Motorola Modem
Problem for Motorola (FMMOTV92PCI) Modem
Missing
By nishanth75 on May 27, 2009
missing
Solution #1
posted on May 27, 2009
Not Rated)
gomez73
Rank: Guru
Rating: 86%, 194 votes
This can be caused by a hardware error or a software(driver,Windows,Etc..) error, or because of a conflict with another piece of hardware if you are using windows 98 or newer, right click on "My Computer" left click on properties, and click on the "Hardware" Tab in the System Properties window, Then click on device manager, is the modem listed under the "Modems" category, if so double click on the line for the modem, and if there are problems with the device it may tell you and give an error code, if it is not listed, is there anything EXCEPT a PLUS SIGN, (Example, an exclation mark or an X) if so those pieces of "Hardware" may have driver problems, goto the manufacturers page and look for the driver in the support/downloads section, and choose your OS and try re-installing the driver, OR if a new driver has recently been Updated or installed, you may try to "roll Back Driver, by clicking the button after double clicking on the "device". If this helps you solve your prob, or points you in the right direction a fixya rating would be appreciated, if not a fixya, whatever you think I deserve, Thanks for the question.
Was this helpful?
Yes
No
Solution #2
Not Rated)
reisenstein
Rank: Wiz
Rating: 82%, 58 votes
Have the driver disk handy and let the computer re-detect the modem. If it doesn't find it, remove the modem from the slot it's in and insert into another slot. the re-detect if it doesn't see it on boot up. It the computer still doesn't fing the modem, you may have a bad modem.
Was this helpful?
Yes
No
Popular Solutions for Motorola Modem
Questions and Unsolved Problems for Motorola Modem
Do you recommend Motorola (FMMOTV92PCI) Modem?
Answer
Answer
Got a new laptop running on Windows 7/IE8, but can't get to my AOL account because the system won't... (More)
Answer
i could not attach bsnl wll to mac book
Answer
i want to unlock my idea net setter code
Answer
I have been told that internet will run better if I occassionally disconnect & reconnect my... (More)
Answer
I used to connect to the internet without problems. (I'm using motorola fax modem installed in my... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Motorola Modem:
Top Modem Experts
Rank: Guru Guru
Solutions: 3608
Experience: Semi retired, was network administrator, proficient with hardware, software, networks, CAD systems
Ask Me
Find more Modem Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
