78783-eclipse_ea3422_car_audio_amplifier/manual-18248#
Jan 29, 2010 | Eclipse EA3422 Car Audio Amplifier
Best way to connect a 15'' kicker cvr15 4 ohm dvc [single sealed box] and a volfenhag zx-4712 1000w 12'' 4ohm+4ohm dvc to my pyle 885 1000w 4 ch. bridgeable amp and how to wire the voice coils that are in...
best way is to just run the volfenhag with a set of wires for 2 channells(one set per coil) left and right @ 4 ohms per channell. The CVRs you can parallel the coils(2 ohms) and run a set from each sub to the amp in stereo left and right. This will give the kickers a little more juice than the 12 but should be fine.
Jan 25, 2010 | Rockford Fosgate Car Audio & Video
I have 4/3/2 ch. alpine f-240 amp- i want to hook up four 6x8 3-way and one 12''sub. the amp has bass EQ on ch. 3. how would i hook it up and get the most power. can i put the 4 6x8 bridged all together...
run two 6x8s on each of the front channels of the amp. then depending on the sub you can bridge it on the rear channels.only if its a single four ohm. if its a dual 2 ohm sub run each coil on each channel. 1 coil-1channel. the other coil-the other channel. amp should run fine may run a little hot since it will be doing all it can do at a safe ohm load. just make sure it is mounted in a well vented area. should be safe.
Dec 25, 2009 | Alpine MRP-F240 Car Audio Amplifier
How to connect a 4 ch amp to 4 speakers and sub-woofer
http://www.audiosavings.com/content/ebay/SubWiring.html
this link will help u understand the wiring & how too wire your speakers...
as far as speaker ohms & amps go, 4 ohm speakers should be wired too 2) two ch. amps.
hope i was of sum help.
Jul 14, 2009 | Car Audio & Video
Alpine eq 3331 install
USE THE FOR CH RUN ALL THE SPEAKER THE MEANS TWO RCA ONE FOR FRONT AND ONE FOR REAR INTO THE AMP AND NON-FADE REAR-FOR YOUR SUB --POWER FOR EQ--[POWER 'REMOTE AND GROUND]
Mar 26, 2009 | Alpine ERE-G180 11-Band Car Equalizer
Correct wiring for a ASTATIC TEARDROP MIKE to a RANGER RCI 2950DX
here is the info you asked for the following is the correct wiring.
Mic Wiring Info
Stock Mic Wiring
1. Ground Shield
2. Audio Yellow
3. Transmit Red
4. Receive Black
5. CH. Up White
6. CH. Down Blue
Turner 4-Wire MIC. Wiring
1. Ground Shield
2. Audio White
3. Transmit Black
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Turner 6-Wire MIC. Wiring
1. Ground Shield & Red
2. Audio White
3. Transmit Blue
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Astatic 4-Wire MIC. Wiring
1. Ground Shield
2. Audio White
3. Transmit Red
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Astatic 6-Wire MIC. Wiring
1. Ground Shield & Blue
2. Audio White
3. Transmit Red
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Mar 11, 2009 | Connex 3300 240-Channels Base CB Radio
Why connect a car amp in series and will this help me?
Not sure if it's what was meant by previous poster. But if you're just driving the two subs off the 4 ch, and no other speakers, your best bet is to run pairs of bridged channels, ie use the 4 ch as a more powerful 2 ch amp. Then independently run one sub on each of these paired channels.
If you bridge all 4 channels (not sure if this is an option on this amp), and then run your subs in series, you will likely lose out compared to the peak power you could be seeing with two independently paired channels.
Dec 01, 2008 | Car Audio & Video
Hooking up a new 8" woofer speaker to my amplifier
If I'm reading the amp manual right, you should be able to connect the amp in 3 channel mode. To do this:
  • Connect both left door speakers in parallel to Ch A Left.
  • Connect both right door speakers in parallel to Ch A Right.
  • Bridge Ch B and connect it to the new 8" sub.
  • Set the Ch A LPF/HPF to HPF.
  • Set the Ch B LPF/HPF to LPF.
This should allow you to run all 4 door speakers and the sub from the amp. It will also automatically route non-bass to the door speakers and "only bass" to the sub.
Mar 22, 2008 | Pioneer GM-6300F Car Audio Amplifier
Alphasonik (PMA640A) Car Audio Amplifier Logo
316 people viewed this question
Top Alphasonik Car Audio & Video Experts
xxxxxx xxx
Are you an Alphasonik Car Audio and Video Expert? Answer questions, earn points and help others
