Question about Kenmore HE2 Plus Front Load Washer
Code F20 is appearing on me washing machine
When engaging my clean cycle to dissolve tablets to clean my kenmore elite he 5t steam, the code F20 appears after only a few moments F 20 is appearing in my washing machine. The cycle stops.
    President:
  • Kenmore Master
  • 662 Answers
Http://www.fixya.com/support/r3608632-f20_error_code
Posted on Jun 04, 2010
My Kenmore Elite HE 5t is showing the F20 code 15-20 seconds into the washing cycle. F20 standing for Water inlet problem. We have cleaned and checked all inlet ports and they are good so what else
Hello Shannon;
My name is Peter. I am a retired field service appliance technician.
Code F20 also stands for pressure switch.
You have a incomplete model number so I am not sure if this is the correct switch.
Substitution: W10514214 - $48.00
This is just inside the top cover, right hand corner.
The diagram is on the following link. Plug in your model number.
Water Filters Lawn Garden Appliance Parts
Dec 11, 2014 | Kenmore Elite HE5t Washer
I have a kenmore elite HE5t steam front load washer that keeps putting up f20 error the water lines are not plugged water is flowing into it i moved it out to check the water lines and it ran 3 loads then...
http://www.fixya.com/support/r3608632-f20_error_code
This code is tricky to troubleshoot, so jsrock516 advices to eliminate the easy common sense items first.
May 14, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he 5t the code f21 comes on, the hose is ok.
This is a Long Drain Issue. Likely that something is stuck in the pump trap. Take off the mottom tree screws under the drum panel. This will remove the drum panel on the front. From under neither you can see the drain pipe trap. Unscrew the trap cap in the from. Clean out all debris and re-install. this should do it.
Feb 15, 2010 | Kenmore Elite HE5t Washer
Our Kenmore HE2 keeps giving f20 error. Water pressure is fine. No kinks in hose. Cleaned out junk in trap behind the bottom panel. Ordered new pressure switch. Works fine on clean washer cycle, but with...
This code is tricky to troubleshoot, so jsrock516 advises to eliminate the easy common sense items first
Dec 02, 2009 | Kenmore Elite 45986 Front Load Washer
My kenmore elite He 5t wash machine is flashing F
This typically indicates slow drain condition. Check for any clogs or kinks in the drain line. Also check that the pump is not clogged and that no pump impeller blades are missing/broken and that the impeller moves freely. Any broken/missing blades or if the impeller won't turn freely will indicate a faulty pump. Hard objects can sometimes make it to the pump and cause damage. Hope this helped and best wishes.
Sep 09, 2009 | Kenmore Elite HE5t Washer
Hi
Error F 20 means "No Water Detect" error. It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed.
You'll need to check for the following--
1- Check the Inlet water valve if it is clogged.
2- Make sure water taps are working fine.
3- Check inlet hoses for kinks or clogs.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 26, 2009 | Kenmore HE2 Plus Front Load Washer
F20 code.
in my fixing f 20 needs a new cpu main board in the top washer middle back side
Nov 16, 2007 | Kenmore Elite 45986 Front Load Washer
2006 kenmore smartwash quietpak4 he3t F20 code washer
F20 ERROR CODE ON A KENMORE HE2T FRONT LOAD WASHER.THE FIX FOR ME WAS TO REPLACE THE TUBE THAT RUNS FROM THE PRESSURE SWITCH TO THE BOTTOM OF THE WASHER.YOU MUST REMOVE THE TOP AND BACK COVERS OF THE MACHINE(EASY).REPLACED TUBE WITH3/16 INCH CLEAR TUBE.THE ORINGINAL TUBE HAD A PIN HOLE FROM RUBBING AGINST THE SIDE OF THE MACHINE AFTER 5 YEARS OF USE.THIS COST UNDER $10 DOLLARS TO FIX. NO SERVICE GUY=MORE BEER MONEY GOOD LUCK.
Nov 07, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
949 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
